View Full Version : Blazer
- I got a little problem.
- A/C condensor
- 91 s10. AC keeps blowing fuses.
- problem
- Clunk when I turn all the way to the left
- Spark Knock
- transmission problem
- squeak in reverse!
- 99 blazer air conditioner cold air only after driving for awhile
- Blue / White smoke at startup
- Hard Starts on 02
- brake booster
- brake trouble
- 95 vortec ecm fuse
- Transmission Problems**Please Help
- How to test if 4x4 works
- crackling sound under car
- Inop. Power Mirror Function
- Frozen rear brake drum
- Cannot screw Dist cap to Dist
- 97 blazer and 4wheel drive not engaging
- 89 Full Size Blazer 'Ghosts'
- '95 #3 cylynder misfire
- RPMs
- Numerous upcoming projects, so numerous questions
- Fuel Spark No Start
- transmission no reverse
- side mirror covers dont fit ....help
- Need torsion key help
- 95 Blazer Oil Pressure Gauage
- odd knock
- Hello, Everybody. Truck Shakes When I apply the brakes at 65-75mph.
- How to replace a fuel pump for a 98 blazer
- 97 Blazer with code P0300
- Outside temp display and AC
- Odbii P0101?
- a/c, heater control problem
- 96 A/C Problems
- air compressor kicks on and off
- Driving lights
- 89 blazer transmisions? help wich one?
- transfer case fluid change
- 2002 Blazer Starter replacement
- BIZZARO Front differential leak
- 89 4.3 4wd tbi, oil gauge maxes out.
- Air bag question?
- Third Brake Light
- Leaking washer fluid?
- The Official Projects of the month! (for the month of July)
- How Much Is The Avg. Price For A Good Tranny Rebuild?
- Neutral safety switch??
- Rear end squeak
- distributor cap o5 Blazer?
- Bosch?
- 95 4.3L CPI distributor clamp bolt...!?!? $%$#!
- a/c & tune up questions
- Electrical Problem
- No fuel pressure
- starting '90
- getting harder to start-wtf?
- Transfer Case Switch Light
- Grumpy new Pro Comp 31/10.50 owner
- squeeky brakes..again
- 2000 Blazer Fuel Pressure
- HVAC Solenoid
- Transmission Fluid Level
- Blow'n dash fuse
- Emergency help needed:
- Update to Envoy Center console
- Fuel Filter Problem
- Loud tapping in motor...??? 2000 Blazer
- Recall Alert!!! Fuel Filters....
- ::1995 Blazer LT:: Squishy Brake Pedal...
- ::1995 Blazer LT:: Purge Selonoid HELP!..
- '95 clicking noise from alternator?
- 95 S-10 Blazer engine replacement
- some probs
- Shift light - Engine cuts out
- starter problem?
- Good Floor Jack
- 2000 Chevy Blazer starting Problems
- looking for an custom billet grill for 89 s-10 blaazer
- 2002 Blazer ~ rear window problem
- Smoke screen out my tail pipe... ('95 4.3L 4X4)
- 98 blazer odd trouble codes
- fuel pump
- sticking key in 97 Blazer
- Air Box Mod
- CPI trouble
- Went to Mechanic.. couple Q's
- New devloped tap
- Chirping/Whistling sound noticeable at low speeds
- TCCM - Aftermarket availability?
- Blower/Fan problem. It won't turn off....
- The French forun member has trouble with Overhead Console......
- 89 s-10 blazer no fuel
- Actron Live Data-translation?
- Pro comp Or Mickey thompson's
- Instrument Cluster Info
- 4-door ZR-2's exist?
- Vacuum motor leak
- Gabriel Pro Guard shocks?
- Exhaust bolts
- Exhaust bolts
- Carbon in EGR Valve
- Towing with 2003, 2dr Blazer
- Quick question on shock replacement
- rollpan question
- Exhaust leak?
- Aftermarket fog lights
- installing glow gauges?
- 4wd service light
- Check out this 95
- 97 blazer a/c v6 Vortec
- Suspension help...
- a/c not working
- Flowmaster
- 01' Tranny Prob? Rare jolt on highway
- Which ball joints to choose?
- Turn Signal Two Speeds
- Overhead console compass/ temp. sensor
- rough idle (EGR?)
