View Full Version : Blazer
- 2003 EGR location?
- Hesitation in acceleration
- Front diff seal change
- 95 blazer won't start
- Should I stop? Or go for it? Need thoughts.
- 89 Blazer Front end feels funny
- 2 new moderators
- Delayed Forward & Reverse
- FAQ and How to's Inside! READ ME BEFORE POSTING!!!!!!!!!
- ::95 Blazer:: Play in rear??
- Howling on accellerate in rear
- Wipers sound like finger on a chalk board
- Tick, Tick Tick tick..........
- Lights inside radio
- 1989 Blazer remote oil filter help
- ::95 Blazer:: Question about factory alarm.
- 2000 Blazer starts and dies
- 1994 Blazer dashboard and instraments
- Blinking 2hi/4hi lights
- Power steering "sticks" in the morning when cold
- Noise in front end of 2000 blazer
- air sucking noise at high rpms
- power steering fluid exchange
- Temp Question
- 95 S10 Blazer Fuel Pump / relay
- 1999 Trailblazer 4x4 Actuator Problem
- Dome Light and Gate Ajar
- 95 blazer rear hatch button??
- NO HEAT ~ 1998 Blazer
- underbody coat, is it necessary?
- Blazer SS Pictures
- "degree" tool for head bolts etc
- Better gas mileage
- Elect Problem Radio, Cig lit, and hatch button
- hot air
- Gas Milage Question
- Body side Moldings starting to get ragged
- TCCM fuse....Where is it?
- 1995 Blazer hard start/Rough idle
- I figure id make a thread of bitching.everbody has to blow off steam bitch away!!
- Where is my......????
- 95 jimmy "W" distributor part #?
- Any difference in Blazer and Bravada?
- Weird idle / misfire
- K&N MAF Problem--awful mileage--Please Help!!
- 87 s10 blazer no start
- 96 blazer wont start in the cold
- let's try this again
- 95 Blazer ignition switch oddball torx screws
- -10 F carburated 2.8L, no choke
- The end of my Blazer hell.
- Looking for a cheap good 4L60E Tranny
- Started the tune up... holy crap...
- 4WD Problem
- front diff will not engage
- 93 Blazer S10, 4x4 box keeps Clicking?
- 95 Blazer accurate electrical schematic?
- Nerf Bars, havem? likem?
- stumped with 4.3 fuel injection...
- Where is my Fuel pump located on 1996 s10 blazer?
- New HID Retro
- More things to do!
- RLITH, Help!
- Which DVD Overhead console???
- 97 Blazer TCCM fuse...
- Heat...sort of...sometimes...
- Schematic Diagram (4L60e) Transmisson
- How much is too much?
- 4wd hi does not work
- Leaking coolant
- What's better off-road: '95 blazer vs. '92 Cherokee?
- Cold Air Intake mounting and heat shield
- Forum page randomly takes forever to load
- Hissing sound from HVAC
- Headlight and taillight removal?
- What gear am I in ~ (trans issue related)
- Always winterize before winter!!!!(I'm Back)
- most likly the stupidest question you ever heard...
- ::95 Blazer:: Changing to Synthetic I have a question bout the gunk engine cleaner
- Rattle at Low RPMs
- god help me, electrical problems
- 96 Blazer weird problems
- 1998 Blazer wont start
- Transmission Fluid... Whats the best???
- 4l60e 94 only 13 pins or 12 pins on plug????
- Need more info on Fuel Economy and General Maintenance list
- No heat to the feet 2001 Blazer
- 95 4x4
- no one has fixed this????
- another 4x4 problem
- Synthetic tranny & gear oil
- 89 blazer heater not working
- 1989 4x4 shift on the fly?
- Heater is a pain in the a$$. HELP!
- Holiday greetings thread
- Need Help Asap problem with new sterio
- heater core repacement, 1997 Blazer
- 2002 Blazer Dies When Stopping
- 2000 Blazer won't run
- 96 Blazer starting issue
- Do a search first Folks!
- 2000 4x4 problem
- Help! changed heater core, now won't turn over
- boiling from under my feet
- ::95 Blazer::Tranny Flush Advice
- 98 Blazer 4WD Issue
- 2000 ZR2 stuck in 4 Lo
- Advise on what brand, cap,rotor,wires
- Urgent!!!! P0300 Misfire, Rough Idle, Fuel Trim Error
- Fan clutch question
- help with body lift
- 98 chevy blazer
- 2002 Blazer - Thinking about buying
- P0410 - Secondary Air Injection System
- !999 Blazer 4x4
- Gp thunder 7500k bulbs
- 95 blazer fuel pump
- looking for Center console in 1st gens?
- ::95 Blazer:: Cooling system flush
- ::95 Blazer:: Whats this CPI i hear about??
