View Full Version : Performance
  1. Air Compressor Bolt to intake?
  2. help with firebird 455 engine
  3. Help chosing a performance engine for my car
  4. Any FE guys out there
  5. 1970 Dart Imp stats
  6. Gearing change
  7. twin turbo mustang transmission
  8. Fuel pump problems
  9. 1970 Duster Help
  10. 1970 340 Duster
  11. Anyone Know much about Patriot Heads
  12. Big Block Chevy Cam Recommendation Anyone?
  13. Chevy Bowtie Heads
  14. stock torque
  15. Best Deal On Vortec Heads
  16. 572 Chevy / 750 Horsepower Performance question.
  17. 355 Stroker questions
  18. new carb help 2 brl /4brl
  19. 350 runs rough
  20. Motor Mounts. Pontiac vs. Olds
  21. Pontiac Engine Smokes...after shifting gears
  22. 350 chev timing problem
  23. Stingray vette Big Block swap HELP !!!!!!!!
  24. MSD spark problem
  25. Need help with twin turboing a 327ci in '57 Chevy
  26. cheap easy horse
  27. Gear drive timing sbc
  28. cut outs
  29. holley carb install
  30. bubbles in gas filter
  31. ford 302,shift point
  32. Th400 leak
  33. Good carb for a 305?
  34. Big Block Bow Tie Specs
  35. pontiac 400 hp
  36. The most you can bore a 305?
  37. GMPP Crate engines.
  38. 350 SBC HP Guestimates.
  39. MPG for a 351 Cleveland
  40. 351c to 429 swap
  41. what carb is reliable streetable and decient
  42. holley carb problem
  43. 351c knock
  44. Which cam and pistons to choose???
  45. TH400 weak links
  46. New Motor New Problems
  47. Help with engine swap
  48. egr removal
  49. ford and chevy power train questions
  50. Junk Engines
  51. Aftermarket Guages
  52. C6 or FMX?
  53. torque heads
  54. This a good cam?
  55. just few simple questions
  56. Ring Landing Spec
  57. Cam Help?
  58. Mondello Parts
  59. Newbie Question - Distributor Install
  60. Hooker Headers
  61. Cams - For computer .vs non-computer
  62. Dual Exhaust
  63. Torque Converter for 350
  64. Spark Plugs for 350
  65. 351m with 400 Camshaft and Pistons
  66. Supercharger for 1978 ThunderBird
  67. building a 290
  68. trans swap
  69. ford big block in 82 chevy camro
  70. pro-touring anyone?
  71. carb problem
  72. 454/455 Intake
  73. Edelbrock Carb Question
  74. big block rockers
  75. TH350 Shift Kit Questions
  76. Dyno In Wi
  77. PCV Crancase vent Questions
  78. timing 5 degrees after top dead center?
  79. so lost 350 or 383?? seached..but now lost
  80. super/turbo combination
  81. Building a 383
  82. Radiator
  83. Octane for street rod
  84. building 1st engine
  85. Vacuum operated exhaust?
  86. Small block chevy install/removal
  87. Recommend Performance Shop
  88. Whats a Blower?
  89. Power valves
  90. looking for advice on a cam swap
  91. ignition idea
  92. Cold Air Intake Question
  93. Holley and Demon opinions?
  94. Blocking off EGR
  95. performance temp coatings
  96. 77 T/A 403 Perfomance upgrades
  97. Help Making Scoop functional
  98. 77 T/A Olds 403 heads swap smaller 350 heads
  99. tubo kit
  100. Holly-vs-Edelbrock
  101. normal operating temp
  102. swaping in a 454 bbc
  103. Sebring performance suggestions
  104. why is my car so fast?
  105. Stroker kits
  106. rod length selection?
  107. boosted carb, what size?
  108. Would this motor fit?
  109. ford 289 power
  110. 351CID flat to roller cam
  111. which carb. should I get? here are my specs
  112. NOS - Turbo 84 Camaro 355 HELP!!
  113. Suggestions on 455 engine mods
  114. gta 5.7 liter t.p.i. question?
  115. Which Carburetor?
  116. New parts..
  117. just bought 90 chevy truck...
  118. 89 Z28 LT1/T56 performance
  119. 396ci 500hp 6.5L LS1 Crate Engine on Ebay
  120. Saftey?
  121. LS5 454 engine questions
  122. BB chevy radiator
  123. Stock 400
  124. my engine
  125. 94 vtech in 92 accord ex
  126. Distributer Timing
  127. supercharger ?
  128. Pontiac GTO
  129. coil on hei distributor
  130. Racing? :)
  131. Recommendations - Rear Diff for IRS
  132. Serpentine conversion - BBC
  133. serpentine conversion SBC
  134. quick question about engines
  135. '69 Firebird fuel injection
  136. People who know cars please help
  137. Horsepower/Torque Kits on a 350
  138. Bohnalite 6-71 Blower
  139. A blower that I saw
  140. performance parts
  141. 4 wheel drive?
  142. crate engine
  143. crate engine
  144. 1985 trans am 305 t.p.i to a 454cid
  145. cowl hoods
  146. Engine Questions
  147. tranny questions
  148. Increase horsepower
  149. 82 Malibu Engine
  150. Help me build a 289
  151. Oil coming out of Dipstick and breather?PCV valve?
  152. Holley carburetor jetting
  153. Engine ID
  154. engines
  155. Burnouts
  156. Compression Ratio for Pump Gas
  157. Wheel and Tire sizes
  158. Welcome!
