View Full Version : Blazer
- number 2 randum missfire on 1988 blazer
- 1996 Blazer No Start
- interior lights
- alternator
- belt tensioner
- door and rear gate locks
- Sorry for bringing up old posts
- Oil, which one
- New Page Colors, WhooopEEEEEEE!!!
- Wow!!!!!!!!!!!
- Problem with Gauges On 96
- Ah.! Tranny Problems!
- 4WD stabilizer bar required or optional?
- Blazer Won't Start
- Trans fluid exchange again , and again, ...
- Brake light
- 95 boggs down on acceleration
- Trans fluid exchange again and again ...
- '96 Blazer inner front door panel removal
- Spark Plugs on a 98 Blazer
- dead battery ....ect! i dont know
- 86 blazer 2.8,tries to die when put in gear
- Need expert help on 95 vin "W" Blazer, I think its the CPI :(
- air vent removal
- blazer starting problems
- Transfer case making loud noise!!!!!!
- Blackout healight covers
- 4.3w poppet nozzle,Tryin to get to open
- Shock Opinions
- Sweet Deal/Trashed Rearend
- Need help on fuse 24 (97 Blazer)
- Rough Idle Engine Check Light On!
- engine swap
- Ride height
- Help!!! Suspension and brake Problems
- Want free horse power? REMOVE YOUR SUB BOX! LOL!
- draining the radiator
- Now its knocking!
- Shock Sensor Reset Button on 2001 Blazer
- How do I change the Alternator on 95 SLT
- 2000 chevy blazer - odd whine
- 4wd in reverse?
- Billstien Shocks
- Diver window stopped working suddenly
- Rainwater
- Pcv
- Pitman Arm problems
- Advice: Shocks/Tires
- ABS problem
- Which gear should I use
- gas leaking out exhaust pipes
- My New Front End Modification
- Tensioner squeaking
- Slipping into 4wd?
- 4WD Problems
- 95 blazer crank or knock sensor
- Another Turbonator?
- Buch of new parts!Ran 2 days.Won't start
- 1998 Blazer fuel pump stopped
- blazer power seat
- compass
- 2000 blazer heating problem
- Door handle rear hatch problem
- 4wd Problems
- 4-Wheel Drive Problems
- What do you think I should do?
- 91 Bravada anti-lock & brake lights ON
- How to remove Door Panel???
- bad hesitation/ slip
- timing 97 blazer 4.3
- More Tranny Questions
- 91 chevy blazer s-10 wont start
- HELP! Key Trouble
- HELP! Key Trouble
- 95 Blazer dies when turning right.
- Help finding a heavy-duty flexplate
- P1406 Code
- ABS problem info
- 97 Blazer won't start after intake gasket. timing? please help!
- automatic transmission removal 95 blazer?
- Filling up the Tank
- wheel hubs
- 95 Steering box adjustment
- key stuck in ignition and car wont shift in drive
- 96 Blazer Headlight Cycling
- need a new tranny for 2.4L vtec
- Just bought a blazer!!!!!
- Oil Filter, Which one?
- po418 Secondary air relay
- Coolant drip, drip
- Help Blazer just died no power
- noise when in 2wheel drive
- won't start now
- Body Kit
- Quitting
- HELP! with amp install
- 2001 Blazer shift stutter
- Would this be positive or negative?
- Heater/Defroster
- Code 45 ?
- I just received my $5000 Thousand Dollar Pay Back from General Motors Inc...
- 1989 4X4 4.3L rear main seal oil leak
- Engine Problem
- 1997 Blazer 4x4 Wipers acting up!
- Check Engine Light
- flashing interior dome lite and electric door lock problem
- 97 4.3 Vortec NoStart Challenge
- Will it ever end?? Engine interference-radio
- Need any help I can get...
- Vortec v6 W
- 2001 blazer 4.3l
- 98 Blazer 4x4 Rear Oil Seal
- Clunkity Clunk
- PO700 and PO715
- My Rear...
- rock hit my windshield
- Crack Oil Coolant Line -
- collapsed lifter
- Any of you guys in Connecticut?
- Code Reader question...
- Does anyone know how to test if the FPR is bad on a 95?
- 95 S10 Blazer will not start, I am totally stumped
- 1996 Blazer, poor acceleration, poor gas mileage
- If someone needs a replacement for their tired 2.8L
- biggest tire on stock rims?
