View Full Version : S-10
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. Where does the O2 Sensor go
  2. 4.3 engine miss ??
  3. 1996 si stepside f/s
  4. 2003 S10 4.3 V6 Idle speed
  5. 3rd Brake light Melted
  6. 7.2 Liter in S10?
  7. How do you compare 'liters' with regular engine sizes?
  8. Will bigger tires cause your speedo meter to read differently?
  9. 2001 S10 Autotrans downspout washer leak
  10. engine cuts out under a load or when accellerating
  11. passengers air bag removal
  12. 92 s10 4wd ABS light on
  13. hot weather non starts
  14. Door Panel Removal on '86S-10 Blazer
  15. '88 S-10 Blazer, 2.8l Idler pully
  16. Need help removing drivers side airbag
  17. driveshaft
  18. motor swap question
  19. My s-10 just went up in flames!!! HELP!!!!
  20. stalling
  21. need some advice
  22. S-10 Idle
  23. '94 4 Cyl. Very slow, need speed
  24. fuel injector??
  25. machined Cam on a 99 s-10
  26. 96 S10 Reminder Tone Module
  27. should i make the purchase?
  28. engine troubles
  29. 95 S-10 suddenly running rough
  30. 1997 S10 weird Problem
  31. fuel capacity
  32. question for body worken guys
  33. transmission question about switching 91 transmission with an 88
  34. Can newer grill bolt in my '86 S10?
  35. 88 S-10 cranks/will not fire/has fuel & spark
  36. 90 s-10 Blazer Brakes
  37. 1992 s-10 blazer squeaky front axel
  38. Installing a 3/4 drop kit
  39. lifting an s-10
  40. Clutch issue
  41. 01 ext cab rear speaker ideas plus speaker box ideas
  42. 89 4.3L Throttle Body...Leeking by Injectors????
  43. s10 fan problems
  44. Locate PCV 2000 S 10 pick up 4 cycl
  45. What parts should I keep?
  46. Some More engine questions on my 94
  47. Question
  48. Another Quick Q... Gas gauge
  49. Been Meaning to ask... what's your MPG?
  50. ABS problem
  51. Instrument Panel Lights
  52. lifting a 00 2WD S10
  53. 1995 S-10 Speakers
  54. 4.3l questions
  55. rear axle squeeking
  56. 1988 s-10 blazer 2.8l 4wd, no fuel prime,no check engine lite
  57. Electrical driveability nightmare
  58. Know nothing...need help...94 s10....
  59. duel exhaust
  60. Pictures
  61. Wont Start
  62. need to replace fuel injector on 97 S10 2.2L
  63. cat converter 2.2 4.3 swap
  64. Surging w/No Check engine light
  65. Low Pressure Switch
  66. Question About Special Tools for Idler Arm Installation
  67. MAP And O2 Sensor
  68. 1996 Chevy S-10 4.3L
  69. rear disks ever stock?
  70. 2001 S-10 Security Light
  71. 95 S-10, manual trans. 5-speed
  72. whiney tranny
  73. 1998 s10 wiring diagram
  74. 355 swap with goodies..
  75. can i bake the drums??
  76. '94 S-10 Blazer Smokes from Defrost & Floor Vents
  77. Connecting a Laptop to my truck
  78. S-10 350 swap
  79. 85 S-10. Headlights, tail lights, horn, instrument lights and radio out.
  80. How do you tell if a fuel filter needs replacing?
  81. wont start
  82. 96 5-speed tranny locked between gears
  83. 94 s10 4.3l tbi black smoke
  84. truck bed seems loose?
  85. Excessive cranking
  86. Emissions Problems with my 94 ZR2
  87. Emissions Problems with my 94 ZR2
  88. No downlow power
  89. Open Diff. to Posi rear end
  90. IAC Vavle, how much should it move?
  91. hows the zr2 lifted
  92. '91 S10 Blazer - Alarm install questions
  93. Neon Light law
  94. speakers
  95. 98+ High beams and Lows, both on
  96. 1998 S-10 Heat doesn't turn off....and A/C doesn't work no more
  97. Strange starting problem
  98. 95 S10 in 4yrs 12-15 starters
  99. newbie here with some s10 questions
  100. 1986 S-10 GM Shop Manual
  101. '95 S10 Vortec v6 4.3 and '91 GMC v6 4.3 engine swap
  102. code p0140
  103. For Sale
  104. 2002 S-10 Performance Upgrade
  105. still wont start
  106. Question about the emergency lights
  107. Sub enclosure for ext cab(down firing) yeah or neah?
  108. CPI Parts
  109. Hey guys, can you help with an S10 that stalls out going down the road?
  110. fuel pump?
  111. reclining seat lever
  112. S10 Cranking problems-please help.
  113. How to get codes?
  114. help is nice let me know what you think
  115. 93 s10 blazer tranny problems
  116. do i need a new driveshaft??
  117. 2.2 overheating fan maybe?
