Our Community is 662,000 Strong. Join Us.
View Full Version : Pick-Up
Pages : [1] 2 3 4 5 6
  1. 1989 Toyota 4X4 Pickup 22RE Engine not starting.
  2. 18 volts on 84 pickup
  3. Replacement parts question (brand?)
  4. irregular idle 22re
  5. Fuses to the Fuel pump are on even though the car is off
  6. 22RE fuel pump pressure?
  7. broke a stud on exhaust flange 2 of 3 left do I need to do something about it. what is the torque for the bolst
  8. 94 catalytic converter how do you know when it needs replaced? need replaced
  9. 22r issues
  10. 1992 V6 Toyota Pickup
  11. Manuel transmission won’t go into gear
  12. Trouble shifting out of drive
  13. Alternative tire sizes
  14. Front-end rebuild (how far should I go?)
  15. 1987 pickup differential replacement
  16. Black Fuel Smoke Backfire Busted New Muffler
  17. Measuring Impedance or Resistance on Igniter
  18. bogging troubles?
  19. Custom Canopy Build
  20. 89 toyota 4x4 Automatic Transmission erratic shifting
  21. 93 4x4 high speed vibration
  22. 93 Toyota Pickup 2WD -Runs but no acceleration
  23. 93 Toyota Pickup-Dies after 10 minutes
  24. bad mileage.. is it bad thermostat?
  25. four wheel drive wont work
  26. 81 Toyota intermittent starting problems
  27. Hi irregular idle 22RE
  28. 1989 Toyota 4X4 Pickup won’t start.
  29. Rear end....
  30. 1993 Toyota Pickup, Manual Steering Issue
  31. Tire Size
  32. Cant find the ground on my 91 Toyota pick up
  33. No Heat
  34. 94 with 3.0 missing at startup
  35. CONFUSED!!! 22re timing/distributor
  36. 22RE Timming Issue/Bent Valves??
  37. Porlock, anybody know how to bypass or uninstall them
  38. 94 22RE suddenly dead as can be, no clock even and nothing when turning key
  39. 89 hard starting/ when cold/ issues
  40. Low coolant sensor
  41. clutch not working right
  42. 1994 tailgate hinge threads broke off? how repair?
  43. 1988 3.0 V-6 has no spark
  44. 92 pickup 22re #2 and 3 wont fire
  45. 87 Vacuum Emission System - 22R
  46. Electrical system completely dead
  47. am\fm \cass.
  48. Toyota Hilux D4-D 2KD-FTV engine rev problem
  49. Need help with my 22re engine
  50. Overheating 22R Engine Thumping
  51. olejoe
  52. Hard to Start
  53. 94 Toyota SR5 V-6 Cranks but no Start
  54. 90 4x4 diff ???'s
  55. 1982 Toyota PU Shifting Problem
  56. Timing Chain Question
  57. 88 22R runs wide open...
  58. no oil in filter
  59. Need help for my 1988 Toyota pick up
  60. Help with 1988 Toyota pick
  61. Help with 1988 Toyota pick
  62. Help with 1988 Toyota pick
  63. 1989 22r ignition problems!!!
  64. 1988 Pickup 22RE
  65. 87 2WD 22R rear axle issue
  66. 22re engine whine
  67. 89 toyota p/u V6 mystery problem
  68. 89 starting problems
  69. burnt altenator again
  70. 89 Toyota truck fuel problem/ possible ignition
  71. 90 Toyota 2wd pickup speedometer
  72. 89 clutch replace? Hard?
  73. diesel no power
  74. More info on the 94 toyota rebuild. please help
  75. 94 toyota rebuild and failure
  76. 94 toyota 4x4 pickup won't stay running.
  77. '94 pickup problems with rain
  78. 89 toyota thermostat
  79. 90 Toyota truck, bad Hesitation ??
  80. 84 22r Carb help
  81. 22re engine swap
  82. 87 pick up 22R won't start
  83. Engine options.. please help.
  84. help please. 84 yota fuel problems
  85. 1990 Toyota Pickup Transmission
  86. EFI fuse blown
  87. 1989 22re tps
  88. '87 22R, Carbed 4x4 Bucking
  89. Will 1994 rear end swap with 1990
  90. Fuel leak
  91. The notorious Toyota "TICKING" sound
  92. replaced timing chain but still flopping around
  93. From a pick-up to Frankenstein
  94. 93 toyota pickup
  95. Factory intake hose from canister to exterior grill
  96. 2wd toyota pickup
  97. projector headlights
  98. 1989 Toyota 4x4 Pickup Starter Question (how to get it out?).
  99. starter motor/solenoid problem?
  100. 91 3vze exhaust/header Q
  101. '93 PU/New cold air intake/bypass old intake sensor????
  102. Cylinder head recommendations
  103. Brakes very strange
  104. 1979 Backfiring through carb
  105. opinion on rebuild or not
  106. '80 4cyl. 20R water pump bolt torque specs? I got the 6cyl. specs thou...
  107. 22re HARD 2 START?? Check here
  108. strut rod bushing replacement help needed 94 pick up
  109. 1989 toyota 4x4 pick-up 22re not starting well.
  110. 81 Toyo Left Rear Brake Line
  111. Replace front suspension control arms
  112. 1987 22r. carburated. fuel problem.
  113. 89 sr5 wont go into gear.
  114. 22r to 22re
  115. Help I Lost my Distributor Bolt
  116. Need help finding cam bearing caps 91 4 banger
  117. 88 V6 No Spark!
