View Full Version : S-10
- Fuel delivery problem
- Transmission fluid level
- Transfer case fluid change
- Running rough
- airbag suspensions
- 1987 makeover-tell me what you think
- manual transmission drain plug
- Are little Dodges and Fords worse about getting stuck than the Chevi's?
- S-10, won't go in gear
- problem
- 1998 s10 not starting
- P 0410, P 0704, Another Heater Control Problem, AC stuck on
- 2001 S-10 auto trans-It's the 4L60E,Right??
- Fuel Pressure Regulator Location ???
- Starting Issue On S-10 Extreme - HELP !!!!!
- High Pitched Noise On Accel.
- radio lights-trivial but why not
- inner fender
- throttle sticking
- 1987 S10 No power?
- Help changing dash lights
- Mileage Of A Great American Machine
- Reversed battery terminals
- s10forum.com
- Fuel pump question
- 1992 4.3 Liter Back Up Light Switch
- Envoy conv. foglight splice into S-10 low beams
- Clanging noise - Need advice.
- stupid just woundern question
- new 4.3L motor
- ESC module missing on 1982 2.8L?
- will the 2se carb kit work for a E2se?
- Notice: Parting out S-10
- 4.3 fuel injected
- Door Problem
- What Should I Really Replace Or Have Done?
- Differential fluid change
- Air Conditioner
- Extreme Stock Comparison
- 1989 S-10 Running Rich (Code 45)
- 1987 S10 Changing Cab?
- 94s10pickup-tranny fluid out of breather tube
- Engine Stalls - HELP !!
- 20's on a 1st Gen S10 Blazer..
- blown fuel pump fuse '92
- rear end howl
- happened once...is it a sign?
- vibration from rear
- 1991 chevy s-10 est
- whiny fuel pump?
- 92 s10 distributor to a 89 s10
- Ethonal...mixed In Gas.....good/bad?
- brake squeal
- '91 S-10 Body panals?
- valve cover gasket 91 S10
- truck bogs and dies, code 55 ECM?
- leaky water pump???
- bed cover
- 1984 chevy Suburban won't start
- Easy way to protect tailgate?
- Exhaust
- Only 1 plug had carbon build up
- Tranny squeeking
- Tranny flush but without filter
- Where did my power go?
- s 10 fuel gauge
- whistling noise
- Billet Grille for 87 S10 Blazer
- fuel pump causing problem???
- nice first gen V8 S-15
- intake question
- turning a roter
- supercharger?
- Wax and buff?
- driving lights
- another dumb ?
- rear window defogger
- To much Tranny fluid
- whats a good wax?
- fuel pump....9.3 4.3 cpi....
- tps....where is it..and how to check it?
- s-10 won't start
- 95 PU 4.3L coil
- 2000 ZR2 air filter
- Torgue Converter
- 91 Blazer Totally Dead
- speakers
- '91 s-10 blazer help.. am i doing this right?
- amp install...what needs 2 be done?
- No start until oil gauge flickers
- 4x4 service light
- 2000 Chevy ZR2 4x4 Lo shifting
- 2002 s10 ZR2 Vent Problem
- Electrical Issue / VSS & Heater Blower ?
- why does my spedo move
- Sputtering Problems
- 82 S10 won't start...
- Strokin
- egr valve location?
- electrical/fule delivery problem
- need to change your fuel pressure regulator?
- 1994 S-10 2.2 liter, engine surges at cruise, slight decel
- changing a 93 cpi spider unit?
- 93Blazer s10 - Help removing gauge panel?
- Electrical Problem???
- 96 S-10 V6, little or no heat w/temp < 32
- Gas tank Popping
- first gen hood for free
- Turbo?
- Trannsmission flush discussion
- Where is the fuel filter on a 82 s10 2.8?
- 91 s10 blazer problem
- New Fenders
- Daughters first car
- formal appoligy to dmbrisket
- more painting tips
- my 93 s 10 wont start?
- what would cause an backfire...threw the intake?
- dipstick location
- Sick of pop up ads
- 3 v-8 candidates, which one would be best?
- 96 s10 2.2l ???
- S-10 2.2 oil pressure to high ???
- rotor question
- 87 s-10 high idle
- 93 s-10 cranks but won't start
- 97 Blazer won't start
- what tranny does a 93 4x4 4.3 cpi have?
- question
- clutch pack in an auto tranny...where and what is it?
- s 10 brake light flashing
- anti-lock brake problem...
