View Full Version : Pick-Up
- 1986 toyota truck
- would MR2 turbo engine fit "2003 Hilux"
- Cylinder head
- transmission issues!?
- IDler Arm Bushing Question
- Need parts magazine
- 22R Carb problems??
- 1989 Toyota Pickup 4x4 - 3VZ-E engine
- Is the 22re a interfearence engine
- mileage
- This Forum Is Dead!!!!
- 22RE using lots of water; can't find leak
- Oh Shoot!!! Blue Smoke From My Engine
- Need Recomendation on where to buy reman 22R
- 86 toy ac problem
- Will 2 wheel drive 87 pickup doors work as replacement for a 4x4 88 pickup?
- Tail Light Problem
- 89 Truck Hard start after setting for awhile.
- 1994 Toyota Pickup auto tranny problems
- is this a good deal
- Radio Light
- Check Engine Codes
- 1992 Toyota Rough Idle
- Starter Problems?
- 1993 pickup 22re turns over but won't start
- Bad Smell?
- Toyota won't start after sitting for a while
- 86 22r
- Help, Heelp, Heeeelp!!!!!
- '87 22r won't start
- need some parts for 86 toyota pickup
- Replacing the original seats in my 81 4x4
- 94 4x4 needs new engine
- Desperatly need help with an 89 Toy 4x4
- pinging engine 90 toy pickup 22RE
- what truck are the same
- Loosing Brake Pressure
- 1981 4x4, inconsistent idle, rough ride
- Help! Taillight Wiring Issue
- pics of a custom dually rear yota pickup ?
- bad idle,. miss ? vacuum guage needle moves
- how much you get your truck for??
- 89 Toyota Lifted Big...good Idea?????
- how do i lose the open door/seatbelt buzzer?
- 1988 Toyota 22RE
- 1989 toyota ext cab
- need parts for 86 toyota pickup 2wd
- Ignition Timing on 93 Toy P/U with 4 cyl 22RE (w/A/C)
- finding repair panels for 1990 pickup
- fuel guage not working, 87 yota pickup
- No fuel- intermitent- please help
- High Idle, 22R-E to 22R
- were do you get parts
- instrument lights don't work HELP
- 89 toyota 22re Mass air Flow??ECU??
- Overheating 86' Toy Pickup
- what problem to look for on 4x4
- 92 Suspension...
- A/C Problem 1990 Pickup
- Motor!!!
- paint code
- Speed Sensor
- 1988 toyota bed
- Toyota V6
- Bad head gasket??
- push start cause timing chain to jump?
- 94 pickup 22RE pcv valve removal??
- wiper delay,is it an easy add on?
- 22RE California Emissions Removal
- timing chain
- Sounds like egr, but not positive,need help!
- Brake Light Problem
- motor swap
- Removing rust from my 1990 toyota 4x4
- 91 SR5 Xtra 4x4 starter clicking when starting
- 22RE timing chain
- 89' blown fuse.
- A/C clutch not engaging on my 90 4x4
- rought idle
- 1988 Pickup Hard Start / Overheats Highway
- 4cyl tach to 6cyl tach
- Lots of clicking
- Truck won't start, but POP Starting worked WHY???
- Temp.
- Vibration at 49-55mph 92 yota
- Low oil pressure??
- idling
- grinding noises!!
- Gear shifter removal
- Need a dash.
- '92 4x4: BAD rumble between 40-55MPH?
- 89 4x4 toyota truck starting trouble!
- Turbo tranny
- Engine Knocking!!! Please Help!!!!
- 86 Toyota, oil is leeking next to the clutch
- 90 4x4 Oil Leaks
- what's needed to lower a 93
- solenoid?
- Mk4 Supra rims?
- 1987 HILUX Diesel Turbo issues
- Where'd My Oil Go???
- Manual to Automatic
- Steering Gear Changeout
- Timing or Carberator
- Bad Day
- Truck wont start, not getting gas.
- headlights
- headlights
- Should I Buy This 85 Toyota 4x4????
- Price on a 93 P/U 4x4
- Need Help!! car wont start
- AC problem
- Im Lost!!!!
- Having a problem with 77 toyota pickup clutch
- 2 bbl Holley carb, 1980 20R engine
- HELP '89 Toyota Pick-up Won't Turn Over when Hot
- Oil Consuption
- 22R to 7MGTE engine swap
- 2WD Conversion
- 86 tail lights
- Front Main Bearing Replacement
- Trans. trouble
- 1994 Freeze Plug Install
- looking for good minitruck forum for Toyota pickups 2wd
- 86 Turbo Idle
- Auto Door Locks - how do I stop them?
