View Full Version : Blazer
- Finally, pictures of my Blazer.
- Installing driving lights – 99 LS
- AC not to cold..sucks!
- Gas saving, and power
- Thermostat 160, 180, or 190
- 98 speedometer questions
- Tranny Pan
- Lifting my blazer, how much offset?(already searched)
- Stero/lift questions would love some help! 1989 S10 Blazer
- Oil Questions
- just a dumb question.
- Vette Servo in '02 Xtreme
- ABS Light on and Bad Shifting Trans
- click clicking sound noise
- 96 Blazer need to remove the top cover on the steering column
- Master Cylinder swap?
- blazer pulls to the right
- Cam sensor help
- 95 s-10 blazer engine whine
- Ignition Question
- 1990 S10 Blazer electric problem??
- Need Help 94 Blazer Struck By Lightning
- EGR Block Off
- 80 + oil pressure on 89 s10 blazer 4.3
- 93 Blazer/Jimmy 4wd problem
- Center console parts?
- From Russia with love
- 89 back speaker wire placement
- Trans fluid gasket filter pan
- 1996 Blazer Dash lightbulb goes on and off...
- 95 blazer spent more than its worth
- Whats your stand?
- 87 s 10 blazer tranny swap?
- steering column disassembly
- Opinions please...
- Rear axle repair bearing kit
- Correct idle speed
- fender replacement
- 98 Blazer 4WD Engages while stopped but not while on the fly
- motor mount or tranny?
- Brush Guard
- '98 Blazer 4x4 "BANG" on disengagement.
- Broken vacuum line from vacuum switch to vacuum ball
- First the reverse lights and flashers, now the turn signals?!?
- 96 chevy blazer keyless entry
- I can hear fluid running in the tranny!
- Ignition switch 76 Blazer
- Engine or Starter?
- Hotshot Mod..... Part Deux...
- Supercharger
- Is this what it looks like?
- tire torque lbs
- Squealing!
- wiper arm removal
- Terrible Ride
- Door Switch Access?
- Insturment Panel switch question?
- What's causing sound/vibration
- Oil Plug Oddity
- fuel pump
- vac leak?
- OMG its smoke
- *Info about P1870 (TSB)*
- Delayed Starting (already searched)
- 98 keyless entry problem! Please help!!!
- Air Conditioner almost makes truck die!!
- 89 Axles
- Overheating & RUFF Idle
- Digital dash problems
- 93 chevy blazer Fuel pump problems
- Biggest Tires???
- Squirrly Rants
- torque converter???
- Weird Occurrence with vents
- Mismatched Engine Crankshaft
- Cooling System Trouble
- FOG LAMPS & TOW HOOKS ?
- What looks/works best
- few problems with 95 blazer.
- 89 1500 blazer audio wiring problem
- 99 4.3 4x4 won't go into 4wd any
- I changed my Positive Battery Harness
- 2000 Blazer Fuel Gauge Sending Unit ?
- Alright. Know the issue. Need to find the culprit
- 2003 blazer gas mileage/transmission?
- exhaust leak
- 99 4.3L 4x4
- 2000 S-10 Blazer Cam position sensor lost.
- front end play
- Rainy days... unbelievable Mechanic Flub!
- 1969 blazer doors
- The Chrome
- Best Muffler
- Pictures of new Blazer Replacement
- air bag fuse
- Speed Traps
- 2000 Jimmy SLE Pos Battery Cable
- Child Anchors (Latch)
- air bag fuse
- Help(newbie)
- Another keyless entry problem. HELP!!!!!
- fuel filter
- put my truck in the drink, need help pls!!!
- mystery vacuum hose
- 95 chevy s-10 Blazer
- 96 Blazer Miss Found problem
- Stalling issue- Driving me crazy
- 4 wheel Disk Brakes
- Bashing Fram
- 1998 4.3L 4WD - Replace Water Pump
- Introduction
- Electric Fan VSS?
- Dash Bezel
- 92 Blazer, oil smells like gas
- Chevy Blazer Keyless Entry (1996)
- '98 Blazer rear brake pads don't last long
- 1998 Blazer...No Start/Hard Start
- '98 W/ TBI got new fuel pump, ran for a day and croaked (done did the searches)
- 94 blazer 4.3 4x4 starts after a whille??
- changing out spark plugs...
- Got a new problem! (vents)
- thoughts? preventive engine care?
