View Full Version : Pick-Up
Pages : 1 2 3 4 [5] 6
  1. wanted
  2. Rebuild, should i go turbo??
  3. 84 Rear Brakes locking up?
  4. annoying grinding sound up front drivers side
  5. hi 1985 front suspension
  6. hi 1985 front suspension
  7. One more question
  8. best times 1/4 mile
  9. weber carbs 22r
  10. T100 vs 80's Pickup
  11. need a fuse panel diagram for 86 2wd
  12. 1987 22r lack of power
  13. 89 toyota heater fan
  14. 1985 Toyota pick up problem
  15. 1992 4Runner headlight assy removal (how?)
  16. replacing truck bed
  17. building a truck
  18. overheating??
  19. My truck idles high and low, high and low...
  20. 4x4 not engaging
  21. 1977 Toyota Pickup Probs
  22. 1984 choke problem
  23. sex sex sex sex sex sex sex sex money sex
  24. lowering a 90 toy
  25. HELP>>MORE POWER
  26. 93 4x4 22re power loss
  27. ingnition stuck
  28. stereo wiring woes
  29. 89 toyota pickup vacuum hose
  30. 1987 toyota pick-up engine seizure??
  31. tire pressure & rim size??
  32. fuel pickup tubes/lines
  33. open circut relay
  34. Oil Pan Removal w/o Removing Engine
  35. great oem engine parts source
  36. 1992 4x4 Piston Replacement Questions...Help!
  37. Bad running 89 22re
  38. Mounting a 22re on an engine stand
  39. 22re Rod Bearing sizes
  40. 85 pickup with 22r battery hooked up backwards
  41. 1991 Toyota pickup truck 4x4
  42. 92 22re engine failure swap or rebuild?
  43. Cold start low idle problem
  44. 4 wheel drive
  45. extended towing
  46. Engine Swap 3VZE
  47. 1989 Toyota Deluxe 4X4 Pickup Engine Seals Leaking
  48. Toyota rear quarter panel
  49. cd player installation
  50. 91 Pickup - rear wheel slipping? bad bearing?
  51. 77 pu won't start
  52. 87 toyota 4x4 gas tank
  53. I need help!
  54. could it be fuel pump?`
  55. 87 Pickup runs poorly when heavy on pedal
  56. 89 4W-Vibration after pinion bearing replacement
  57. Weirdest highway problem (power cut-out)
  58. Rear pinion bearing-now vibration??
  59. 84 toyota SR5
  60. theftproofing techniques for my truck
  61. Hard cold start 94 22RE pickup
  62. Break squeal
  63. help with V6 Sr5 swap
  64. 85 flatbed good project?
  65. Need Info about a 1jz conversion!!
  66. Whineing Sound
  67. Spare Tire Damnit!
  68. where to find specs in detail?
  69. 1983 Toyota charging problem
  70. 93-22RE smoking suddenly - help!
  71. Please Help
  72. Best Shop Manual - Chilton, Haynes, etc. ??
  73. rough idling and black smoke
  74. 86 p/u 22r pcv valve
  75. 35 inch tires on a...
  76. new #@$^!! problem
  77. WTB 79-84 Toyota 4x4 front calipers
  78. 86 Pickup Starter
  79. Removing Heavy Duty Springs
  80. 22rte info
  81. how to tell what used camper shell fits 92 xcab 4wd
  82. Cruise Control suddenly stopped working.
  83. squealing noise from belt?
  84. Horn not working in '94
  85. 22r
  86. oil gauge no longer working
  87. engine swaps
  88. grille guards
  89. Jackstands
  90. clutch fluid squirts out on to clutch pedal
  91. Thing under my TOY
  92. fender flares
  93. 20R rebuild ?
  94. valve cover seal leak
  95. ignition system
  96. truck noise, please help!
  97. Getting my butt kicked here!
  98. 91 Pickup Stuttering
  99. 87 toyota pickup sb MOTOR SWAP
  100. Fuel Filter
  101. ignition coils?
  102. Timing 86 22re
  103. 88 22re wont start!
  104. installing a/c
  105. supra engine in 92 yota??
  106. having problems
  107. 1986 toyota truck
  108. would MR2 turbo engine fit "2003 Hilux"
  109. Cylinder head
  110. transmission issues!?
  111. IDler Arm Bushing Question
  112. Need parts magazine
  113. 22R Carb problems??
  114. 1989 Toyota Pickup 4x4 - 3VZ-E engine
  115. Is the 22re a interfearence engine
  116. mileage
  117. This Forum Is Dead!!!!
  118. 22RE using lots of water; can't find leak
  119. Oh Shoot!!! Blue Smoke From My Engine
  120. Need Recomendation on where to buy reman 22R
  121. 86 toy ac problem
  122. Will 2 wheel drive 87 pickup doors work as replacement for a 4x4 88 pickup?
  123. Tail Light Problem
  124. 89 Truck Hard start after setting for awhile.