- No AC/Heater control
- 95 blazer wont start
- Reminder, Check your cooling system!
- Name my Diesel Blazer Project
- Hows your interior sound?
- 01 gas gauge
- propane fuel
- 8,000 Thread!!
- Rear wheel hop ?
- What else do i need to do?
- Reusable oil filter
- What Size Filter
- Coming Home
- the ride quality thread
- Dorman Oil Cooler Lines
- Need help with installing tailgate tension bar
- 95 4.3 timing
- Yaaaaaaaaaaahooooooooooo!!!!
- Ebay Torsion Key's good or bad
- still over fueling
- Debating on next mods.
- cleaning the MAF sensor
- 96 Chevy Blazer LT
- LOc Display on CD Player
- Its Leaking But Dunno Where From
- question
- Transfer Case
- Keyless Entry on 97 Blazer
- newbie (to blazers) lookin' to get one
- need help
- Rattling like a tin can
- My 1999 LS So Far
- RH outside mirror - light sensing??
- Problem on Passenger side floorboard
- Granatelli Mass Air Flow Sensor
- Door Retainer Clips
- remote control
- Faking Thieves...Part 2. AKA A woodsy adventure
- rain causing sluggish behavior
- Radiator Cap
- This is really bad, and i really need help..cv-axle is dis-connected.
- NO Turn signals/back up lights
- popping sound in front door?
- Four wheel drive button not working correct
- Welcome to the new Advisors.
- haha foolish me? i solved the rough idle problem!
- Updated Community Guidlelines. Must read.
- I know I will get help here!!!
- German Castrol 0w-30?
- 1997 Blazer 4.3 Running Rich
- Upper Control Arm Bushings
- Opinions for audio
- You think changing plugs are bad, try the fuel pump....
- Front end ball joints
- Deal?
- 4wd problems loud noise
- 305CI need muffler help!!! by 2pm Eastern time today!!!
- compass\temp reset
- Ok problem
- MY god I hate changing plugs on my 4.3L!!!!
- Transmission hard shifting
- noisey cold start
- EGR Duty Cycle and O2 Sensor Failure
- How to disconnect ABS system??
- General info
- climate fan sometimes will not run
- This v6 is crazy!! He runs 9's!!
- 91 S15 Jimmy Check Gages Light when stopping
- computer problems
- Intake Gaskets..now Gurgle Gurgle
- Mother load of Brake information!!
- Opinions welcome...
- Steering problems
- rear end gear interchangeably years?
- bad fuel pump?
- Bypas Air Conditioner
- 97 Blazer 4x4 tune up
- stop rust
- Keyless entry on 2002 blazer
- Misfires
- spark plug gapping
- 98 Blazer brake issue while bleeding
- axel swap/brakes qustions
- 97 blazer tranny codes
- Pulsing Brakes
- 2002 Blazer Rear Brake Pads
- Lack of braking power
- Headlights will not turn off
- Do you hear a whirring noise when in 4x4? Please post.
- gauge light problem......electrical issue??
- 91 Blazer map sensor
- Window Help
- Front Brake Pads
- Jiffy Lube Comments
- How much difference in front end on blazer and bravada?
- 98 Blazer Air Conditioner Problems
- And it begins
- 1992 Blazer S10 tailgate locked with window closed
- Stupid ignition problem
- New Ball joints.New sound ARG!
- '98 blazer tune up
- 98 Blazer slight vibration/noise during turns
- Undercoating on the frame rails.
- Lil help needed with no start
- transmission noise????
- New Brake Pads rattling...Solution?
- suggestions on paint colors
- Stupid Question??..??
- Left rear lower than the rest.
- '88 S-10 Blazer Clicking
- blazer caliper bolt size
- what kind of power chip?? 1st gen
- 97 Blazer LS Trailer Harness
- relay ? multi-function? DRLamps?
- 96 blazer 4wd ball joints
- Should I replace my engine?
- Does and donts
- Average fuel mileage on blazer 4x4
- '97 Blazer - electrical issues?
- need help with audio
- 4.3 vortec compatibility
- 1999 Blazer 4WD problems
- non power brake wire
- '99 Blazer Misfiring P0410, P0300, P0172, P0174
- Steering wheel vibrating
- A/C R-135a refrigerant fill up
- Rust Remover Wow
- Clicking Relay in 2000 Blazer?
