View Full Version : Maintenance
- turbo tune?
- 1986 toyota Supra No electrical at all!!??
- 1987 supra
- Bad Head Gasket?
- 2jz-ge and turbo??
- new turbo
- Running/Parking lights dont work. HELP!
- 86.5 supra oil pan blues
- turbo check
- Clutch question
- jdm 7mgte swap
- general head gasket questions
- 2jzgte wiring diagrams
- clue to rough idling problem?? (pics)
- F&F supra specs
- 1984 Toyota Supra Value Lashadjuster
- Car will not start. No electrial power
- 7M-GE to 7M-GTE
- 85 Supra Rear End Clunk
- 85 Supra Ignition Timing Check Problem
- MKIII Idle problems; CPS?
- NEED HELP 94 Supra Kills on IDLE!!!
- Wanted turbo supra Project car manual transmission
- speedometer cable question
- 1987 toyota shakes while driving. Help Please!
- HELP! OH, **iT Think its F**ked
- just wondering
- Problems???
- coolant in plug valleys after HG replacement
- HELP! Alarm in kill mode & can't bypass alarm or turn off.
- 1988 problems
- dash lights wont come on
- dimensions~need help!!!
- ? about exhaust measurments
- Help! Water Leaking into Boot/Trunk
- New Targa Top
- 89 NA Supra engine making bad sounds
- My 89 supra turbo has troble starting
- Tems
- engine problem
- intermittant hesitation/rough idle
- engine/air cond problem ???? HELP
- how do you swap a 7mge to a 7mgte
- 1988 Temp gauge short?
- Time for a rebuild
- fuse
- help oil present at turbo inlet??????????
- 91 Supra Turbo need serious help!
- 1986 Supra MkII Not Firing
- Can You Diagnose This?
- Rocker Cover Gaskets
- 89 Supra Turbo wont start- HELP
- 1990 Supra Sound System
- oil in spark plugs... is this normal?
- '86.5 supra making noise possibly CV joint?
- unknown pressure...
- replacement engine
- Exhaust Smoke
- turbo sound
- auto tranny fluid, how much to put?
- Ring & Pinion Gear change
- Front Main Seal + timing belt questions
- Turbo pressure
- New problem....
- mkI supra
- Be advised
- troubleshoot radiator cooling fans, electric
- replacing head gasket?
- Horrible Vibration
- A/C clutch doesn't engage
- Starter relay? 88 N/A
- intake cam lobe
- Parking brake pads???
- No spark
- can boosting too much blow powersteering?
- 89 Supra, auto tranny, no kickdown, no power mode
- Zero Tolerance?
- 1990 Turbo,perfect condition,replace HG?
- installing cam position sensor
- need help on my 86.5 supra ... please
- MK3 1986.5 Supra problems...
- E-brake adjustment
- wont start
- electrical problem...trying to locate junction box 1
- Open door to start car.
- Strange vibration
- 86.5 N/A driveshaft and spark plug problem
- Help with an 86.
- Missing Cylinders
- No Shifting~~!
- ?car dies while moving?
- car color 90 turbo
- Oil in the plug valley
- 86.5 Supra auto tranny shifts wrong
- Sign for BAD GAS!!!
- 90 Auto Trans PLEASE PLEASE HELP
- cam ?
- radio stopped working in my supra turbo
- 87 non-Turbo Starting Problem
- need instructions for installing a greddy turbo timer
- No Belts!!!
- Supra cuts out
- code 12?
- Need Fan
- is smoking bad?
- boddy trim
- mk4: auto to manual.
- Shaking/Shimmying 90 turbo NEED HELP PLZ
- High Mileage Supra MKIV
- More Problems!?
- Stripped head stud.
- Timing belt for 1983 Supra
- alarm wont shut off.
- supra gearbox problem
- engine running hot
- Alarm/Starting problems
- torque specs
- water leak
- Transmission
- wiring question
- possible blown head gasket
- Mk3 Headlights
- overheating
- ? about windshield washer wires
- Turbo guage not working properly
- ? about egr problem
- Turbo oil cooler
- 7m-ge Head gasket
- 1987 supra running hot
- I need front and suspension parts for Toyota Supra 1997year
- tems
- 7mgte swap
- Targa top bolts
- swap or rebuild????
- ecu issues
- Oil missing?
- need help w/ alarm and pwr windows
- cylinder head torque settings
- air mass flow sensor
- 90 turbo wont start
- mkIII won't start
- radiator light
- idle
- Iridium Spark Plugs..
- 7mge to 7mgte engine swap
- Buying advice
- Help with my supra
- mkIII 40 dollars turbo good
- car wont start after bhg repair?
- turbo exhaust manifold stay?
- Need Help ID Wheels
- need help finding harness connector?
- transmission
- Transmission additives(slipping under load), share your experiences, please help.
- in middle of bhg repair
- problem with clutch or tranny?Help plz
- power steering pump problems
- ? about bhg repair
- My 1986.5 NA wont fire Across any cylinders
- Speed ABS Sensor help
- Oil where there shouldnt be oil???
- dash lights come on?
- Airbag question ??
- Headbolts
- Clutch interlock switch needed for inspection
- Intake manifolds
- Oil leak question, please help
- 1999 corolla gas mileage drops
- head gasket may be starting?
- MKiii idle prob
- what is the light to the left of the water temperate gauge?
- 1jz idle problem
- PLeazzzzze i need help for my ?s
- Supra Idle
- Air Flow Meter???
- boost problems
- need help with cooling problem
- need help about broken stock blow off valve
- 7mgte
- Speedometer noise
- What is the name of this part?
- Big question on timing belt
- Air Bag Kit.
- Turbo and non turbo heads - what's the difference?
- Whats the normal oil pressure?
- Need to find 1jz performance parts
- ? about 5 speed transmission swap to an automatic
- Need help with 1jz-gte MAP sensor
- ? about swaping motor and transmission
- Fastest supra
- Engine mount torque specs?
- Replacing the Head Gasket
- thinking about getting a supra mk2.....
- Wiring Diagram
- Looking at new pulleys
- Exhaust header
- PCV Pipe
- 88 Auto Tranny help
- Please help
- Can some 1 please tell me fast in at least 2hrs!!!!!
- Crankshaft pulley
- how do u know if u have a blown head gasket?
- need help, loud knocking sound from engine
- Oil leak problem
- 84 supra fuel pump
- Missing Targa screw
- Replace Starter on 89 Turbo
- What is that wierd noise??????
- 89 turbo engine rebuild
- supraracer5689
- temp guage up..but not overheating?
- Help!!!
- Red 89 Supra NA needs parts
- need help 89 turbo, cracked piston!
- overheating...maybee
- Power Steering
- 1990 supra turbo
- Supra pluus to one side on acceleration
- german supra driver needs help with apexi
- Anyone fixed wind noise on mk3 supra??
- MKIII no-turbo head rebuild issues
- lost power
- Strutbar problem
- Supra Twin Turbo Drilled/slotted Rotors For Sale!
- CPS/distributor wire color diagram
- Engine Swap....car starts then turns right off
- How to remove oil pan? 81 Supra MK1, engine IN.
- fast idle at start 2001 toyota corolla
- help with gauges?
- 5M Tranny on a 7M GTE
- idling problems help me out!
- 1986.5 starting problems...??
- Rebuilding everything
- mk3 wiring diagrams
- tech question for mk3 supra!
- how many miles does the clutch normally last on a supra?
- Problem with Supra in 4th gear..
- Help please - Stripped Transmission bolt
- rough idle
- supra head gasket
- burning oil on startup
- Help...A/C smells funny