- 4l60 Interchange, 95 S10 Blazer 4X4
- window sticker question
- Motor mounts
- Check your lugnuts after a rotation!
- I'm not stupid, just ignorant.
- 3rd brake light works but not the other 2
- Plug wires retaining clips
- lift up hatch
- Gas Leaking -$1010 to fix
- Have gas and spark but won't start
- More tranny problems hope u can help
- 4x4 problem on a blazer 96
- 4low issues
- Remote Keyless Entry
- 2001 front end conversion
- 98 blazer no start/name that sensor..
- rear windshield washer leaking
- Ok, time for a paint job!
- Ok guys rookie tranny questions
- Rear wiper trouble.
- I change my shocks last summer, now I hear squeaking noises
- skid plate swap intercabatly years
- Transfer Case and Differential Oil Change
- Wilma Flooded Blazer
- Clicking behonde the glove box???
- catalytic converter
- Brake Booster Line
- codes in glovebox
- seafoam
- rear axle seal
- Rear hatch glass wont open.
- a few questions about my 93 Blazer
- Starting Problems - Radio
- Side View Mirrors
- starting problems
- Where to start
- brake lights
- Damnit! Got conned into doing it...
- gas in oil
- Interesting smell..........
- 1997 fuel pump problems
- Pumpkin gasket question
- Need a quick answer! '96 Blazer LS Oil Leak
- 97 Rear Wiper - Assistance Needed
- 1997 blazer goes into 4 hi by itself
- coil
- Transmission Overflow, smoke, fire
- Advice on engine rebuild kits
- apologies for multiple threads!
- battery cable
- Blowing oil
- air injection system
- door panel removal
- RPMs surging at freeway speeds
- Ahhhh And the saga continues
- 1997 4.3 Vortec, short block
- 0-60 times for 95 4x4 blazer
- 1995 Blazer will not start! I need help!
- 93 blazer bog off the line
- Sirius Radio placement
- Often overlooked! Cause of a lot of problems!
- Engine or trans...?
- no crank, solenoid or relay or switch?
- blazer mirrors
- Heater Problem
- No fuel pressure 1994 4.3 s-10 Blazer
- reading codes
- ::95 Blazer:: Trans service Update
- engine just stopped
- 1994 Blazer 4X4 intermittent engaging
- Winshield washer tank leak (I think) ??
- How difficult should it be to.......
- Problems with Rear Window
- paint job
- How do I replace the FPR and the fuel injector on a 1999?
- 97 chevy s-10 blazer engines shuts off
- Catalytic Converter - Aftermarket Opinions
- Catalytic converter started rattling....
- Scantool for ABS?
- What do you all think?
- Sluggish Response
- 99 S-10 Blazer died-Oh woe is me
- fuel filler hose off tank
- 94' Blazer Temp Gauge Jumping Around
- blazer thermastat
- Constant vacuum to front differential actuator
- knock knock
- Whine - AC compressor
- question regarding 1995 ignition switch replacement
- Code PO351 again, now what..........
- Heater control
- Ignition timing question
- 95 s10 started fine but then went south
- 97 Blazer will not start!
- 95 blazer EGR
- electric rear view mirror
- Code P0507, no one can fix so far
- replacing starter on 4x4 99 s10 blazer
- 95 blazer 4x4 ABS issues
- Bad U-joints??
- help finding a fuel tank part
- No reverse update!!!!!!!!
- Welcome to the new Moderators
- Multiple probs, need advice
- 99 Blazer lots of problems, now it wont start. I have had enough of this truck!
- CD Player- 2002 Blazer
- Need Major Advice - intake gasket/valve lifters
- Cargo Cover
- Replacing a fuel filter on 98 Blazer
- 97 Blazer Thermostat Help and No Heat (Pics)
- 97 Blazer wont shif tout of park
- 97 s10 blazer
- Free Parts!!!
- 95 blazer wont start
- 98 Blazer MAF and MAP sensors
- Fuel pump quit
- something making a clicking/whiring noise..no fuel pressure
- 99 blazer 4wd will not shift back into 2hi
- 99 zr2 blazer
- 98 blazer crankshaft removal
- 96 Blazer Engine Knock PLEASE HELP
- Help Asap Help Won't Start 95 Blazer
- No Spark
- Bfg Land Terrain
- 95 running horrible again
