View Full Version : Blazer
- tailgate window ket switch
- 4x4 Problem - Partially Disengaged
- New Brakes all around...caliper stuck
- 96 Blazer, no start
- Backwards muffler by meineke
- Speaker like object in headliner
- Ignition switch Problems???
- Dead instrument panel, ignition key stuck.
- Codes
- 93 blazer cpi question
- Guy's I know this is the Blazer forum, but you guys know what your talking about...
- Under the hood.
- wiping the rain away
- A question about this board
- 98 blazer transmission problem
- Rear Shock Mount
- "95" ALDL Connector OBD2
- Cant Remove Key
- Heater Core Was Whistling?..not Dixie though
- Anyone using EBC 6000 series green pads
- blazer
- 93 blazer vortec Hot start issues, rough idle, stalling
- Is my CPI going bad
- did dealership mess up my truck?
- 95 Blazer now windows stop working.
- simple question
- Jet Plane Noise While Driving
- Trouble logging on???
- Just more problems.
- ravin muffler
- Whoa!!! No Brakes!! Watch out!!
- Fuel Lines
- Rpm Question Crusing 70 Mph
- 30 Minutes to Install. Now need help!
- A/C blower and funny diode
- '95 S-10 Blazer Blue Smoke
- 94 s10 blazer kicking in and out of overdrive
- malfunction in vss 1990
- Help Asap
- have a oil leak problem on a 1985 balzer 2.8L
- Wierd Clicks and no interior function
- My '95 S-10 Blazer
- windshield wiper fluid pump
- short in 1998 s-10 blazer
- Shock question
- thinkin' bout wrappin' my Jimmy ...
- if you can help
- Cool Site for Parts....
- Coolant temp not registering on gauge.
- The elusive door sping tool
- cut the top off
- timing 42 degrees retarded exhaust gets red hot
- WEEEEE Another Tire Thread WEEEEEEE
- rear end
- Gas Guage is messed up, Float?
- Headlights Projector Halo's Any Good?
- My Complete Tune Up....
- question on P0103 code
- Looking to buy a 1994 Blazer-Transmition ?
- 4L60-E teardown
- 1978 Blazer problem, (long)
- waterpump installation question (gaskets)
- 4.3 spark plugs..25 & 26
- Blazer Hatch
- Distributer issues
- weird 4wd problem
- blazer transfer case keeps slipping into neutral
- 1998 tranny
- How important is it to change your Automatic Trans Fluid?
- What are Caps & Rotors?
- 95 blazer missing and rpm tack jumping
- 92 S-10 Blazer high idle
- Anyone have bad seals on ...
- Fuel Pump Issues?
- Blazer 96 starts and dies then does start
- 2000 Blazer Wire Colors
- What is a coolent temperature sender???
- CPI Injector assem. does the brand matter?
- Easiest way to replace Spark Plugs for 1995 Blazer LT 4x4 4Dr
- Back Hatch Doors Shock Lifters need to be replaced on 96LS4x42DR.
- Replacing the oil cooler lines to fix oil drips...
- Humming in the front end....hmmmmm
- fender flares..
- Sagging rear springs....
- 1995 Blazer Dripping Oil...I think from...
- do I have an orifice ??!!
- Ideas on value of 1994 Chevy S10 Blazer 4x4 with 4.3 CPI
- Help my truck with it's squeaking problem
- 4x4 Not working
- Derm Module
- Disable alarm but keep keyless entry?
- Borla Exhaust deal, but will it fit?
- 1995 Blazer LT 4door 4x4 with Cellular One phone package...REMOVING
- Drips? Drips? and more Drips?
- My electical gremlin is back!!
- 2002 Blazer Vacuum Tank Replacement
- Cold Air Intake [suggestions?]
- Cheap lift but will it work?
- Guess What I Am Doing Tomorrow!?!?!
- Plastic POS Bumper
- no start 91 blazer
- '93 s-10 starter removal?
- Anyone Know A Cool Website To Purchase Aftermarket 1995 Blazer Body kits, Lights etc.
- Power Seat, Mirrors Dont work Help!?
- 97 balzer code 0440
- Why not 4wd on highways? Hums in 2wd not 4wd
- 1998 Chevy Blazer Vent Valve
- need help diagnosing
- Rear glass
- hard start in moring
- Mirrors
- 98 Blazer Fog Light retrofit?
- Headlights not coming on
- Leaking Doors
- No Defroster
- 97 Blazer...no low beam headlights!
- oil leak
- 94 s-10 blazer vacuum ball position.