- 1997 Blazer Surging Forward
- New rattling AC compressor
- 97 Blazer electrical events
- Riddle me this!
- Fender skirt? removal
- Tire Size
- Cpi
- timing chain or CPI?
- Alarm question
- 2001 Blazer A/C cold is off and on
- 4L60-e Transmission Shifting Problem
- blower motor doesn't work properly
- transmission shifts from 2nd to 3rd hard
- 96 Blazer Bad idle
- New O2 sensors and still P0133 Error
- Air Conditioning Re-charge
- Removing Starter
- 93 vortec surges
- Ignition Wire Clips
- alternator
- Installing new Gauges on a '00 Blazer
- Dash removal
- leaf spring u-bolt lift kit
- New 96 owner 4wd question
- How long does the blazer keep a code?
- rear window alignment
- 4 WD stuck in Low range HELP!
- Need 95 Blazer Help Please..
- 305 tbi into s10 blazer
- 96 2dr 4x4 recommend ujoint brand & #
- Spare Tire Carrier Handle
- 95 Blazer 4.3 Won't Start
- WARNING: Delco Battery Failure, Risk of Fire/Explosion
- Help with Air!
- New Serpentine Belt Material
- Belt squeels for a few seconds
- leaking transmission
- New Coolant leak after servicing...hmmm
- Rear Hatch and trouble starting after running awhile
- Computer Won't Read Out Codes
- Having trouble with a MIS-leading gas gauge?
- Reverse to drive: Grinding, winding -then clunk
- 31 Inch Tires
- 95-97 power mirrors to 98+ power heated mirrors
- 96 infrequent stalling
- 95 Blazer 4.3 won't start
- Torsion bar isolator mounts?
- Won't Start or shift from Park
- 95 Blazer sometimes won't start
- Passlock problem
- ravin exhaust legal question
- Bridgestone Duellers A/T
- Couple of Pics
- P0753 SES Code and Fuel Gauge Trouble
- 1995 blazer problems with brakes
- 94 blazer wont start
- Weird starting pattern (already tried search)
- Altenator Voltage Drop
- Low craftsmanship...
- 91 Blazer transmission looses all gears, rebuilt tranny
- Best place to buy aftermarket stuff
- 97' S-10 ZR2 4x4 prob.
- 97 Blazer AC question
- 95 s-10 Blazer Cruise Control Turned on by itself?
- Synthetic oil... Who runs it?
- New owner 2002 Blazer...
- Catalytic / Oxygen Sensor Modification
- Fuel Filter Location? HELP !!!
- ABS or brake pads?
- Exhaust question
- A new type over overhead Console <evil grin>
- Oil Pressure switch?
- hazards dont work & lock are messed up
- AC trouble 79 blazer
- Blower motor
- Tran Shift Problems
- 97 Blazer engine probs
- 98 Blazer check engine light on AGAIN!!
- 97 Blazer P0175 code
- Should I buy it?
- 94' Blazer a/c heater blower problem
- reversed the battery cables and something started smoking!!!
- stuck dip stick
- fuel injector--check engine light
- Blend door motor
- ANOTHER AC problem!
- 1999 chevy blazer no fuel
- Strange Air Conditioning Problem
- blazer quits after warming up
- 98 Blazer Ping Problem
- Vaccum line size
- did auto-rx work for you?
- 99 Blazer Spark Plugs
- Car stalls out.
- Transmission surging problems?
- 1987 k5 Blazer rear window goes down but not up without pushing on door?
- 99 Blazer LS 4X4 Problem
- Starter Issues
- 97 Blazer Transmission Issues
- what is this thing near the master cylinder????
- Worth It?
- 2000 Blazer A/C Cooling Problem
- rear end
- Service 4WD light comes on ..
- slight shutter between 900-1300rpms
- Blazer front end humming (not bearings)
- water in dashboard
- used sheet metal
- '96 Blazer Electrical Problems??
- Radiator
- Liftgate won't open- '99 Blazer
- 98-01 interior door panels fit a 96?
- Dead Battery; battery indicator light on...
- Burnt/Black tranny fluid...
- body drop
- Head swap? "Z" vin to "W" vin?
- dropping
- power band
- Front end differential
- fuel smell after acceleration
- 98 fuel pump test lead??
- instrument cluster problems
- repainting
- Help with 02 stock CD player
- Noise when decellerating