- 94 S-10 Blazer grinding god aweful sound
- need help/
- Putting a newer style grill on a 96?
- Dashboard gauges dont work + car wont start
- gas smell, poor gas milage
- Ignition switch install problem
- Temp gauge fluctuation
- Emissions System Failure
- CPI Fuel Pressure regulator
- new seats?
- push bars...etc...
- Thermostat for a 99 blazer
- Useful calulation tool
- Dimmer swtich don't dim and int. light prob
- Interior Lights
- Replacing Headlight Bulb 2001 Blazer LT
- No HOT heat and fan roaring
- Ignition switch part number
- spark plugs and cap on 95 s10 blazer
- Another tint question
- What Brand Tires Do you Run On?
- Fun contest that we should try
- 1995 Transmission Power Purge
- 95 Blazer 4x4 hi not working
- 4x4 problems
- still having issues with 4X4 stuck in.
- hoppy hitch trailer wiring and spare tire lock
- Transmission filter
- Changing transmission filter
- 4wd clunk when engage and disengage
- 98+ blazer front conversion on a 95
- Need help!!!!!!! BLAZER NO START
- Do you TRUST your local chevy dealer!
- 98 blazer headlights flicker and brake lights out
- 99 S10 4x4 No reverse
- 1994 s-10 blazer won't downshift
- Switch to computer climate control.
- 31 X 1050 R15 !!!!! Oops !!!!!
- Antilock Braking System Video
- 95 Blazer 4x4
- Real Performance from a V6 Vortec!!
- Blazer is acting funny (but not funny at all)
- 1995 Blazer Questions
- 99 blazer -heater out
- 4x4 not working - Is dealer screwing me
- Blazer Burnouts!!
- my temp won't hit 160
- resistor size HELP!
- TPS circuit low input
- Somebody Please Help Me!!!!!!!!!!
- how to set timing on 95 4.3 W
- HVAC vents blow at different speeds
- My 4x4 is not working properly
- Climate control cycles from cold to hot repeatedly
- 96 Blazer ?
- Fuel pump voltage
- 96 S10 Blazer won't start
- 95 blazer runs and idles rough
- Differential, CV joint problem
- 4x4 auto 98 blazer will not shift into 3rd or 4th gear
- www.ecofuelsystems.com
- 95 blazer blown engine or not?
- Key In Switch Alert/elect Lock Problem
- tell me what you think of my wheel/tire combo?
- 1996 vacume lines
- First vehicle...?
- head & intake gasket question
- Winter driving in a Blazer
- 97 blazer 4x4
- Blazer audio
- 2000 Chev Blazer Lt
- '04 Insta-Trac transfer case
- 96 Blazer driver side door buzzer
- Fuel feed problem
- 2001 Blazer Wrecked Today
- ZR2 Package???
- Rear Windshield Washer Flood Nightmare.
- Question for BlazerLT
- Faq thread suggestions.
- Read First - FAQ & how to thread!!
- CATZ foglights
- Transmission
- PCV Catch Can
- man i am tryin to put dubs on my 02 blazer xtreme and having the hardest time!!!!!!
- transfer case switch and door
- How to park a car
- Service 4wd light
- Fog Lights
- Can't get fuel filter off of 1995 S10 Blazer
- Rear speakers (2 door Blazer)
- Fastest S-10 Blazer
- Replacing exhaust
- coolant radiator- mud-very thick-can i flush this out?
- 99 SLT 4x4 not engaged
- 1995 Chevy Blazer Fuel Pressure Schrader Valve
- How to Diagnose your fuel system problems
- The Clunk is back!!
- Dash Security light
- EVAP Problems/Done everything i could think of am open to Anything atm
- How did Y'all get your Blazers???
- MAP Sensor Cleaning
- Torsion bar
- Aftermarket Parts
- Just got my 1994 S/T Truck Service Manual...
- ongoing saga of emission testing tuneup mishaps
- i have gas in my oil
- 93 S-10 squeak/chirp
- Timing marks for 1994 4.3 Vortec?
- Rear rotors on 2001 blazer
- 87 / 88 S10 Chevy Blazer
- 94 S-10 Blazer Tahoe/Runs but dies...
- 98 Blazer gas line freeze or fuel pump?
- quick question
- Front End question
- 1990 S-10 4x4 not engaging
- Wireless Key fob
- Odd Dome Light Issue
- Can a bad battery cause ECM failure?
- 1999 Chev Blazer Hood release
- Car sometimes feels like it moves while sitting still
- How to remove bulbs in visors?
- Turn Signal Bulb Question.
- Blazer vs Hummer H3
- Need instructions for installing oil cooler lines
- wheels on my blazer
- cai and exhaust
- Gas tank / Gauge
- Neutral Safety switch/ Back up Light switch
- Key is stuck in ignition on a 96
- Check Gauges, Oil?