- 1991 s-10 blazer back door wont open...
- fuel system cleaner
- removing brake light switch
- A little too breezy!
- FOR SALE: Air Conditioning Knobs
- s10 blowing #4 fuse (guages)
- 1998 s-10
- Just a CRAZY idea
- 91 s-10 blazer fuel pump replacement.
- antifreeze leak in between tranny and engine block?
- Purolator filters etc.
- Engine Probs.
- going from a turbo 350 to a turbo 400 I need Ujoints to fit a 400 Yoke please help
- heater core..how complex is it to swap?
- I accidently put premium gas in my S10
- 88 to 91 S-10 blazer swap
- Stuck with a heater core
- Heater
- carberator
- Lt1 350
- 95s-10 hard starting when warm
- Monetary question...
- Post Head Gasket Temp Problem
- Engine Swap 1990 S-10
- dye
- brain buster s-10 prob
- brake lights
- wierd oil leak
- 2.2 to a 4.3 vortec
- Air cond. Compresor/1994/S10
- What will an S10 with a 454 under the hood look like?
- Help s10 seems to have a hesitation
- No more advertising Please
- 95 4x4 not working
- Antilock Light & Speed Sensor
- S-10 Blazer Center Console
- 95 s10 for sale... lots of new parts (ks)
- Lots of ?s
- 95 S-10 2.2L head gasket replacement
- 2002 S10 Keyless Entry Program
- 1998 2.2L Motor & Tranny For Sale: (FL)
- 4 wheel drive not working on my 97
- free 1st gen 2 door Blazer runningboards.
- 92 S10 350 swap with digital dash
- 95 s10 ls 4x4 transfer case help?
- 2002 S10 wiring harness
- What sensors would cause an engine not to run?
- radio turns off when using windshield wipers!
- towing S10 2x2 4 down
- 88 S10 4x4 4.3 Swap
- Problem with lights on my S-10
- 4.3 TBI to a 4.3 VORTEC swap HELP
- replacing starter on newer 4cyl. s-10
- 88 s10 4x4 Blazer tranny question
- 2.8 in 87 s-10
- 85 4x4 blazer 2.8
- 2001 S10 won't start or turn over
- Questions about a Zr2
- 88 s-10 blazer with 4.3 tbi won't turn over
- 88 s-10 with 4.3 tbi won't turn over
- new exhaust!
- bad torque convertor? how to tell
- Gull Wing Doors On S10?
- 96 s10, 2.2 ABS problem
- Multi Function Swtich
- Is it possible
- 2001 door panels
- problem w/ OBD and SES
- 1999 S-10 Running strange NEED HELP PLEASE
- Runs on 3 cylinders when cold
- 95 S10 4.3 Z code w/TBI Need Help!! Rough Idle
- '87 S-10 Blazer Exhaust Questions...
- 88 s-10 wont crank
- 383 Stroker
- 1988 wiring diagram
- 2.2L Lifter
- third brake light not working
- 88 no start need info. desperate.
- 95 4.3l W having serious issues, need help
- 99 S-10 Coolant Dissappearing
- 94 fuel pump
- 1999 S10 2.2 Electrical Problem
- S10 wont start
- Check Engine Light/Rough Start
- Front Shocks 85 Blazer
- Clutch Change
- HELP!! '89 Chev S-10 Auto Trans Shift Prob
- '98 ZR2 4x4 trouble
- power window/lock conversion
- 92-95 4.3 vortec vacuum line placement--runs then hesitates at throttle up-
- 0-60 times?
- 2.8 flywheel ???
- 2.8 vibration/flywheel question!!!!
- igintion timing
- subs in standard s-10?
- Does anyone else have this problem?
- 327, 350, or 383 in S10?
- 2.8 vs a 4.3
- K&N Air Filter on my '87 S-10 Blazer
- Ticking Noise/Timing Belt
- turn signal tempo
- clanking noise missing 2.8L
- brake fluid leak
- '94 ESC Sensor
- Fuel issue with 1996 4.3
- Light Problem
- Thermostat Installation on 91 S-10 w/ 2.8L V6
- anyone heard of this before?!
- Headlights going CRAZY!!!
- Gas Tank
- Search Before You Ask Questions!
- Turn signal/headlight problem
- S-10 & MPG
- U Joints
- What's the difference between an S10 and an S15?
- 3.4 what is it?
- Keyless Entry Wiring
- 88 s-10 no start
