View Full Version : Blazer
- PCV valve noise
- Odd vibrating noise 98 Blazer
- 2004 Blazer 4.3 liter tapping when cold.......
- 98 blazer w/4wd issues
- fluid swap
- Engine Ticking and....
- 2001 blazer wont start replaced fuel pump too
- 2001 ZR2 electrical issue
- 4L60E valve body-I dont get this
- 1996 Blazer ECM Fuse blowing???
- Every which way but loose......
- A/C changes vents by itself
- Need some help on recent issue.......
- No Defroster only dash vents
- Heat blend door stuck
- 99 blazer
- 4l60e oil capacity
- Alternator
- blazer fuel filter ?
- Fuel Tank Locker
- Do I replace the engine?
- quick ? on transfer fluid
- What option is this?
- may sound like a dumb question
- security system woes
- water pump removal
- 99 Blazer ZR2. Need to buy a new fuel pump.. Looking for part#'s?
- K&n air filter question. Will this work?
- Fixing your light on the HVAC controler
- 97 Blazer tranny fluid change
- cash for clunker engines
- 95 s 10 blazer
- cfmi to mfpi
- Chevy Vs Ford Vs Jeep
- 1989 s-10 blazer engine
- Thanks to the forum!!!
- Don't use Fram Oil filters?
- 1998 chevy blazer
- Short block replacement..other parts to replace
- Cutting off the 4x4
- RPO codes
- Spare tire rack...You can put it on!!!
- Chevrolet Blazer blueprints
- not a fan
- Cleaned MAF....What a difference!
- 4.3l vortec???
- code readers
- 2003 Chevy Blazer Haynes Manuel
- Please help
- Fuel Filters. Two words. Replace them!
- Airtex Fuel Pumps - Buyer Beware
- Blazers Model 93 & 95
- What Year Blazers?
- My Blazer ownership review
- Differential Diagram
- 2000 Blazer rear cargo shade handle info
- Need body mount bolt and big washer
- ? on lifting '03 Blazer 4x4
- Tire choice
- Differential type?
- Tire size calculations
- 1994 Blazer Sport 4x4
- Car Alarm Model # AL100-H who makes it?
- Carquest Radiator Cap?
- Door spring
- suggestion for the forum...
- i found a way to remove the center plug on the driver side 95 & up
- Autocerm! Anyone Tried It? Is It Safe?
- Discount on RockAuto Parts!
- Found This To Be Interesting
- 2 wheel or 4 wheel drive
- how can i show a pic of the ploblem
- '96 blazer Body panels
- The "Other" CPI failure mode
- lift kits
- speedometer problem
- help again
- in-stant fill
- Is the 2.2 S-10 a real dog?
- blazer s-10?????? probably a stupid question
- thinking about buying a 2000 zr2
- 98 Blazer noise question
- 96 Blazer 4x4 remove seized engine HELP
- comon moderators get real
- wheres my post?
- Thanks Blazee & BlazerLT
- 265/70/15
- What's the name of that oil stuff????
- Duralast Ball Joints?????
- Scan Tools For a 95 Blazer
- Welcome to our new moderator.
- Looking for parts
- buying a 99 trailblazer
- The Difference
- Parts for my Blazer
- Ripped off at Commonwealth Motors
- Overhead console
- Best place to purchase the 4l60e atsg guide?
- Help buying a 1998 Chevy Blazer
- Hello
- What's the best oil?
- 96 blazer
- 4.3L to 305 swap
- Where to get AC delco tune up parts ??
- synthetic or standard?
- New member
- How many SUV's went into the classifed sections last week
- rpo
- 1999 chev blazer good deal ?
- Thread ??????
- blazer as next vehicle?
- thanks to this forum i have a digital dash
- Good Site For OEM Parts?
- Tires
- Mobil1 formula
- How big a Boat do you tow with your Blazer?
- 1998 blazer motor type...W??
- 2002 keyless remote programing
- Need advice! 96 Jimmy Fuel lines leaking
- Can't find thread, help if you can
- Radiator replacement
- Transmission fluid problem
- Online repair manuals
- oil pressure
- Suspension Lift
- Power window regulator
- 2000 blazer rear brakes staying on
- Tires
- anyone have a carfax account I could use?