  118. 94 toyota, fuel or air intake valve
  119. Burning oil help 22re
  120. Engine swap advice.
  121. 89 toy wont run unless block off return fuel
  122. 95 Toyota truck won't continue to run.
  123. My motor is tired whats my options
  124. 89 pu wont run
  125. 94 4X4 coolant mixing with oil
  126. 1979 yota vacuum lines
  127. drive train knocking?
  128. 89 toyota pickup replacment engine?
  129. 89 toyota SR5
  130. Pick-up only starts if sitting on a hill.
  131. 93 Toyota Truck wont shift gear
  132. 91 Toyota Truck
  133. 94 Toyota pick up timing chain, need info on how to replace guides!
  134. Wheels
  135. Toyota steering link recall video
  136. i will never adjust valve clearance on a 88 pickup again.
  137. 1994 Yota top end noise
  138. 89 toyota please help
  139. 1992 pickup Automatic transmission overdrive problem
  140. losing charge on 1990 pickup v6 SR5
  141. losing charge on 1990 pickup v6 SR5
  142. 93 2WD PU up and down idle when warmed up.
  143. 89 pickup v6 IAT?
  144. 84 22r charging system
  145. 1990 toyota pickup 3.0evz v6
  146. 22RE Buy/ReBuild
  147. Shake when braking
  148. 22r fuel tank pickup cloged ??
  149. 1991 Toyota Pickup V6
  150. 1993 Toyota Truck Clutch Adjustment
  151. egr valve
  152. My truck
  153. '90 3.0l V6
  154. 86 22R EFI won't Idle
  155. 94' Pickup. Problem under the hood
  156. 1994 Toyota P/U center console removal
  157. 92 - 94 rear end swap
  158. 94 pickup won't start warm (sometimes)
  159. 93 Pickup Won't Idle
  160. '85 Toyota, newbie question
  161. 92 22re pickup idle problems when brake applied
  162. Problems with starter removal
  163. 89 toyota truck 22re no compression
  164. 1987 pickup possible engine change
  165. 1987 Toyota pickup-2wd 22r engine coolant in engine
  166. 94 pickup torque converter question
  167. "What to look for" 1993 Toyota Pickup
  168. Wheel hub problem
  169. 1990 toyota xtra cab 4x4 22re-no power
  170. Rear window latch
  171. 1986 22re hard start & check lite
  172. 4 spd. Auto?
  173. 1990 pickup knock sensor
  174. 89 PickUp-22RE 4x4 5 spd(gas gauge/ac Stoped working)
  175. 1987 Toyota Pick-up Spare Tire Mechanism
  176. Head gasket or timing cover
  177. 96 22 r wont idle
  178. valve train issue
  179. Need dual exhaust headers for 3 Liter V6
  180. 86R 4x4 swap with 92RE2x4
  181. circuit opening relay
  182. 1990 exhaust replacement
  183. 94 Pickup needs new engine
  184. 85 22re having trouble
  185. 90 swap to 91 cluster,tach will not work
  186. 85 22re rebuild, any suggestions
  187. 22R timing chain R&R on 86 pickup
  188. need more horsepower
  189. Need New transmission
  190. 1986 4x4 ext cab FI
  191. Help finding some parts
  192. 93 with frozen head bolt
  193. 1990 toyota pickup power ratio
  194. 87 Toy motor rebuild. Carb version
  195. turn signal flasher
  196. 87 Toy 22R carb rebuild
  197. 22RE with MegaSquirt
  198. 86 PU w/22R growling
  199. Toyota pick-up floor shifter?
  200. 1989 EFI Engine Trouble
  201. Window Visors
  202. 1991 'Yota Parking brake bracket
  203. 87 to 89 swap
  204. 1989 Pickup shift know removal
  205. someone help
  206. '86 Fuse Box Diagram?
  207. Mod for the AISN Warn tranny on 87 4x4 Toy
  208. '91 3.0L oil pressure drops out
  209. 87 rebuild kit on 4x4
  210. Pick-up engine specs
  211. Hercules tires, any opinions?
  212. 1992 toyota pickup seats
  213. 87 Toy ...need AC
  214. Pls help...2005 toyota hi-lux
  215. Oil Leaks
  216. '86 Pickup fuel gauge quit
  217. coolant in oil
  218. 1987 Toyota 22R 4X4 Vacuum Problems...
  219. '91 MPG seems low....
  220. 86 yoda turbo
  221. 91 Pickup Starting Problem - Just a click and whirring noise
  222. 95 pickup engine dies when starter stops
  223. 76 20R carb problems
  224. '91, 5-speed won't engage gears...
  225. crappy idle 89 22re
  226. 91 pickup electrical questions...
  227. 1986 22-RE Running Hot
  228. 91 SR5 pu has no power at all
  229. 5-speed swap
  230. Confused 94 Toyota P.u. 22re
  231. 22RE engine to replace 22RET
  232. 86 yota has NO power and won't start
  233. will a 85 or later cab fit on my 82 frame?
  234. 1989 Toyota Pick-up fast idle
  235. problem with pickup starting, not alt., starter, or battery
  236. my brothers truck. 87 pick up
  237. 98 Toyota Tacoma
  238. 86 Yoda Turbo Clanking Noise
  239. Brake booster problem, or gasket vac leak?
  240. 95 Toyota pick up timing belt
  241. new gas line to carberator
  242. parking / instrument lights stay on after rain
  243. disappearing oil trick
  244. Nothing will fix my Heat
  245. choke / fast idle not engaging when cold
  246. choke / fast idle not engaging when cold
  247. fixing up my truck
  248. Turbo question
  249. re: 92 p/u water in dash
  250. 83 4wd 22r / camber problems
