View Full Version : Blazer
- Rear wiper stuck!
- 98 blazer Lt
- tranismisson oil cooler
- load hum in 4wd over 20 mph
- 1993 s10 Blazer 4.3L Vortec
- oil pressure gauge pegged all the way up
- '98 Blazer code 452 repair
- air blend door
- Heat tempature problem
- 99 4wd s10 blazer transmission oil cooler
- 98 Blazer - Airbag indicator on
- Distributor replacement
- 1992 vs 1993
- 97 Cranks, Won't Start. ECM Problem?
- high beams
- Transmission problems...
- Problem with New Diamond Headlights
- 95 Blazer Died While Driving
- Bosch 4s
- VMAX intake manifold spacer?
- 97 blazer no reverse
- oil cooler problems
- heater
- 2000 Chevy blazer 4x4 problem
- What are the Off-Road capabilities of my Blazer
- Is Dry Gas Good for the Blazer during the winter.?..
- Quality Shocks For Mostly Highway Driving?
- Antifreeze/green or orange?
- knock when cold
- Inaccurate fuel gauge
- 91 no start cold strange injector problem
- 98 s10 blazer quits running
- Help! 1992 s-10 blazer: no start
- CPI and nut kit
- electric superchargers
- Front bumper
- Blazer is blowing cold air then hot air
- 96 Blazer ABS Does not work....
- low oil pressure
- Hello, 1998 blazer can't find the terminal to prime or check fuel pump
- help when i put my gear in reverse it cuts the power some times...
- 94 Blazer keeps draining battery, won't stay running..Help, please
- AC Compressor Keeps Clicking On
- Is it just me ?
- Quick question on the fan clutch
- Computer Virus Alert
- brake FLUSH w ABS
- 98' Blazer, 4w HI Bind and wipers and radio
- Blown Lower Intake Gasket....CRAP!!!!!
- Happy Thanks Giving
- driving LIGHTS in lower valance
- I got me self some low emissions
- Front Washer Fluid doesn't work
- 98 LT Trouble Starting (Fuel Pressure Related)
- 98 Blazer tranny
- Help interpreting scanner readings
- Need help finding vacuum switch
- what about WINALDL ?
- Loss of power in a weird way.....
- voltage drop
- Light Bulb For Headlights.
- Noisy heater and reduced amount of air
- where is located the knock
- Broken spark plug
- Fluid Changes
- Fuel spilling from exhaust pipe before CAT converter
- 95 blazer Stalled and wont start
- Bilstein Shock Absorbers
- GM Equivalent Power Steering Fluid
- bleeding brakes
- Headlight Problem
- problemo with Blazero
- autozone diagnostic
- Replacing the oil pan with 4wd gear torn out.
- 4.3l 1990 different sound and it feels more light
- Battery Problem?
- 95 Blazer Rough Idling
- Weird Power
- Alex Peppers Automotive Scan tool
- 97 heater fan/motor replacement
- Jimmy pinging
- loss of electrical power
- Finally had enough!!!
- Rough Idle part 2
- Thermostat Replacement
- brake/fuel line corrosion
- Sold My Blazer
- Hello All
- 4x4 trouble codes
- 96 keyless entry instructions
- Am I getting a good deal?
- 1985 K5/K10 Blazer questions
- Blazer weight
- Gas mileage 13.5 city, is this normal?
- 1991 Blazer won't stay running
- Lock cylinder..HELP
- 2003 Leak in back of cab????
- I would like too put custom rim on my 99??
- front axle stuck in 4wd
- MY 95 blazer hell... code 175 system to rich ahhhhh!!!!!
- Who's Who
- '99 Blazer need serious help
- Spark plugs
- 1987 blazer stalling problem
- randomly shuts off, and makes a noise
- What happened to my car info in the profile
- My new problems lol its just gets worse and worse
- Must read; Don't buy anything from this guy
- P0128
- No Response from the board...thanks
- How do I measure????
- How much...
- 2003 Blazer ????? Daylights????
- Drive heat...no drive,no heat
- Still Gremlins!
- FS Hypertech ThermoMaster Computer Chip 91
- Electrical Gremlins? Starting/not starting heater not blowing all times
- my gas mileage sux
- CarMax or similar
- Installing Oil Cooler Lines - Directions
- Can I replace a CV joint boot?
- Please Explain What I should Grease????
- 1998 Chevy Blazer 4x4 Transmission Shot
- vacuum ball in 92 blazer?cant find?
