View Full Version : Blazer
- checking for pluse and 12V power to fuelinjector
- Vacuum port (?) on '97 AWD Transfer Case
- starting problem 94 S-10 Blazer
- Starting Problems - 1994 s10 Blazer
- 2000 blazer electric schematic
- need new rear????
- 1984 CUCV tailgate
- keysless entry not working
- cylinder head swapping
- Transfer Case Motor Removal-98 Blazer
- Fuel Pulsator Valve
- A/C Question !!!
- 2.8 to 3.8 conversion ?
- does 4x4 work????
- fuel filter
- fuel filter
- Fuel Pump
- Squeeky grinding sound need some help
- 99 Blazer LT 4x4 transfer case switch
- skid plate works on a non off road package
- Ravin Z55 muffler (Needed)
- Does Anyone Have Access To Schematics?
- 98 Blazer-Will not go into 4wd Low
- Coolant drips from edge of plastic intake manifold
- engine replaced
- Bad idler arm
- Need some help with my 4.3
- Please help, 2000 Jimmy, rear end prob.
- 2002 S-10 Blazer Fuel Pressure Regulator
- 2001 Blazer with no fuel
- Quick questiourn
- Replacing flywheel/flexplate
- Stumbling Start
- 1995 blazer engine swap problems
- Anyone got an opinion about this
- Lets drop the insults folks
- Finally got the fuel pump done
- Blazer shuts off sudden while running
- EVAP Hose Issue
- No Power !!
- lift kits for blazer
- HELP!! 1995 s-10 Blazer 4.3 Vortec won't start in morning.
- Wiper Problems
- will idle but stalls when you push gas
- hmmm.. my women said theres high oil pressure..
- 98 s-10 balzer speed sensor
- Rough idol and engine missing
- Troubleshooting front left squeal--not brakes...
- Safe Jack Stand Usage
- just a curiouse break question
- Brake Bleeding
- The clunk is revealed
- P1345 - 1998 Blazer
- Blazer LT loose parts & tranny questions
- instrument cluster: flashing indicator lights and bouncing needles
- 95 Blazer Flasher/hazzard Relay Location
- tow ratings
- locked out of 01 blazer
- 96 chevy blazer stalls
- '85 Blazer 2.8 to 3.4 Conversion Question
- PCV Valve Location
- lifter noise
- Anyone remember what chemicals was used to refinish the plastics/area around windows
- CO2 Leaking into the drivers compartment
- removing knock sensor
- flashing battery light
- Its the fuel pump!
- Anywhere to get used parts online?
- Correct IAC valve wiring
- Lift kits
- 96 Blazer 4 door comlete rebuild, is this even posible?
- 1990 K5 Blazer 4x4 steering!!!
- Borla Muffler Question
- Catalytic Converter- Where to get one?
- Help: 99' A/c Compressor Freon Fill Tips
- 2005 Blazer Stereo Question's
- manifold leak?
- 97 Blazer LT
- head lights
- U joints
- Transmission Fluid Tube Replacement
- 95 Blazer 4x4 turn signal failure
- ABS and Rear Wiper system gone haywire!!
- I know this has already been posted but...
- 98 Blazer SIR airbag light
- 99' Balzer Rough Idles
- 97 Blazer No dash lights, and wont start. Please Help
- 95 Blazer Fuel Pump
- How difficult is it to replace the intake manifold gaskets?
- Oil Cooler/Filter Line Replacement Tips
- 90' k5 4x4 full-size 2 ?s please read!!
- Distributor Cap Mount Cracked?
- 2000 chevy blazer 2dr 4x4
- Do's and Dont's To Your 4.3 Vortec
- lift kits?!
- P0101 - Can Someone Help Me With This?
- who own a full size blazer
- It got me again, ABS and Speedometer this time
- Cap and Rotor
- Turn Signal won't shut off.
- harmonic balancer help
- P0440 Service Engine Soon... What now???
- 1995 S-10 Blazer-Dome/Courtesy lights do not cut off
- fast idle?
- Trans Service/Major Trans issues follow
- Need Help! Upper Intake Manifold
- Advice on changing multifunction switch
- Fluid Temp
- all kinds of noises in the front end.
- K&N FIPK GenII review
- Brake Problem Please Help!!!
- transmission leak (correction COOLANT LEAK) photo...anyone got any idea?
- Wheel bearing or CV?
- What is this ?
- Gonna drop the tank. need to buy right jack.
- automatic transmission shifter
- Stock Radio Problem
- TPS recalibration
- 2001 Blazer new plugs & wires?!
- EGR Valve Gasket !!
