View Full Version : Blazer
- Service Engine light on but no codes are present
- 95 Blazer Start Problem
- Things and products that we should avoid!
- Brake rotors and more
- 4.3 High oil pressure - top end rattling
- 1997 heater core
- How much oil?
- Stupid Distributor...what garbage
- High Pitch Nois after Tune Up
- Comments on 03 ZR2 Blazer ?
- 98 Blazer pad/rotor combo
- Changing Column Shifter to Floor
- very squeeky brakes
- Fuel Economy problems
- Quick Question w/cool video!
- another coolant problem
- New Toys! 12's and Amp!
- Wiper blade size
- How can We help improve this board?
- 97 blazer 4*4 fuel pump trouble
- 93 s10 blazer hatch problem
- Help - 4wd convert to 2wd
- Instrument Cluster
- different questions idle speed & converter lock up
- Coolant leak behind AC compressor (98)
- AC causes rough idle
- Rear End Question
- Never know if it will start
- 95 4x4 tranny problems / questions
- Lens for the roof brake light--97
- Broken lock and back seat
- 2004 electrical problems
- 97 Blazer wiper circuit board
- trouble starting
- Wiring diagram
- O2 Sensors
- Removing fuel tank
- 1996 Blazer
- 94 Blazer will not idle .
- Fuel pump
- 1997 blazer 4 door interior parts needed
- Screwed Up Bumper *Pics*
- i smell gas!
- Idol's to high
- dont start cold without starting fluid
- Why do the other branches of this forum suck?
- Tune up
- Drivers side window wont roll up
- Hard Ride!
- 97 blazer gets no power anywhere.
- oil-over 75K
- New Brake problem-ABS Brake light
- 4WD Noise
- 94 blazer high idle 1500
- light bar
- WTF is with my tail lights
- Finally, Pictures of my 91 S-10 Blazer Tahoe
- Back Window
- Side moolding removal.
- Wierd Light Question
- Auto transfer case maintenance
- air dam on 95 chevy blazer
- Blazer Alarm System
- evap problem
- Replaceing a CV Axle, Help.
- red coolant inside my blazer
- Power Window Fix
- ABS wheel sensor 2000 4x4
- 1991 s-10 rear won't lock
- Odd problem
- lower intake gaskets 2000 Blazer
- 1991 s-10 blazer stalls one in a while
- Need to replace upper and lower ball joints
- Towing/Heavy Duty Packages
- K&N filter problem.
- fuel guage points to fuel
- Upper ball joints and center link needs replacement?
- Odd Sound
- Need Help with this no start
- Rear washer tube routing
- Gas Mileage Improvements
- Trying to Find a Specific Roof Bar ??
- How to remove antenna base?
- 97 Blazer goes click, click,click when I start it.
- Replacing "smog" pump
- blazer
- CPI nut kit question
- Anyone have a grill/brush guard on their blazer?
- Flickering dome light
- Airconditioning Problems
- 97 2wd 4.3 blazer
- Front rims hot to the touch
- I'm stuck in high gear,help!!!
- looking to buy a blazer
- Replaced oild lines - now a question
- 2000 Engine in a 1998?
- Trans Dipstick
- 94 Blazer starts, dies and starts later
- steering colum off after plug change?
- 2000 Blazer Gas Gauge Fluctuations
- WHERE? remote wire for amp in a 2003
- wires behind dashbord
- 2004 Blazer won't start
- Problem After Installing SilverStar Headlights
- 89 Blazer Wouldn't Start Now Running Rich
- 2001 Blazer Power lock and rear hatch problem!
- Question about Jet Chip
- P0303 Engine Shut down, Won't Start
- 97 blazer starts then stops, new fuel pump, new problem
- New Addition to the Blazer Family.
- 20' rim's good or bad ????
- 4WD Vacuum Actuator question
- O2 3, bank 1-97blazer
- Govenor driven gear assembly
- electrical problem please help!!!
- Bad Gas Tank Gaskets
- INT. Lights stay on Fix
- Catalytic Converter????
- Still here a vibration or knocking noise..
- 1994 blazer engine miss
- Smoke from Blower Control Switch
- Anyone have a 97 RearEnd
- How To Tank And Fuel Pump
- down shift
- backfire sound
- my fuel gauge is going nuts!!!!!!!
