Our Community is 662,000 Strong. Join Us.
View Full Version : Maintenance
Pages : [1] 2 3
  1. Timing/Knock
  2. Need Help!!!!!!!!!!1
  3. Supra 7MGTE won't start
  4. t3 turbo but the o2 housing will not fit on the manifold
  5. vacuum trouble
  6. BoV Troubles, please help
  7. suspension Q 87 7mge
  8. bleeding fuel lines? 87 Supra, non-turbo
  9. missing while accelerating when warm
  10. In need of major help.
  11. need help on 7mge swap-no start
  12. Will crank but not start na 1986.5
  13. A/C question
  14. different kinds of turbo's
  15. Help!!!... Car breaking up badly under boost!!!
  16. 86.5 supra electrical short need help!
  17. 89 7mgte need help like its goin out of style
  18. 89 7mgte need help likeit goin out of style
  19. Supra slight tick or knnock
  20. Snapped a Bolt
  21. just bought
  22. Stock afm problems
  23. 85 supra knocking 5m-ge engine
  24. 87 disable the stock anit theft/alarm system?
  25. Electrical problem
  26. 86 supra smoking really bad
  27. Can automatic 7mgte wire harness be used on manual?
  28. noob quetion/don't kill me
  29. 89 Supra non-turbo starting problem
  30. Supra Turbo needs rebuilt engine. Good buy?
  31. Supra Turbo needs rebuilt engine. Good buy?
  32. Transmission swap for a noob
  33. help please
  34. crank pulley
  35. Changing Trunk Release Cable-1990 Supra
  36. check engine light
  37. Please Help Engine Knocking
  38. Please Help Engine Knocking
  39. Oil Leak, bad- please help
  40. know ur way round 7mgte's?HELP!
  41. oops i wrecked, what now?
  42. new issue
  43. spedometer help
  44. great article about oil sludge
  45. fuse block
  46. starting issues
  47. steering rack
  48. severe cutting out.
  49. severe cutting out.
  50. 1987 toyota supra
  51. leaky liftgate
  52. tps and idle rpm
  53. Supra Project Car Need help!
  54. 1986 Supra rear end
  55. Unconnected Wires?
  56. Question For You Guys!
  57. Cold start power loss
  58. more starting problems
  59. More starting problems
  60. Egr cooling Gasket!!!
  61. Desperate for headlight help
  62. I need your guys opinion
  63. milkshake on oil cap
  64. Starting Problems
  65. timing
  66. How to remove Wiper Arms?
  67. what does this light mean?
  68. Code 42 Speed Sensor
  69. standard stereo fuse problem
  70. need help with parts search!
  71. dorman 620-005 electric fan prob
  72. Toyota Approves Use of 0W-20 and 5W-20 GF-4 Oils
  73. code 2Z?
  74. swapping a 1JZGTTE into my 1990 supra turbo?
  75. Supra starter
  76. 91 Supra A/C low side port
  77. prototype 1986.5 supra
  78. nonoperational supra
  79. Power Steering
  80. pulling fuel injectors
  81. Starter Problems
  82. Alarms
  83. swapping a 2JZGTTE to my Supra??
  84. Damaged supra to fix!!
  85. timing problem
  86. i need help
  87. 7mgte head bolt torque
  88. Question
  89. help me please!!!question about 7m head
  90. Cant stop overheating
  91. need help with crank
  92. 1987 Supra N/A AT - All help welcome!
  93. Help Asap!
  94. What is this?
  95. toyota supra 1991
  96. Suitable turbo for 2jzgte
  97. Runing problems with my MKIII
  98. Inner door panel removal
  99. Supra Stopping Noise
  100. 1987 toyota supra shuttering
  101. Supra electrical problem
  102. break hub!
  103. Inspection Plate
  104. 1988 Toyota Supra wants to be driven into a river
  105. Advice on a 1988 Turbocharged Supra!
  106. Code 14
  107. Fuel Pump, Broken Turbo
  108. 1986 toyota supra
  109. 86.5 oil pressure fluctuates
  110. 1986 supra - installed engine - wont run
  111. Supra 2JZ-GTE T88hTURBO ECU map
  112. 5mge
  113. Is this possible??
  114. Quesion about engine swap.
  115. Used japanese engines
  116. I have no idea....
  117. MkIII wont stay on
  118. drive shaft
  119. Get at spolier lights 1988 supra
  120. 7mgte
  121. Vacuum
  122. fuel filter
  123. wont start
  124. runnig to rich
  125. newbie 86.5 turbo problems
  126. Overdrive disengage
  127. super monitor abbreviations
  128. random electrical outages
  129. head gasket blown in all 6 cyl.
