View Full Version : Forced Induction
Pages :
1 2 3 [ 4]
5 6 7 8 9 10
- Forged Pistons & Rods
- Need some suggestions....
- why do you inject water into the chamber?
- oil drain
- Question
- 2 turbo questions
- best b-series motor for turbo is......
- Anyone have a TurboXS's BOV?
- WTB 99' civic si ecu
- For Sale Jdm Type-r Lsd Gear Type
- E-bay Intercoolers?
- Nos (zex) on Stock si good or bad idea?
- not again!!!
- Ignition upgrade for nitrous CRX
- fuel system for turbo
- D16 with turbo
- Turbo for Lewd! (dependable??)
- Can someone give me a rundown of HOW you engage nitrous?
- Really Important
- Supercharger?
- Turbo (or supercharger) and Nitrous for a 1985 chevy 5.0 (305ci)
- painting charge pipes
- superchargers
- custom downpipe
- ebay turbo?
- k&n filter worth it???
- 91 prelude DOHC turbo
- WOW! Civic + B18 + Turbo - Interior = FUN
- need some help with a turbo d16
- grounds=more hp/tq???
- What turbo for my gsr
- Changing Internal Wastegate
- A turbo question for 95 Civic
- upgrades before nos
- 94'gsr turbo problems
- N20 and turbo?
- JDM B20a turbo project
- worth it ? A guy wana sell me a JRSC with 1500 USD . worth it ?
- tranny swap
- 50 Shot nitrous on a prelude
- turbo for 91 accord
- Turbo with miles?
- forced induction: additional wear and tear?
- turbo kit for 98 civic hatch
- how much will it cost for turbo intall.
- Turbo/Supercharger relation to fuel mileage.
- can a turbo run without a wastegate?
- hard ass built B16
- GM 3800 SC tech question... ...
- Look what the fed-ex guy left at my house today
- 354 hp out of crank? GSR with stock int and 7psi of boost ?
- gsr turbo
- Lebaron Turbo
- edelbrock turbo kit
- Turbo and smog check
- radiator hoses
- Post turbo install TUNING
- safc or safcII
- Super charger like ideas?
- tapping the oil pan a must?
- Exhaust
- white smoke
- superchargers? takes power to make power
- Does anyone know where to get the d-3
- d16 turbo question?
- n2o
- air induction
- b16a2 turbo ????
- Turbo Tuning
- how to tune?
- Are intercoolers really that effective???
- Help Hooking Up Zex Dry Kit on My B16A
- nawwwwwsssss
- Turbo, Turbo, Turbo
- Fuel/EMU
- k27#8 880hp? help plz
- Sotck 94 Accord F22B1 w/ Turbo???
- Build a SUPERCHARGER
- Any point in 20psi?
- Turbo + Nitrous
- This is you Piston on N2o
- Newbie needs Odyssey help!!
- What size T3 turbo for a D16z6
- turbo,supercharge,or ls/vtec
- Frankestein Engines
- b164a2 turbo? psi?
- go turbo or all motor?
- Greddy turbo kit on H22a?
- resleeving and port/polish question
- Custom Turbo Setup
- turbo accord qestions
- quick spooling turbo setups
- just a few more questions and ill quit buggin y'all
- T3 or t3/t4
- turbo question
- what pistons to use if i want to run alot of boost?
- Advice..Turbo on my 11:1 gsr motor????
- 2 Stage NITROUS
- A Contraversial Issue!
- A Contraversial Issue!!!
- twin turbo honda
- noob turbo questions
- Ideal compression ratio?
- whats the cheapest complete turbo system?
- help.... 22psi
- help..... for 22psi
- N2O on top of a Centrifugal S/C
- supercharger setup
- Custom Kit or FMAX?
- je pistons... and crower.. and darton
- b16a block
- do u need turbo software?
- Accord 98 turbocharged F23A1 engine
- Does anyone know anything about the KKK K27 turbo?
- Garrett Turbocharger
- greddy turbo 4 sale
- compression vs. boost
- which motor is better for boost
- Ls/vtec turbo
- Removing sleeves from stock JDM H22a?
- Turbo Kit or put one myself. Which one???