- Beginning of the end, or end of the beginning?!?!
- Opinion..Everybody Read
- Key Fob Progaming - 01 Blazer - Need Help...
- HELP !!! Oil change from Hell
- lowering kit
- How do you clean your MAF sensor?
- Shocks of choice?
- Any Help Please?
- Cat for California Emissions.....ouch!!!
- 97 Blazer Heater
- What to do with rad flush waste?
- 97 blazer died...HELP!!!
- 87 2.8 with loud knock
- Replacing Spring Leafs after 10 Years....
- Bad Response
- scangauge in 95 OBDII
- Wanting to add a new exhaust to a 1991 Blazer
- 94 s10 phantom problem
- '96 GMC Sonoma/S-10 for trade
- 89 Blazer, break light in dash flashing
- Cccc
- Flavors of CPI?
- 93 blazer throttle body surge problems
- shift delay
- Need a replacement 4.3 Vortec
- One more Problem (no Heat)
- Post what mishaps your 4.3L has endured....
- How Many Miles Does Your 4.3 Have
- Pulsing headlights?
- Where do you buy your parts at?
- Exhaust Fitment
- 1987 K5 blazer 350 TBI Misses after warmup
- '89 S-10 that skips/misses
- 97, 4.3 ECM Problems - Maybe?
- Stupid!stupid!stupid!!stupid!!!stupid!!!
- Abs Light Stays On
- Leaking Rear Trans Seal
- shocks and springs
- 99 Jimmy ... rough rider
- Fram Products
- Want to Blow you Transmission? Don't replace your rad....
- where is blazerLT?
- Cleaner Lights...Buld help
- electric fan conversion
- 2001 blazerspeedometer-abs
- Gas Gauge issues
- Exhaust and intake?
- So had to replace rear brakes today
- 96 blazer whining
- How to remove window panel from 1997 chevy blazer
- Anyone have the TSB for the Transmission PCM ground update?
- Engine over-revving until it shifts into 3rd gear then its back to normal
- Brake lights driver side only
- Replaced Front Diff. 2000 Blazer 4X4
- Rattle Under Hood?
- A little better gas milage, maybe.
- 350 in 85-87 blazer
- sticky lifters or blown rod/bearing
- Finally passed my California smog
- Dynomax Catback exhaust a total letdown
- HERENDISS noise
- Fan clutch question
- Humming from engine
- Speaker Sizes?
- 89 S10 Blazer Brake Problem
- Spark Plugs
- Theft code hacks on a salvage yard CD
- Any Help Will Be Appreciated...
- Autozone Oil special
- Trenz - Billet Dash Overlay
- steering pulls to the right
- Wheezing sound behind dash on a '98 Blazer
- Transfer Case Driver side Seal leaking
- short circuit
- Heater Motor
- Steering Gear Box "Sloppy"
- Keys stuck in ignition wont turn anywhere.
- 97 Blazer Loose Heat, Temp guage...
- knock
- Intake Questions
- Sticky Lifter??
- Droppin The Ol' Tranny
- PLZ help me.....
- 1995 blazer something's wrong
- Can a converions kit ????
- roof rack removal
- Heater Blower
- Oil question
- Knock
- Brand New Owner of a 1991 S10-Blazer 4X4
- Posi Lock questions
- 96 blazer.....wont turn over
- 95 blazer runs great on the highway but wont idle for jack
- 98 Blazer - Please help!
- Tornado Air Management
- Recall Info
- won't start without starting fluid!
- 96 blazer engine replacement
- Help needed quickly
- 4wd Possible Quick Fix?
- 2001 Blazer won't start sometimes
- K&N Cold Air Intake
- 96 Blazer Fuel Pump Connectors
- Intake Question
- Service Engine Soon
- New Blazer owner - a few questions
- 96 Blazer Dead Battery All new
- opinions
- car rolls while in park!!!
- Auto e-mail reply works again....
- 2000 Blazer 4wd. Opinions?
- cranks wont start
- It wont open
- Engine Family
- 95 Blazer keyless entry
- Ordering Spare Key
- 2 large problems
- New Carpet
- Hey Wolfox! Did you ever...
- power seat, wiper fluid pump, relays???
- suddenly rough idle
- fuel pump
- 97 Blazer
- Severe Stalling Problem
