Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Mitsubishi
> Eclipse 2000+ |
View Full Version :
Eclipse 2000+
Web
AF
Pages :
1
2
3
4
5
6
7
8
Car goes to Hot when idle
Draining power?
2001 Mitsubishi Eclipse EGR code
Vr4
misfire cylinder 2
Saying Goodbye
2k Eclipse clutch problem
2002 eclipse spyder engine swaping
Code 1610
Changing Spark Plugs
Worth it??
Trunk space
Underhood fuse box question for an 03
Whats some good name brand tail lights?
Exhaust
lighting problems
Any of yall using EvoScan or Nology?
so little wires and not a clue
appearance?
exhaust ?
2001 eclipse backup light wont go off
Another Clutch Question
louvered Rear window
rubbing noise
Clutch going bad?
Tire Opinion
Transmission Temp Question
2007 Eclipse?
parking light problem
WHY Do this to the car????
Broke my crankshaft pulley
Brakes & Rotors
weird clutch noises
windows
Need some info on a harness
Just a curiosity question
'03 center dash speaker
2000 Eclipse Error Code
2001 Eclipse GS speed sensor
? needs answering quick about a turbo
2000 3.0 oxygen sensor need help
body kit
WpBoosted3g
Strut, bushing, or swaybar?
Replace tie rod for 2003 Mitsubishi Eclipse
Just got my 01 eclipse, gonna mod it.
Fuel Injectors?
2002 Eclipse GT question
CLutch Trouble
2000 recall
new eclipse.....?
Seat Belt Guide
SPEC clutch help
Stock Head Unit *Error* Codes
Need help with o2 sensor
clutch slipping
supercharging
Keyless remote programming
eclipse heating problems
Please, HELP!!!
FS: 2003 Eclipse
2001 GT Eclipse Turbo or SuperC help
Need CD/Cassette Radio for a 2000 Eclipse
Product review: tires Dayton ZR 215/50/R17
weird sound
Cheap mods for 2001 eclipse GS
Infinity stock CD player help!!!
turbo kit 2000 eclipse gt
2006 Eclipse Gt Spyder
2000 Eclipse GS window Stuck
backup lights
GSX Revival?
Re Bulid my v6 gt motor
Transmission issue
Bad Reviews!! HELP!
Ever Notice?
2007 Spyder Suggestions and Help needed
Suggestions
Air Filters
Hello fellow Eclipse owners...
Stop Posting In What Car To Choose Thread!!!!!!!!!!!
shaking/smoke smell
Spark Plugs!!!! I Need Help!!!!
whistling out the exhaust
??????forced induction???????
Headlight Bulbs!!!
Revs dropping and rising
Happy New Year everyone!
Transmission conversion??
Wiring guide
Is my transmission my probmlem??????
ticking in my engine
2002 ecu location possible flood damage
Heater Problems
High Stall Torque Converter?
I need codes
Cold Temperature Problems?
headlight wire clips
Flood damaged car.
Update software?
Stuck in the Midwest
manifold differential pressure sensor
2001 Eclipse Headlights
Is it worth it to put on suspension or have shop do it?
dumbass in need of some assistants lol
engine shuts down in the middle of the street
Max Rev Turbo Kit
eclipse guys in florida
2003 Eclipse RS, AT transmission shift bump
Rough engine sound
Fuel Filter need
WTB. lifters
Dual Exhaust
turbonator does it work?
i need some advice
need some advice
mitsubishi eclipse stock radio center display
2003 Eclipse RS, AT transmission forces to shift gear
2003 gts front ecu ticking
Ground Control with KYB?
Evo VIII brakes
Serious Question
2.4L Ignition Coils Problems HELP!
01 gs 2.4 motor
A/C Light Flashing
soo uhh, this is bad right??
Timing Belt
Selling my car
which motor?
2001 eclipse 4cyl motor swap
2001 awd conversion possible??????
4G Rockford Fosgate Sound System Aux
Mitsu LED Kits?
Buying a 2007 Eclipse GT
sad...sad...day
ES shifter bushings
tail light install
Starting work on my 2991 GS. Looking for tips.
Trans fluid ? etc..
Headlight Bulb
Rear Spoiler
Think these will fit?
rough idle
Headlight problems!
Need help 2000 eclipse gt
Custom turbo build
Starter/Alternator Installation
WD-40 as cleaner
need OEM cats for a 2002 eclipse 3.0 GT
boost thru MAFS
The 4G69 swap
Hope for the 3g after all
Check Engine Light
Keep or sell?
Stupid Question
Stupid Question
does the 06 eclipse have a govenor?
Temp. bulb change
Air Conditioner leaking water inside!
Car stalls please help
elcipse and sonata one and the same?
Adjusting Valves/Lifters
Minnesota misubishi cook out Saturday 8/18
Help With HID Kit
Help With HID Kit
Help With HID Kit
Desperate for Information
radiator crack
code p0301 again
1991 Ralliart spec 3000gt for sale
Question about motor oil
2000 Transmission Oil Filter Question
2007 Eclipse GT or 2006 mini cooper S
radiator fan
2001 Eclipse amp wiring
New car looking for good exhaust
FS: 2000 Eclipse GT
99 3000 gt or 96 sr eclipse
2003 ECLIPSE spyder v6 DEAD????hELP
4gen
remotes???
Think I have settled on wheels
2003 Gt Spyder V6 Mod Help???
Modified stock intake - throaty sound
dtc p1610
VIS Body Kit
Headlight Accents
heat from turbo
Trip Odometer
warranty ?
can you make an eclipse 2002 rs fast enough
stereo removal
2003 Spyder GTS - Rough Ride
problem with altezza's
killed all dash lights
Power Slot rotor install
new eclipse brother
need stock intake
hole in seat
magnaflow exhaust= +10 hp?
headlight problems
how much faster....
just bought a 2000 eclipse
Lowering / Rims for a 2007 4G
money for gas
General Question about Springs
Speakers
F&F Tokyo Rice
Fuel Injector Clog?
EclipseGt vs. 3000gt
few qustions
Question about struts
Spark plugs
vertical doors
2002 Spyder won't start
more hp
Very new at this.....help
quarter mile times?
Sunroof Judder
LF Fender and paint
Eclipse 2003 speedometer not working
remote trunk lid
cali or fed spec
Just hit 100K Miles
Torque
Turbo Kits for a 3rd gen?
SES light
eclipse hood
2001 Spyder convertible top won't open
Clutch or transmison
MANY questions regarding mufflers/exhaust/catback/headers etc.
Help Wanted-Clutch
Throw Out Bearings
Rim Size???
Help Installing a Pionner Premier CD Player in 2001 Eclipse GT
Factory Alarm Arm
2001 Eclipse Spyder GT For Sale!!!
i gotta problem...
Radio display question
Speedometer Needle goes wrong way! HELP!!!!!!!!!!!!
AC lines
Clock Light??? Want to change to Blue!!
Dash Lights
can i ask a motorcycle question???
clicking sound??
birthday party time!!!
what's that song???
Florida Eclipse Club
Help With Which Muffler To Get
Web
AF