  130. pistons
  131. Please Help!
  132. Celica-Supra
  133. Idle speed controller...
  134. Cold Engine Idle problem
  135. MKIII Head Gasket Replacement
  136. Weird Squeek
  137. Coolant leak problem
  138. 88 Supra with coolant in intake
  139. oil pressure gauge
  140. GGGGGGRRRRRRR transmissions suck
  141. clutch help.
  142. 89 supra doing strange stuff
  143. Just got my 1987 Supra Turbo and. . .
  144. ticking sound
  145. 1985 5m-ge
  146. 86.5 supra problems
  147. 7m mk2 transplant
  148. What should i Do
  149. my 87 na kills batteries!!!
  150. Problem with starting
  151. what is the name of this part?
  152. 1985 supra need help
  153. My Car Died
  154. Just Need A Little Help Please...
  155. poor power 7m-gte and timing problem
  156. 1985 Supra
  157. changing plugs on a '90 Supra
  158. Help! 7mgte
  159. Supra Wont Playing With Meh!
  160. Turbocharger Exhaust leak
  161. Help! S-o-s!
  162. engine swap
  163. mysterious rear end clunk?
  164. not going need help
  165. Supra parts?
  166. Help!! Spark Plug 5 Misfiring
  167. Alarm Troubles
  168. Misfire under hard acceleration?
  169. 87 Headlight motor question
  170. code 71 on mk3
  171. high idle when warmed up
  172. fuel problem
  173. Kinds of things to look for B4 buying
  174. lights keep turnin on
  175. oil leak - common place?
  176. MKII Wiring (Headlight issue on my '85)
  177. how to tell if heater core is clogged
  178. buying A hatchback problem
  179. engine start
  180. Major help pls....
  181. gas tank replacement
  182. hot emergency break handle
  183. 1986 and 1990 Supra TSRM, Wiring etc.
  184. 7mgte fireing order
  185. Reset Timing?
  186. 3rd cylinder head cover
  187. Idle screw location?
  188. Something knocking?
  189. Oxygen Sensor ¿Q?
  190. Supra Problems...
  191. fuel pressure reg vacume line
  192. 1jz engine problem
  193. Rear Differential/Pinion replacement cost?
  194. phone call from supra expert
  195. arp stock bolts on 7mgte?
  196. head gasket, resurface?
  197. clutch pressure plate bolt torques
  198. 1jzgte ion 7mgte transmission
  199. light
  200. Car Wont Start
  201. fuel problem
  202. engine diganostics
  203. engine, and door warning light won't work
  204. 81 Supra 5ME
  205. 88 supra no spark
  206. supra tech bulletin
  207. price for head rebuild
  208. oil in intake manafold
  209. coil pack firing order "wires crossed?"
  210. 87 supra knocking
  211. my supra goes dead
  212. bad gas milage Help
  213. 88 n/a overheats
  214. Starting FAQ Thread for Supra
  215. cold start injector removal
  216. strange tick
  217. engine knocking problems
  218. after a race my car wont start
  219. tranny problems??
  220. Supra wont crank
  221. clutch CHATTERING
  222. head gasket repair
  223. Thrown rod rumor
  224. Replacing radiator top tank, ...7MGE
  225. 87 supra computer chip
  226. heat and defroster doesnt work
  227. transmission
  228. 7mgte parts in socal
  229. blow off valve
  230. shocks
  231. 95 supra blown rear end
  232. 88 fuel ratio gauge help
  233. 7mge to twin jz
  234. 1985 Supra no spark??
  235. vacume line on Mt?
  236. speedometer problem
  237. no power when in gear
  238. toyota wont tell or sell (flargen flaggers) 7m gte
  239. mkIII with timing problem?
  240. charcoal canister and egr
  241. short throw shifter
  242. required sensors ecu help
  243. Dash lights
  244. auto trans on manual car
  245. help! wont start
  246. useful idle info
  247. graphics
  248. 83 cylinder not fireing
  249. Timing Belt
  250. whats this
