View Full Version : Prism
- just bought a car with problems
- A/C O-tube keeps clogging up
- Prizm Wheel bearing
- 2000 Prism need engine help
- 1999 Chevy Prizm - Instrument Panel light bulbs ( LED replacement)
- 1999 Chevy Prizm - lock rod clip?
- Airbag light
- 1999 Chevy Prizm - defogger switch light bulb ( LED replacement)
- 98' prism p0446, need toyota part number
- HVAC Control Panel Light Bulbs
- Fan Always Running
- Both headlights died
- 99' prism runs rough and cant go up hills
- 98 Prizm Fusebox wiring?
- 95 Stalls, cuts out.
- 2000 prizm cam sensor code 340 coming back over and over.
- Odd electrical issue
- 1999 Chevy Prizm - Headlight bulb selection
- Geo Prizm - Starting problems
- Grinding Noise Under Hood, A/C?
- the key or the lock?
- What's your MPG, who gets 40 and why?
- Remote Entry Problem
- 99 prizm timing chain replacement
- `99 Power Window Problem..
- Rubber weather stripping
- Prizm 2001 LSi Suspension Coil Springs
- Vehicle speed sensor
- Headlights on, engine off!!!!
- 1999 Chevrolet Prizm Interchangeable Body Parts
- Parting out '99 Prism
- '01 Prizm Question
- Fault code on 2000 Prism
- Door latch
- Installing Tach on 99
- Are the 98'-02' Prizm's 100% toyota like the Geo Prizm's were?
- PRIZM Paint - For Sale (Dark Blue Met)
- '00 chevy prizm, help!
- EGR valve 98 prizm / corolla
- How to find and exhaust leak
- Disonecting AC compressor in 1996 Geo Prism
- Taillight and Turn Signal Issues
- cigarette lighter quit working 98 Prism
- 99 Prism(corolla) differential
- Is my starter bad?
- Can't find the clatter
- 2001 Chevy Prizm + trim kit
- 91 Geo Prizm Air tube
- Rusty Rocker panels
- bad engine?
- Purchasing 2002 Prizm.
- Timing Belt or Chain?
- Rear Stabilizer Link Issue - Anyone ???
- DRL / Taillight issues
- Can't find EVAP Canister Vent Valve ('98)
- Struts - easy or difficult ??
- Who has the most mileage?
- Steering Wheel Vibration
- 1999 wiper motor/linkage
- Both A/C and radiator fan not working
- Ball joints .. anybody done their balljoints?
- Dash Bulb Help Needed
- Tensioner Pulley Replacement?
- electrical problems
- Speaker size in a 99 prism
- What's wrong with my clutch/transmissin? '99 Prism
- Iginition Switch?
- 2000 Prizm DEAD!
- 99 Prism heater issue
- headlight problems
- 2001 Prism Spark Plug Location
- Starter problems 99 Chevy Prizm
- Exhaust Headers
- Tail lights
- Tube goes to nowhere on bottom of Evap charcoal canister
- 0446 solved
- Can't find vacuum leak
- Chevy Prism 2000 PO171
- What is in the exhaust system of a 2000 prisim
- 94 Prizm ABS light always on
- Spark Plug Wire Order
- Rear wheel bearing
- Starter issue maybe??
- (How To) Add Aux input to Prizm 2001
- 2001 Prizm Cluster w/tach upgrade?
- Getting sick of seeing emission codes
- break drums hard to remove 96 GEO
- 94 Prizm tail light short
- Blinking seat belt guy
- 00' prizm p0441 problem
- 94 Geo Prism Have Questions
- Installing a window in a 2007 Chevy Prizm
- Camshaft gear pin sheared off 2000 Corrola, other problem.
- Horn wire wore through condensor tube.
- 01 Prism high mileage
- A/C Compressor Pulley wobbles need help
- Will a corolla catalyctic converter fit a geo?
- 2000 Prism, lots of problems
- Clogged air vents
- Front speaker questions
- Fuel Pump replacement
- Seatbelt Indicator Light
- Horn + Cruise Control not Working
- Problem with tinted windows
- Horn Fuse
- Prizm multifunction switch mishap
- where to by the headlight holding frame
- 99 Prism Airbag indicator
- high idle speed
- Check Engine code says O2 Sensor but isn't
- Starting issues
- Adding Dexron III to '01 differential.
- '99 Prism,LSi won't start until third try. do I need a starter?
- How to install a new CD?
- Wheel interchangeability for '98?
- Battery -- specifications and requirements
- Bad exhaust valves
- oil burning
- Slow automatic door locks
- dead priZm
- paint code for green blue 2001
- Putting seat covers on rear seat
- RF Door Latch broken
- Solutions for Fixing Interior Plastic Peeling Away?