- It just won't start
- 87 s-10 4x4 actuator
- 94 s10 blazer 4.3 linear egr valve
- directional switch on a 95 blazer
- K5's
- Tried Acetone and a Tune Up - No Change In Gas Mileage...
- Lucas Fuel Treatment
- 2000 2wd 4dr
- 4 X 4 Will Not Kick Out On Passenger Side
- 2002 Chev Blazer Added NEW Keyless Entry
- trouble codes read
- fuel problem
- Front End Noise
- heater control
- when to replace hoses on coolent tank?
- TB Spacer Recomendations
- 99 blazer, not shifting to 2wd
- Fog Lights 98LT
- Royal Purple products
- 4 Wheel Drive Issues? Check this out
- 1985 s10 2.8 hard to start when warm
- Help! Tranny or Tras Case or Linkage????
- Alternator ?
- KYB Shocks
- hard start 98 blazer
- Steering wheel
- 3457 Bulb size?
- 89 4.3L cut off hard 1 sec after start up
- cross drilled or slotted rotors?
- 97 electric transfer case problem
- Rear Axle Rebuild
- air dye conditioning AC leak
- Performance Exhaust question
- new (new to me) Blazer
- Need Help!!! Gasket Replaement Started
- 4.3l engine sounds like 4cil..
- Fixing/finding error codes on the Electronic 4 Wheel Drive
- The Juice Box on Ebay
- New tire
- Synthetic VS. conventional Oil
- 96 blazer advise
- 4.3L Engine Performance
- 96 2dr center floor console removal tips
- Omg Death By Dexcool
- 91 Bravada Anti-Lock light stays on ......
- tornado
- engine temp
- General Maintenace Question - Wheel play
- 2001 Blazer dies after startup
- hood won't open
- Another 4x4 problem
- 95 blazer
- heater core replacement '95 S10
- 00 Blazer "Dead Battery" Again
- 97 Blazer LT Dying and hard restart
- 96 Temp gauge troubleshooting tips
- Wheel bearings?
- 91 blazer tahoe axel seal questions.
- hard starting
- whats the governerd top speed? in 1995
- blazer died and won't start
- Digital Cluster Electrical Wiring Diagram
- 1999 Jimmy/Blazer front end pull
- quick question about TORX sizes
- Need help with ABS light on 95 Blazer
- Fuel Tank Replacement
- It never ends!! Every problem gets worse ans worse
- Blazer is dead with frequent clicking sound.....
- bolt on dual exhuast
- tires
- This is why I don't do bodywork...
- Where can I buy a 4.2 inline 6?
- I'm Baaaack!
- getting at the heater core 99 jimmy
- transmission problem
- fuel pump keeps dying
- What Repair Manual Is The Best
- UH-OH She Wouldn't Start!!!!!
- 4 x 4 problem
- Battery or ignition switch?
- chassis ground, does any1 know where it is?
- where to get torsion bar bushings??
- Any good Off-Road locations around Rochester NY?
- 1995 blazer emmission control?
- 4x4 Problem
- '97 4.3L CPI Rattle at Low RPMs
- 96 blazer
- Red Emblems
- 96 blazer low gas mileage/ sluggish acceleration/ misfires
- sluggish acceleration
- what does check gages light mean?
- Tune Up Question
- 96 4.3L P0327 & P1870
- oil filter on 94 blazer????
- tire size / Toyo Open Country A/T
- 350 swap
- 1989 Blazer
- headers and cold air intake
- 98 Blazer - I Need A Service Manual !!!!!
- 97 blazer rear window help
- What size flare wrench to remove fuel filter?
- Hvac replaced 4 times
- 98 Blazer Ignition Fail
- headlights shut off
- Tires
- Heater ain't that hot. And it's cold outside!
- 1994 Blazer Dash Lights
- "Shift" Light Problem?
- 98 Blazer - Bad Ignition Switch?
- Baro Sensor Circuit, and IAC issues
- Trade-in
- Blazer Zr2 Tires
- 1996 Transmission idetification ?
- 1991 Blazer no spark
- 1997 Possible ignition sw. problem
- Trans Problem. 97 Blazer Need solid advice
- cost to replace bag ignition switch
- Heat/ac control problems...PLS HELP!
- door lock and window failure
- Squealing Issues
- 95 camaro rims?
- 96 blazer recalls
- 99 blazer blowing the 4wd fuse
- 2000 Blazer Rear View Mirror Removal???
- 4x4 turning concerns
- 1996 blazer very very hard start
- 99 gear illumination (PRND321)
- 4.3 cooling fan clutch noise
- 94 S10 Front Suspension