- air bag light
- Scan tools for pre OBD2 toyotas
- Temp Gauge
- Brand New Toyota 22r Short Block In Factory Box Save$$$
- 1989 toyota pickup misfires
- Indiglo gauges
- need help with transmission
- Differntial -- Pinion bearings '94 Toyota P/U
- oil leak what to do?
- what can i do to make my motor run longer??
- Very hard to selector gear
- Low end lack of power engine hesitation
- pics of a 94 22re vaccum hoses?
- need a MANUAL gearbox 1991
- 94 Pickup Engine Surge No One Knows What it is.
- Racing your 22R
- 1981 toyota 4x4 truck. Help with putting motor toghther!!!
- 93 toyota pickup won't start
- 20r to 22re swap advise
- 91 4x4 Front End Problems
- Oil leak at head gasket.
- 92 Toyota Pickup rear end problems help
- parting out 88 pickup!!!! 4x4!!
- 1990 Toyota Pickup Cold Engine Problems...
- lowering???????
- Check engine light reset?
- 22r Turbo?
- Retrofit 1994 Pickup With A/C
- tocoma parts
- toyota pickup should i lift or lower????
- Under hood mess
- Where to find Stock Decals???? help
- Circuit Opening Relay Infomation
- 1985 Electrical locations?
- '91 p/u: looking for knoeck sensor
- heater core & dash lights 1990 Toyota Pick-up
- 4" Superlift
- Decals
- Destroy a Toyota?
- I need a complete 22RE for and 87 Toyota Pick-up
- Engine/Transmission Swap
- 1991 P/U RPM gauge
- New to Yota Pickups
- 1990 pickup
- Minitrucking 82 SR5 longbed 2x4 ? anyone
- Various Toyota Questions (94 P/U)
- 1977 Pick Up 20R Carb
- toyota chips
- blown head gasket, brand new motor?
- looking for more power head work 22re
- Can anyone recommend an engine rebuilder
- swapping 85 motor/trany into 84
- need to know the size fitting I need
- Front IFS diff with A.D.D 4:88 ratio
- 83 Toyota Pickup Charging problems
- have a few questions
- sounds
- timing
- carburator problems
- fast idle carburator/choke
- Toyota 1980 20R
- 1986 Toyoya Pick-up passenger side rear skin
- 96 accord Overheating while Idle
- changing thermostat in 1989 toyota pickup
- Poor Gas Mileage
- Need help timing a '93 22RE
- 93 toy pick up fuel pump
- Fender Flares
- 84 22R wiring diagram, ignition prob.
- Red or Green Coolant
- My 94 V-6 yota needs more power!!!!
- Culch replacment in 92' PU
- how do i beef up a 22R?
- Overheating
- Hard Left turn then a CLUNK!
- headgasket
- Spark plug gap, 1986-1988 2.4L
- 87 Toy Charge/Brake Indicator On Dash
- Instrument panel electrical problem
- 1990 Pickup Headlamp Replacement
- pace setter header for 22re
- 89 Toy PU starter problems... Please help!
- Replacement bed?
- Vacuum Booster for a 93 22RE
- Squeaky and vibration
- whats the value of a 88 pickup?
- leaky clutch
- hesitation when accelerating
- climate control no longer works
- Noise/Vibration after clutch job
- engine chatter at certain rpm range
- 3.4l in place of 3.0l
- 84 pickup OVERCHARGING Problem!! plz help
- 1986 Toyota Pick Up Stereo Wiring Diagram
- 91 Pickup Knock/Ping
- what kind of automatic transmission fluid does the 89 longbed use?
- 1993 Pickup Paint Code?
- 91 Locking Hubs
- misfiring
- 22 to 302 Engine swap?
- overheating problems!!
- 94 TOYOTA PICKUP needs some PICKUP!
- Vacume diagram fer 77 SR-5 pickup 20R
- Need help, 01 Tacoma 2.4DOHC into a 92 pickup 22R-E
- 77 trany anyone?
- Front axles
- Suspension
- Shift Knob Removal
- Auto to Manual swap question.
- 22RE Engine Swap
- Engine Swapping: TOY P/U swapping a 3.4L V6 in place of 3.0L V6
- 4 to 6
- 4wd to 2wd
- CHANGING MY OIL FILTER {please help}
- Pics of my cousins' toyotas
- vibs
- 85 Yota
- free stuff
- gibson exhaust for my 94 pickup
- Cold Air Intakes!!!
- Toyo pickup exhaust questions 87-22R
- shift knobs
- Cold Air Induction??
- Where's the Toyo PU forum???