- Fuel starvation on acceleration. HELP
- 99 Prizm battery cables
- P0441 code fixed for fairly cheap. Purge valve was bad.
- P0420 Error: Unauthorized Catalytic Converter or Oxygen Sensor
- for sale
- front left side bang / knock
- Tranny fluid capacity with torque converter
- Wiring Diagram Needed
- check engine code P0171
- *URGENT* 2001 Prism 1.3L Stumbles off idle and no DTC's!! HELP!!!
- are parts toyota???
- Canister and valve system problem
- Where are the spark plugs?.....lol
- 98 Prism Bad Take off
- Radio Lights
- How to locate the low side port of AC?
- ABS Light on for 3 years... last night completely lost brakes at intersection.
- fuseable links
- 89 geo prizm intermittent no-starts
- Key doesn't work in passenger door
- How to check orig. equipt. on 2001 Prizm?
- 2001 Prizm front license plate holder?
- 2001 Prism check engine light
- Differential fluid change in a '99 auto?
- 1999 Chevy Prism 100,000 miles
- Airbag and Horn problem!!
- Replace Rear Struts - 89 prizm
- Symptom of Timing Belt or Sprocket Problem?
- pulley problems
- won't pass emissions in missouri
- Check Engine Light Code po441
- transaxle help!!!
- 95 Prizm inertia (fuel cutoff) switch
- A question about 2001 Prizm Stereo Wiring
- Oil in Number One Cylinder
- 94 power problem
- n00b question about headlights
- Tune up kit help for 94 prizm
- Looking at buying a Prism GSI
- Need help, check engine light, new driver!
- 89 prizm trunk lock won't open
- 94 Prizm, new front axels but abs lights at 65mph
- Donut Gasket
- Type of disc brake pad used,2001 Prizm
- how to tell if I was ripped off?
- my wifes 98 prizm possible brakes sticking
- under car splash pans@#%^&#@
- a/t to stick conversion=
- differential lock-up
- No power to new head unit in 1997 Prizm
- differential plug location=
- Problems with '98 Prizm
- What makes and Lsi an Lsi?
- Dash Bulb Numbers
- Noise during acceleration-99 prizm
- 98 Prism-How do I reset the clock?
- 2001 prizm heater fan speeds
- Starter Location and more
- Misfire Codes, White smoke and whirring sound
- Battery or alternator?
- Connection Between PO171 Code and A/C Problems?
- 99 prism door panels
- Towing a trailer behind a 95 Prism?
- 95 Geo Prizm turn signals
- check engine light - HELP
- Prizm going through 1 quart of oil every 1000 miles
- 1997 specs
- Wiring
- 91 prism dashboard lights
- '98 Prism driver's window issue
- 1996 to 2002 Chevrolet Prism, Any Chronic problems ?
- keyless remote p/n 12490829 fcc#EZSOEMTX???
- EGR Valve And Evaportaion Canister
- 1999 Chevy Prism timing chain or belt?
- 94 Prism Starter Problems
- fan runs constantly
- 98 Prizm starter
- rattling noise
- Brainbuster for the pros
- Blinking high-beam light on dashboard
- rattling noise
- 2000 Prizm lean fails inspection
- Airbag Maintenance on a 1999 Chevy Prizm
- Check Engine Light LEAN
- 95 geo prism clutch problem...
- 1999 prizm LSI fan speed switch problem
- Broken rear wheel stud 97 prizm
- 95 Prism Brakes
- Can't get Key to release
- Starting Up Fixed
- Starting Up
- 95 prizm brakes are way spongy
- Lean Machine
- 99 Chevy Metro - Fuel Filter
- p0441 code
- 91 Prizm...Doesn't anybody know?
- any simple preformance mods for a 99' prism?
- Check engine light- lean bank
- 91 Prizm left tail light assembly removal.
- 99 PRIZM auto transmission belly up at 86K
- 96 Geo Prizm LSI: Squeaking Problems/ Possible Steer Pump??? Help!!!
- cruise and horn doesnt work
- looking at 2001 prism
- Po446
- Vibrating exhaust system
- radio wont come on
- 94 prizm a/t stalls
- Will only start with foot on brake
- HI! New to the forum! Owner of 2 Prizm's, and looking for another!
- read codes and timing belt replacement
- starter bolt replacement
- '01 LSI DRL and OE struts
- Fob Keyless Entry Programming
- Left TAIL LIGHT 2001 PRISM
- Check engine light code P0171
- Replacing Headlamps in 98 Prizm
- headlight adjustment
- Towing 1999 Prism
- ever replace the starter? 1999 prizm
- oppps battery was installed backwards
- High Oil Cunsumption
- Opening the front console
- 92 Prism int. heat
- Compatible Oil Pans
- Overdrive?
Automotive Network, Inc., Copyright ©2012
