View Full Version : Pick-Up
- help please. 84 yota fuel problems
- 1990 Toyota Pickup Transmission
- EFI fuse blown
- 1989 22re tps
- '87 22R, Carbed 4x4 Bucking
- Will 1994 rear end swap with 1990
- Fuel leak
- The notorious Toyota "TICKING" sound
- replaced timing chain but still flopping around
- From a pick-up to Frankenstein
- 93 toyota pickup
- Factory intake hose from canister to exterior grill
- 2wd toyota pickup
- projector headlights
- 1989 Toyota 4x4 Pickup Starter Question (how to get it out?).
- starter motor/solenoid problem?
- 91 3vze exhaust/header Q
- '93 PU/New cold air intake/bypass old intake sensor????
- Cylinder head recommendations
- Brakes very strange
- 1979 Backfiring through carb
- opinion on rebuild or not
- '80 4cyl. 20R water pump bolt torque specs? I got the 6cyl. specs thou...
- 22re HARD 2 START?? Check here
- strut rod bushing replacement help needed 94 pick up
- 1989 toyota 4x4 pick-up 22re not starting well.
- 81 Toyo Left Rear Brake Line
- Replace front suspension control arms
- 1987 22r. carburated. fuel problem.
- 89 sr5 wont go into gear.
- 22r to 22re
- Help I Lost my Distributor Bolt
- Need help finding cam bearing caps 91 4 banger
- 88 V6 No Spark!
- 94 toyota, fuel or air intake valve
- Burning oil help 22re
- Engine swap advice.
- 89 toy wont run unless block off return fuel
- 95 Toyota truck won't continue to run.
- My motor is tired whats my options
- 89 pu wont run
- 94 4X4 coolant mixing with oil
- 1979 yota vacuum lines
- drive train knocking?
- 89 toyota pickup replacment engine?
- 89 toyota SR5
- Pick-up only starts if sitting on a hill.
- 93 Toyota Truck wont shift gear
- 91 Toyota Truck
- 94 Toyota pick up timing chain, need info on how to replace guides!
- Wheels
- Toyota steering link recall video
- i will never adjust valve clearance on a 88 pickup again.
- 1994 Yota top end noise
- 89 toyota please help
- 1992 pickup Automatic transmission overdrive problem
- losing charge on 1990 pickup v6 SR5
- 93 2WD PU up and down idle when warmed up.
- 89 pickup v6 IAT?
- 84 22r charging system
- 1990 toyota pickup 3.0evz v6
- 22RE Buy/ReBuild
- Shake when braking
- 22r fuel tank pickup cloged ??
- 1991 Toyota Pickup V6
- 1993 Toyota Truck Clutch Adjustment
- egr valve
- My truck
- '90 3.0l V6
- 86 22R EFI won't Idle
- 94' Pickup. Problem under the hood
- 1994 Toyota P/U center console removal
- 92 - 94 rear end swap
- 94 pickup won't start warm (sometimes)
- 93 Pickup Won't Idle
- '85 Toyota, newbie question
- 92 22re pickup idle problems when brake applied
- Problems with starter removal
- 89 toyota truck 22re no compression
- 1987 pickup possible engine change
- 1987 Toyota pickup-2wd 22r engine coolant in engine
- 94 pickup torque converter question
- "What to look for" 1993 Toyota Pickup
- Wheel hub problem
- 1990 toyota xtra cab 4x4 22re-no power
- Rear window latch
- 1986 22re hard start & check lite
- 4 spd. Auto?
- 1990 pickup knock sensor
- 89 PickUp-22RE 4x4 5 spd(gas gauge/ac Stoped working)
- 1987 Toyota Pick-up Spare Tire Mechanism
- Head gasket or timing cover
- 96 22 r wont idle
- valve train issue
- Need dual exhaust headers for 3 Liter V6
- 86R 4x4 swap with 92RE2x4
- circuit opening relay
- 1990 exhaust replacement
- 94 Pickup needs new engine
- 85 22re having trouble
- 90 swap to 91 cluster,tach will not work
- 85 22re rebuild, any suggestions
- 22R timing chain R&R on 86 pickup
- need more horsepower
- Need New transmission
- 1986 4x4 ext cab FI
- Help finding some parts
- 93 with frozen head bolt
- 1990 toyota pickup power ratio
- 87 Toy motor rebuild. Carb version
- turn signal flasher
- 87 Toy 22R carb rebuild
- 22RE with MegaSquirt
- 86 PU w/22R growling
- Toyota pick-up floor shifter?
- 1989 EFI Engine Trouble
- Window Visors
- 1991 'Yota Parking brake bracket
- 87 to 89 swap
- 1989 Pickup shift know removal
- someone help
- '86 Fuse Box Diagram?