- 4x4 issue resolved
- offroading
- Tune Up
- engine fan question
- OnStar will be usless next month?
- 99 Wheel Cap
- o2 sensor is stripped!
- Why are some taller/shorter?
- 2000 Blazer radio
- ZR-2 Questions
- $10.50 at the junk yard wOOt!
- First real test of my 4 wheel drive
- Anyone use speed bleeders?
- 99 Blazer Vacuum Axle Actuator
- Inspection time!!!! Exhaust work!!!
- How Do You Replace the Airbox Cover?
- 94 S-10... whats the difference
- 2006 Blazer Pics
- American Engine Installations - Milwaukee
- 4.3L Vortec Lifters!
- Which tires???
- Maf combatability
- CAI cone filter replacement
- Lower Control Arm bushings
- programing a 2000 trailblazer remote
- Transmitter for a '97
- where is the m.a.s. on a '95?
- CSFI Swap to MFI
- steering column replacement problems
- Oxidized wheels: Any one hve some tips on cleaning them?
- Rear axle bearings S-10 Blazer
- Wheel lug torque? How much?
- Coasting in Neutral
- Where can I find interior clips?
- Cleaning floors
- Recommend a catalytic convertor for a 1996 2dr 4x4
- 97-98 Blazer-known problems?
- 1996 lt1 power problems
- Running Boards
- rear end differential
- A/C HT6 Compressor
- daytime running lights
- wiper arm removal?
- Does any one know where this o2 sensor is
- Alternator
- 95 Blazer 4x4 vacuum lines
- Question about idle speed
- wiring diagram for hazard/multifunction switch
- Faultfinder/shortfinder
- Oil Pan and Trans pan Gasket replacement
- Rear Window Shocks
- Rear interior help...
- What is a plenum and what are poppet valves?
- De carbon Shocks: MonoTube or Twintube?
- 97 s-10 radio doesn't work
- Free repair guide
- Ebay $6000
- 2000 Blazer Master Cylinder
- tapping noise in motor
- Hooray for my dead fuel pump
- moan-whine&clunk
- heater core??? Need help???
- help replacing the rear wiper motor 2k Blazer
- Loud Hum & Clicking
- Body Product Line
- 96blazer abs
- Crankshaft Positioning Sensor Code [Resolved....stupid mechanic]
- Rear Defog Wire
- What brand torque wrench??
- I have installed the positive, and negative battery wires incorrectlly
- 2wd to 4x4, is it possible?
- 1995 s10 blazer blower switch?
- Cat Removal
- i got the codes, now how do i fix them?
- need tips and tricks on replacing rear leaf springs
- Starter location 1996 Blazer
- Transmission question
- Interesting Experience
- Multifunction Switch--Clean or Replace
- v8 vortec in a blazer... Possible?
- Intake manifold gasket
- Trans filter seal install question
- Changing Parts...
- Shipping cars
- Rough Start
- Engine Knock?
- Rear diff play
- Maintenance Time
- Hypertech Power Programmer 3 Part #30001
- Heat & power loss
- Fuel Pump Dies, Then Tow Truck Driver Dies!!!
- Grille Removal
- headlight switch
- 4 x 4 lights
- Aftermarket undercarriage protection?
- Transmission Question Not a Blazer
- Someone please help, before I shoot it
- Timing on a 95 4.3l vortec (vin w)
- Park Light question
- 95 OBDII ? and scanner.
- Good Bye, Good Luck and thanks!
- More Q's - 2000 Blazer
- Excessive Brake Dust & Squeaky Brakes!
- PO440 CODE / 97' Blazer
- screwed on power steering flush
- Head unit wire harness
- stall speed
- starting in second gear?? automatic....
- Well that was a short honeymoon
- s-10 blazer 86
- Ball Joints- TRW, Moog, Perfect Circle, or other?
- Trailer Class 3 Hitch
- 1995 Blazer A/C question. Is there a clutch relay?
- 1985 Blazer engine change
- Those who have done BL on first gen, is this a 2 pc steering shaft?
- 99 blazer
- Hello from new guy
- Catalytic Converter
- 92 front diff engagement?
- Engine swap questions
- 1999 Blazer Climate Control Problem