- Blown Head Gasket! Now What?
- abs problem
- Front End Clunk
- 4.3 blazer, and when i gun it..
- GM Says NO TO ACETONE !!!!! Don't use it
- 1996 blazer oil pressure switch
- wheel noise
- More Problems with my 96 Blazer from hell
- Squeaky belt.
- 02 Xtreme rear bumper brackets w/o hitch
- Got bored over lunch.. boy am I lame...
- Under carped in back is Soaked ?!
- Could this be it?
- where can i buy the Blinker Relay
- 96' blazer, swap 99' power seats in.
- ignition lock cylinder
- 99 Blazer tries to "die" while driving slowly
- "insufficient egr flow"
- key won't turn
- Page resized , WHY!!!!!!
- Humming in engine
- 1998 Blazer
- New 4.3 in Silverado
- Rattling
- horn not working properly
- The Squeaking is killing me
- Cai
- 2000 blazer problem when starting cold
- Hey has anyone put on those LED Washer nossle on their Blazer?
- ticking noise
- mobil 1 synthetic oil in the cold
- Replace the 2.8L with?
- 97 Blazer Ignition Problem
- Door Spring Removal Tool - Found!!!
- 1996 blazer missing and low coolant temp
- four wheel drive indicator light failure
- 96 blazer transfer case problem
- Just paid .84 cents per gallon for gas, I love Amerika!
- Brush guard 2003 blazer
- heater core replacemnt
- Blazer Tire Rack removal
- wont go into 4wd
- Airbox Mod
- Silverstar 9006 question
- My first car (Need some help with a few minor problems)
- pls help stalling prblms
- question on transmission filter changing
- Parking Brake ??????
- rough 1st to 2nd
- Oil Pressure
- Need Help with Gasket replacement
- 95 blazer need help
- '95 Blazer with a P0300
- New Thermostat Not Working Properly?
- Radio ??????
- 1984 s 10 blazer 5 speed removal
- Heater, Climate control
- radiator flush/fill for Ford Taurus
- Runs Very Rich
- no engine lights come on which doesn't let engine start
- MAF sensor
- Rear disc to drum conversion
- 95 putting
- dash clicking noise
- ABS & Parking brake light on
- 95 blazer wont start anymore
- Fan Belt ?
- yet another stalling prb
- -Not-Blazer-related-But-GM-related-
- cold air intake/throttle body spacer
- 1998 Chevy Blazer Electrical Problem (death)
- Ignition or Starter?
- Brakes
- Clunking/rattling noise when starting initially and turning left
- Who Uses Green Coolant in Dexcool Car with bad results?
- 93 blazer fuel pump
- Who Uses Green Coolant in Dexcool Car?
- squeeking noise
- This Makes ME Mad
- 97 Bloazer Vacuum Ball..NEEDED!!
- 97 blazer wont start again replaced many...
- Starting problems
- 95 blazer won't start
- Ignition Switch Install
- 97 Blazer 4wd Switch Erradic Lights
- Spark Plugs
- bug in the rebuilt?
- After Market Stereo losing presets and clock
- Replacing rear axle pinion seal ?
- drive shaft yolk to transfer case seal
- AutoRX Has Anyone Used it ? Did it Work for you ?
- Replace rear Buckets with banch???
- What do you think????
- 99 Blazer seems stuck in 4lo
- 97 s-10 blazer shorts/no start help plz
- Rear Caliper replacement
- Hesitation when Humidity is High
- Can this be removed?
- Alternator: How to check if its Bad?
- Rear sway bar bushings
- gas
- Where do I locate the PVC Vale on 1998 Blazer?
- rattling
- 1998 Blazer wet carpet
- ZQ8 Sway Bar Upgrade
- You are not gonna believe this........
- How do I replace the wiper blades on my 89 Blazer?
- Blazer is not running right. Fuel seems to be sluggish
- Clear Turnsignal Housing
- 2000 Chevy Blazer - Power seats problem
- stuck fuel filter
- New Wheels!!
- New Problem to me that I can't answers to.
- Cabin filter
- 1994 Chevy S-10 Blazer Fuse Diagram
- 2002 Blazer Window
- cant find thread about guide to replace ignition switch.
- static
- upper and lower ball joints
- Will I win?
- ABS acting up, no light on
- heat doesn't work good
- Oilpan
- fuel pump????
- help did a boo boo
- 95 Blazer #6 cylinder missfire