- Mod for the AISN Warn tranny on 87 4x4 Toy
- '91 3.0L oil pressure drops out
- 87 rebuild kit on 4x4
- Pick-up engine specs
- Hercules tires, any opinions?
- 1992 toyota pickup seats
- 87 Toy ...need AC
- Pls help...2005 toyota hi-lux
- Oil Leaks
- '86 Pickup fuel gauge quit
- coolant in oil
- 1987 Toyota 22R 4X4 Vacuum Problems...
- '91 MPG seems low....
- 86 yoda turbo
- 91 Pickup Starting Problem - Just a click and whirring noise
- 95 pickup engine dies when starter stops
- 76 20R carb problems
- '91, 5-speed won't engage gears...
- crappy idle 89 22re
- 91 pickup electrical questions...
- 1986 22-RE Running Hot
- 91 SR5 pu has no power at all
- 5-speed swap
- Confused 94 Toyota P.u. 22re
- 22RE engine to replace 22RET
- 86 yota has NO power and won't start
- will a 85 or later cab fit on my 82 frame?
- 1989 Toyota Pick-up fast idle
- problem with pickup starting, not alt., starter, or battery
- my brothers truck. 87 pick up
- 98 Toyota Tacoma
- 86 Yoda Turbo Clanking Noise
- Brake booster problem, or gasket vac leak?
- 95 Toyota pick up timing belt
- new gas line to carberator
- parking / instrument lights stay on after rain
- disappearing oil trick
- Nothing will fix my Heat
- choke / fast idle not engaging when cold
- fixing up my truck
- Turbo question
- re: 92 p/u water in dash
- 83 4wd 22r / camber problems
- 92 p/u. water in dash.
- Gauges all died, and the air blower ('92 4x4)
- Need help removing cam gear from 92 V6
- Removing the bolt under the valve cover
- What fits what... 87 Toy truck 22R carb
- Parts for the 87 toy truck
- Heating Problem
- Head work on my 87 Toy
- 86 TOYOTA PU 22R ENGINE-will not idle
- nuts and bolts question
- Cd player install question
- 90 pickup 22R knocking! Plz help!!
- 1991 Toyota Question
- Check engine light after Oil change
- Bronze or Tinted glass
- 1991 pickup troubles. Ideas??
- Toyota Question
- 92 toyota pick up speed sensor problems
- front wheel bearing seal
- '91 Pickup Won't Start When Warm
- heater
- harmonic balancer bolt removal
- Transmission issues. Swap?
- 1990 Toyota Question
- 91pkup engine prob
- 91 eng prob, head gasket?
- crankshaft pulley bolt
- timming cover question
- 93 emissions connector?
- 1990 Head Gasket Repair
- open circuit relay
- Help!! water in oil?? negative liquid test
- Flowmaster
- '91 4cyl wont start
- 3.0 bullet proof head gasket????????
- 91 3.0 Liter engine swap
- power loss and check light
- 20R sounds like a lawn mower
- Rebuilt 87 22r motor problems
- 91 3.0 4x4 Starter Replacement
- Rear Main Seal
- '94 22re running hot
- front end rattle
- Leaking coolant
- 1984 yota fuel pump relay
- Cold Start Problems on 22R 2.4 Engine
- 84 yota problems.. any help?
- Ignition Switch 82' pick-up
- 86 yoda OIL IN CARB!
- 1990 Sr5 Shifting Issue
- 05 sentra headlights?
- 89 v6, which power steering fluid?
- 91 Head Gasket replacement
- R-12 to r-134 AC conversion on 89 Toyota 4x4 V-6 pickup
- 87 Toy Rebuild Kit
- 1985/86 toyota p/up blownhead gasket or a cracked block ?
- 85 buring oil
- what would it take?
- Fuel pump relay
- backfire...can n-e one help??
- trailer lights
- Thoughts on this?
- 1994 toyota code 71
- About to pick up an 82 pick-up
- Problem shifting 86 toyota pickup
- 85' 2wd pickup gone crazy
- 93 toyota valve cover gaskets
- questions about 22r/re/RET turbo swap
- 1994 blown head gasket?
- 89 v6 hard start (hot and cold)
- 94 Toyota Pickup Overheating
- Radiator HELP!!!!!
- Cheap way out (rear end)
- idle fluctuates when brake applied
- 22re coolant and oil problems
- My 89 Toyota 4X4 V6 pickup want start
- where can I find new face gauges for my dash please HELP!!
- Lifting 1983 Toyota Pickup
- How to tell
- 89 4x4 p/u 3.0