  118. '93 S-10 Problems
  119. should i remove the bed
  120. Is valve tap bad?
  121. Engine swap
  122. Do I really need this fuel pump?
  123. S-15 check engine light
  124. s10 found
  125. s-10 back brakes lock up when get wet
  126. Fuel injector problem --HELP
  127. Coolant leak around 2nd left manifold bolt.
  128. fuel pump removal
  129. S10 making a quiet grinding noise
  130. 94 s10 blazer 4.3 vortec vin W
  131. 94 s10 blazer tranny shift adjustments?
  132. radio clock stays on, battery drains????
  133. transfer case?
  134. Do Anyone Know The Dimensions of....
  135. electric brake controller
  136. Gauge Lights
  137. tps question
  138. thermostat gauge
  139. Frozen Fuel Pump replacement
  140. i need a opinion on a motor
  141. leaning S-10
  142. Idiot Lites to Factory Gauges
  143. starter pinion sticking
  144. EGR Valve
  145. Where to check fuel pressure 94 s-10 tbi
  146. S-10 Blazer wiring problem
  147. Flexplate To Torque Converter
  148. 95ZR-2 fuel injection
  149. MAP Circuit low input.
  150. 1987 door panel removal
  151. Oil drain plug spins around but doesn't come off
  152. Question for the 4cyl owners
  153. power loss under acceleration
  154. what do i have?
  155. swap questions
  156. I does anyone have one?
  157. 98 with very strange problem
  158. Rattle noise in exhaust under load 98 S-10
  159. truck wont start
  160. Storing engines
  161. Check for broken timing chain
  162. '99 S-10, No Spark
  163. How to Set timming
  164. Missing wires at ECM. Help!!!
  165. Hissing Noise From Heater/AC Controls
  166. fusibile link
  167. New moter
  168. 91 2.5lt FPR
  169. full-size rearend on an s-10
  170. only getting 11mpg out of my 94 s-10 4.3tbi need help
  171. Odd problems.. Could use some advice quick
  172. Cant get carb off
  173. Sand blasting a rusty old 38 ...
  174. what to look for
  175. 94 s10 blazer alternator belt
  176. window problems!
  177. clutch proglems
  178. S-10 TBI Removal On The Fly
  179. sellin 94 s-10 blazer
  180. the new guy
  181. something squeeks
  182. Passenger Side Plugs Fouled
  183. my truck hesitates
  184. HELP! I Cant get the starter out of my 95' S-10
  185. water cylinder decarbonizing.. how much?
  186. s-10 xxtreme
  187. flywheel problems
  188. shift knob
  189. ignition
  190. Subs In Standard Cab Question
  191. s10 2.2 to 4.3 engine swap
  192. clear coat on black plastic....
  193. Center Console & Bucket Seats
  194. Won't start!
  195. is it egr valve???
  196. Grind Noise in Rear end when I accellerate
  197. S-15 4x4 stalling
  198. Code?
  199. Oil pressure gauge flipping out
  200. cam shaft
  201. 94 4.3 fuel problem??? HELP
  202. Exhaust smell in coolant
  203. Losing power
  204. vss to cable driven speedo
  205. 95 S-10 "Wierd" starting problem
  206. Any RWAL ABS brake gurus out there? (Long)
  207. Stuck in 4Lo
  208. 94 4cyl. auto no up shift
  209. grinding noise on acceleration
  210. Intermittent rough Idle below 1500 RPM HELP!
  211. 1993 S10 Radio Problem - Help
  212. tire question
  213. More Power! 4.3L
  214. Air Conditioner
  215. One of my many questions
  216. damage report
  217. all cylinders misfiring only a p0300 code !!help me!!
  218. Electrical issue - signals, hazards, brake lights, buzzer
  219. How do you take the overdrive off in an S10?
  220. Pontiac 350 and turbo 350 tranny
  221. 50-55 fuel pressure good or bad?
  222. Cab Corner Panels 1993 S10
  223. fuel pressure??
  224. 2000 S10 clutch fluid
  225. Replacement Of Oil Cooler Lines?
  226. clutch linkage
  227. 4.3 tbi to 4.3 cpi swap won't start
  228. sudden rough idle and blinking MIL???
  229. 1990 s10 dash lights
  230. transmission probs?
  231. Failed Smog, High CO% but Code 44 Lean Mixture? Help Please!
  232. Still Screwy Electrical Issue (Speed Sensor)
  233. TNT Motorsports throttle body spacer
  234. I want to touch up some scratches on the back bumper, help!
  235. fan spinning out of controll
  236. 10-Bolt F-body rearend on V-8 S10
  237. Vortec heads on a Z block?
  238. Factory speaker sizes 89 S10 ?
  239. 1989 4x4 front differential
  240. S10 won't pick up speed as well when hot
  241. 87 S10 Hard Starting
  242. FIXED! AC Stuck on, Heater Controls not working, Hissing noise
  243. 94 Starting Problem
  244. '93 s-10 wrrr'ing noise from distributor
  245. AC help
  246. adapter
  247. The SS-10!!!!
  248. 95 s-10
  249. electrical problem i think
  250. 400 small block conversion