- how much hp increase can i expect from the cheapest greddy
- GSR & Type r heads?????
- turbo give good power gain?
- d16z6 superchargers?
- over boosting
- anyone runnin the greddy kit?
- Eclipse/Talon turbo on integra ls
- Someone asked this already.
- 'Most' Easy to install....?
- anyone with VAC/BOOST gauge installed in car?
- Best BOV runnin 8psi
- VTEC Controllers
- Vacuum gauge install????
- Just recieved shippment of Manifolds!!
- Does that Sprial Max thing really work?
- Water cooling lines for T3?
- nitrous + turbo
- T3h Setup
- blow off valve location
- Porting, turboing and stroking.
- 96 cavilier rear defogger
- How to hook up FMU?
- t25 vs. to4e
- T3 Turbos From A 80's T-bird
- vtec safc for sale on ebay!!!!
- Turbo vs Supercharger
- want turbo!
- ls turbo..??
- Whats better? N2O sprayer or Co2?
- 10 psi LS Vs. 8 psi Gsr
- bar websites?
- HELP!! in the metro Atlanta area
- Whats the diff in the N2O setups?
- Zex Install
- Turbo help
- Worth it to turbo H23 lude?
- how much boost is reliable
- N20 + Turbo, to much for a stock motor?
- Carb number?!?
- overall turbo questions
- Nitrous Pics
- I need help installing a turbo on an LS
- turbo question. HELPPP
- Lowering Compression Ratio
- Making final Turbo decision
- wich diagram to use?
- turbo.oil.pressure.
- blow off valve flutter
- Turbo specs...
- Cost for engine Testing
- Help me out, putting T3 turbo on my B18B1
- Newb Lookin For Answers
- rsx tuning
- B16A2 turbo experience
- how should I tubro a stock LS
- New Garrett To4 for sale
- Difference between turbos
- High-compression & turbo
- racing
- how do external wastegates work?
- Turbo/Supercharger help!
- for a turbo
- Need turbo guidance?????
- what needs to be done to my engine to add a turbo
- SC Resale Value?
- supercharger leaking oil
- T3 cheap ... Worth?
- T3/T04E Turbo , what do you think?
- Building Turbo kit, B18B1... FMU, MAP, Manifold Questions
- how much to install revhard stage 2 kit?
- Can someone help?
- how to switch to external wastegate
- Which turbo 2 use???
- SOHC ZC/VTEC and NOS
- wanting to turbo my d16z6, what do i need
- Upgrading questions.
- OBD II tool
- Dyno daze in the corn field, do we need it?
- turbo kit install is done!!
- which setup is better???
- Turbo install
- I need to build a supercharger, and i don't have any specification to do it.
- One Beast of a Honda!
- B18a Turbo
- Best Turbo for Ls/Vtec??
- best turbo/turbo kit for integra GSR???????need help
- best supercharger for acura integra GSR????????????
- oil pressure switch
- V8 turbocharger
- integra supercharger on 2001 honda?
- compression ratio?
- What is turbo lag?
- How does a blow off valve work and what does it do?
- check engine light
- safc tuning
- what can i do to make my car faster
- Piping 101
- slow progress
- Nos
- ANOTHER turbo question...
- turbo my D16z or b16
- B16 turbo
- The best intakes and Turbo manifolds
- Installing wet kit on b16
- Nitrous/Turbo theories
- Turbo Book's
- Vid: My JRSC RSX-S
- anyone got a turbo for sale??
- Header, Intake, Exhaust
- prepping for high boost.
- Turbo Manifold Questions
- EGT Probe/Gauge
- B16a2, turbo, injectors questions
- b16 or b18c1 w/ Vortech Supercharger?
- Installed turbo, now car wont start, Help!!
- Garrett AR Escape 47/AR 51 Compressing, small for b16a2
- Best Honda/Acura for the 1/4
- What do u think of electric turbo that works
- o2 sensor location
- Manifolds
- Cam Question
- the difference of a turbo and and super, good info please read
- V-AFC II worth it?
- just got my s2000 and need advise and help!!
- compression ratios
- sc-14 s/c onto a 1994 mazda b3 motor
- piston rings 4 n2o b16?
- turbo timer install
- Turbo setup