  125. 1994 Toyota Pickup auto tranny problems
  126. is this a good deal
  127. Radio Light
  128. Check Engine Codes
  129. 1992 Toyota Rough Idle
  130. Starter Problems?
  131. 1993 pickup 22re turns over but won't start
  132. Bad Smell?
  133. Toyota won't start after sitting for a while
  134. 86 22r
  135. Help, Heelp, Heeeelp!!!!!
  136. '87 22r won't start
  137. need some parts for 86 toyota pickup
  138. Replacing the original seats in my 81 4x4
  139. 94 4x4 needs new engine
  140. Desperatly need help with an 89 Toy 4x4
  141. pinging engine 90 toy pickup 22RE
  142. what truck are the same
  143. Loosing Brake Pressure
  144. 1981 4x4, inconsistent idle, rough ride
  145. Help! Taillight Wiring Issue
  146. pics of a custom dually rear yota pickup ?
  147. bad idle,. miss ? vacuum guage needle moves
  148. how much you get your truck for??
  149. 89 Toyota Lifted Big...good Idea?????
  150. how do i lose the open door/seatbelt buzzer?
  151. 1988 Toyota 22RE
  152. 1989 toyota ext cab
  153. need parts for 86 toyota pickup 2wd
  154. Ignition Timing on 93 Toy P/U with 4 cyl 22RE (w/A/C)
  155. finding repair panels for 1990 pickup
  156. fuel guage not working, 87 yota pickup
  157. No fuel- intermitent- please help
  158. High Idle, 22R-E to 22R
  159. were do you get parts
  160. instrument lights don't work HELP
  161. 89 toyota 22re Mass air Flow??ECU??
  162. Overheating 86' Toy Pickup
  163. what problem to look for on 4x4
  164. 92 Suspension...
  165. A/C Problem 1990 Pickup
  166. Motor!!!
  167. paint code
  168. Speed Sensor
  169. 1988 toyota bed
  170. Toyota V6
  171. Bad head gasket??
  172. push start cause timing chain to jump?
  173. 94 pickup 22RE pcv valve removal??
  174. wiper delay,is it an easy add on?
  175. 22RE California Emissions Removal
  176. timing chain
  177. Sounds like egr, but not positive,need help!
  178. Brake Light Problem
  179. motor swap
  180. Removing rust from my 1990 toyota 4x4
  181. 91 SR5 Xtra 4x4 starter clicking when starting
  182. 22RE timing chain
  183. 89' blown fuse.
  184. A/C clutch not engaging on my 90 4x4
  185. rought idle
  186. 1988 Pickup Hard Start / Overheats Highway
  187. 4cyl tach to 6cyl tach
  188. Lots of clicking
  189. Truck won't start, but POP Starting worked WHY???
  190. Temp.
  191. Vibration at 49-55mph 92 yota
  192. Low oil pressure??
  193. idling
  194. grinding noises!!
  195. Gear shifter removal
  196. Need a dash.
  197. '92 4x4: BAD rumble between 40-55MPH?
  198. 89 4x4 toyota truck starting trouble!
  199. Turbo tranny
  200. Engine Knocking!!! Please Help!!!!
  201. 86 Toyota, oil is leeking next to the clutch
  202. 90 4x4 Oil Leaks
  203. what's needed to lower a 93
  204. solenoid?
  205. Mk4 Supra rims?
  206. 1987 HILUX Diesel Turbo issues
  207. Where'd My Oil Go???
  208. Manual to Automatic
  209. Steering Gear Changeout
  210. Timing or Carberator
  211. Bad Day
  212. Truck wont start, not getting gas.
  213. headlights
  214. headlights
  215. Should I Buy This 85 Toyota 4x4????
  216. Price on a 93 P/U 4x4
  217. Need Help!! car wont start
  218. AC problem
  219. Im Lost!!!!
  220. Having a problem with 77 toyota pickup clutch
  221. 2 bbl Holley carb, 1980 20R engine
  222. HELP '89 Toyota Pick-up Won't Turn Over when Hot
  223. Oil Consuption
  224. 22R to 7MGTE engine swap
  225. 2WD Conversion
  226. 86 tail lights
  227. Front Main Bearing Replacement
  228. Trans. trouble
  229. 1994 Freeze Plug Install
  230. looking for good minitruck forum for Toyota pickups 2wd
  231. 86 Turbo Idle
  232. Auto Door Locks - how do I stop them?
  233. air bag light
  234. Scan tools for pre OBD2 toyotas
  235. Temp Gauge
  236. Brand New Toyota 22r Short Block In Factory Box Save$$$
  237. 1989 toyota pickup misfires
  238. Indiglo gauges
  239. need help with transmission
  240. Differntial -- Pinion bearings '94 Toyota P/U
  241. oil leak what to do?
  242. what can i do to make my motor run longer??
  243. Very hard to selector gear
  244. Low end lack of power engine hesitation
  245. pics of a 94 22re vaccum hoses?
  246. need a MANUAL gearbox 1991
  247. 94 Pickup Engine Surge No One Knows What it is.
  248. Racing your 22R
  249. 1981 toyota 4x4 truck. Help with putting motor toghther!!!
  250. 93 toyota pickup won't start