- Anyone put on an aftermarket transmission pan 96 2dr 4x4
- Is MT-2500 still here?
- 92 s10 cuts out while driving
- 96 Blazer Mirror Problem..
- 97 Blazer Stalling while driving ???????Help
- SES light burnt out
- Another BALL JOINTS/IDLER ARM/PITMAN ARM
- 91 brake pedal sinks to floor
- idle problem when A/C or defrost is on
- 100,000 Mile Tune Up
- blinkers not blinking
- Need help identifing Fuel pump
- another squeeky belt
- Whats the cost?
- Misfire at 1500rpm after highway drive
- 4 low switch stuck on
- 96 S-10 no start
- speedometer acting up
- what and were is the MAF sensor
- white face gauges
- Popping sound when I take off from a light and stop
- common problems 2000 blazer
- 1996 White Gauge Bezel Buying Help..
- Wiring Gurus I NEED YOUR HELP
- 00' blazer 4WD problems
- 91 Chevy Blazer S10 - OIL FILTER Replacement Issues
- Which is the better choice? Replace or repair?
- Things and products we should use.
- Electric problems with my 1997 chevy blazer.... ignition switch?
- 94 shows its hot
- Where is the Idle Air Control Valve?
- Awesome First Gen in Action
- need to replace shocks...not sure what I need
- Something to ponder
- Moog T-BAR mounts
- Uh Oh!!!!!!!!!!
- Ball Joint Press
- Clunk when disengageing 4 wheel drive
- 1995 Blazer MAF/O2 sensor/EGR valve problems
- brake pad/rotor combo
- knocking in the heater
- Engine sputters over 3000 rpm
- The Official Blazer Forum Off Topic Thread Part 2
- noob here.. Few Questions..
- 1998 Blazer there is "NO SPARK"
- removing 97 blazer fuel pump relay
- 94 blazer door latch won't open
- Is my Transfer Case shot? 02 Blazer...
- replacing ball joints, having difficulty
- Check your plastic hood on your TBI for clunking
- 4l60e shift solenoid
- What is wrong?
- Motor swap, What year motor and tranny will fit? 96 blazer
- White scratches in paint.
- Brake pad question
- Front Door Panel Removal on 97'
- tips to improve ride quality?
- creaks, squeaks, etc....what ALL should I lube?
- Hood Wont Open
- Operating Oil PSI
- cleaned the throttle body, now truck won't start..
- Tranny slippage?
- 95 Blazer Owners Manual
- Can't find my color code sticker
- Body lift kit
- Speaker Problem? MY rear speakers and front left door speaker do not work?
- Missing/sputtering during accerleration
- Can it be the EGR???
- Lubrication??
- 95 Blazer AWD????
- Grinding Noise Under Dash
- purge flow fault code...not a gas cap..
- lowering the blazer 4x4
- Installed a new muffler
- hole by tanny
- EGR Valve !!!!
- antifreeze
- Hesitation, staggering on acceleration and poor gas mileage.
- 97 blazer 4x4 Hi issue
- tranny gasket/oil pan gasket
- '94 Torque Converter Lock-up
- Rip
- Coolant pouring out of the back of the motor
- front drive shaft
- New Radiator Help
- So Long, Goodbye!!
- chevy blazer s10 fenders
- remote oil cooler/filter lines (need a quick reply)
- Brake Fluid colors
- 1997 Blazer - Coolant Leak?
- Jet Performance Module Warning
- Got loose steering?
- Fog Lights
- Brake Fluid
- torsion bar stuck!! help?
- Replaced intake gasket
- History of the S10 Blazer........
- Service Engine light on but no codes are present
- 95 Blazer Start Problem
- Things and products that we should avoid!
- Brake rotors and more
- 4.3 High oil pressure - top end rattling
- 1997 heater core
- How much oil?
- Stupid Distributor...what garbage
- High Pitch Nois after Tune Up
- Comments on 03 ZR2 Blazer ?
- 98 Blazer pad/rotor combo
- Changing Column Shifter to Floor
- very squeeky brakes
- Fuel Economy problems
- Quick Question w/cool video!
- another coolant problem
- New Toys! 12's and Amp!
- Wiper blade size
- How can We help improve this board?
- 97 blazer 4*4 fuel pump trouble
- 93 s10 blazer hatch problem
- Help - 4wd convert to 2wd
- Instrument Cluster
- different questions idle speed & converter lock up
- Coolant leak behind AC compressor (98)
- AC causes rough idle
- Rear End Question
- Never know if it will start
- 95 4x4 tranny problems / questions
- Lens for the roof brake light--97
- Broken lock and back seat
- 2004 electrical problems
- 97 Blazer wiper circuit board
