View Full Version : Pick-Up
Pages : 1 2 3 [4] 5 6
  1. New Engine Won't Run
  2. engine swap
  3. prime oil pump 3vze engine
  4. Wiring harness diagram
  5. Reverse lights
  6. Toy twuck with a hiccupp
  7. 1986 toyota pickup
  8. Help for my 19 yr. old son
  9. What's Normal Compression for a 22R
  10. No Trailer Brake Lights on 89 Toyota Pick-up
  11. '94 pick-up 2wd acceleration issue...
  12. Indiglo Gauges
  13. 88' pickup won't start?
  14. to 350 or not to 350
  15. 91 P/u
  16. Clutch Help
  17. 92 Toyota Truck V-6 engine lacks power, 3.0L, help!
  18. '92 4x4 with a Whine in the drivetrain
  19. 4x4 indicator light
  20. tailgate lock
  21. emissions control system cancelation
  22. V8 into the ole 83
  23. Engine swap--What clutch kit to use????
  24. Torsion bar adjustment
  25. '90 4x4 3VZE - really hard starting in damp/wet weather
  26. air bags
  27. How do I remove/install the sway bar??
  28. Toyota Classified Forum
  29. 89 22re oil in coolant resevoir
  30. 92 3.0 4x4 short bed delux.
  31. New Toyota Classified Thread
  32. 1984 Toyota Pickup
  33. Intermittent Door Rattle or suspension
  34. new electric fuel pump not working !!!
  35. need help from everyone!!
  36. need help with carb efi swap in 83 toyo p/u
  37. O2 sensor and Intake and Exhaust
  38. '85 straight axel noise in 4wd
  39. 89 Toyota 4x4 PU turns over but won't start
  40. 85 toy pu engine swap no spark
  41. 1989 toy 4x4 Intermittent Start clicks
  42. Disc brake conversion 91 2wd 22re
  43. 22RE Timing - 1994
  44. Transmission
  45. Gear Reduction help
  46. 22ret value
  47. want to buy
  48. 1992 Toyota 4WD Pickup-22REC
  49. 22re performance mods
  50. 22RE valvetrain
  51. want to buy
  52. LSPV Rod
  53. buick engine or ring and pinion swap
  54. mileage ?
  55. Off-road Tires
  56. 94 sr5 need hinge for moonroof
  57. AC problem
  58. Car bras?
  59. Rear Diff 1989 4x4
  60. 22RE Issues
  61. sagging door
  62. 84-88 wheel wells
  63. do it yourself 83 Toyota manulas?
  64. Climate control panel light dead after CD player install
  65. '92 Pickup - Removing Door Panels?
  66. Toyota 1989 4x4 / new to forum
  67. Charcoal Canister Overflow
  68. 87 Toyota 22RTEC?
  69. 81-83 trekker
  70. 1994 Pickup auto tranny problems and crappy gas milage
  71. cheap cheap dirt cheap body parts needed
  72. 1989 Toyota 4x4 truck power steering gearbox.
  73. tach install question
  74. 1991 Toyota Pickup Interior Door Panel
  75. Is this a good idea???
  76. wierd overheating problem
  77. car battery
  78. 87 toyota 4x4 22r rod bearings
  79. throttle cable
  80. water hell
  81. transmission
  82. 1989 6 cylinder. check engine light after 20mph
  83. oil leak
  84. Heater light...
  85. BAttery cables or Alternator...HELP!!!
  86. 85 toyota pickup question
  87. wiring problems...
  88. have 35x17.50x15 what to do
  89. cluch start cancle
  90. belt squeal
  91. Grinding noise when starting
  92. Oil Change Frequency?
  93. Headlight problem--very strange
  94. recycled oil in a rebuilt 22r?
  95. Oil Leak (head gasket)...How Do I Fix
  96. 94 toyota pick-up truck front shocks
  97. chirping when clutch is out
  98. 94 Toyota pick-up SR5 V6
  99. blowing fuses
  100. Crakced Block or Head gasket
  101. conversion
  102. Idle too high and too low
  103. Exhaust Help
  104. Speedometer and 4X4 On Light
  105. Tail (running) Lights Out!
  106. 1994 tachometer installation trouble
  107. 1990 Toyota 4x4 Front Alignment
  108. Barrell connectors near coil
  109. 22R-Te Ignition Timing
  110. 89 4x4 Timing Belt
  111. 1988 Toyo 4X4 clutch help needed
  112. extra cab longbed-why did toyota stop making it?
  113. timing 22re
  114. 22re engine suddenly dies
  115. How to Install Cd Player in 93 Pickup
  116. yoda problems again
  117. 22R Engine swap What years interchange
  118. Bench seat in 87 4x4
  119. HELP swap 22re in my 84 toyo and then turbo
  120. Downey Header On 3.0 Auto
  121. 86 Toyo PU Minor Starting Problem
  122. seats in a truck bed
  123. I Need One!!!!
  124. 89 Toyota PU been sitting, won't turn over. Possible kill switch?
  125. dashboard removal?
  126. what trucks are the same
  127. lifting a 2wd '85 yoda
  128. Engine specs
  129. Tranny wont shift into high gear
  130. Low rpm misfire - 91 22RE
  131. 1994 Toyota Pickup 4x4
  132. grease like sludge in radiator HELP!!
  133. Vibration between 45-55 mph 91 2wd shortbed
  134. Manual tranny pops out of gear
  135. Looking for a blue v6 Ext cab Toyota 4x4 89-95 in Tacoma/Seattle!!
  136. Truck for me?
  137. 94 toyota 4x4 electrical problems
  138. 22r vs 22re
  139. jackin up a '80 yota
  140. rough idle on 86 22r
  141. in need of header
  142. How to install tachometer in 93 pickup
  143. Ticking sound
  144. 'Yota problems
  145. wanted
  146. Rebuild, should i go turbo??
  147. 84 Rear Brakes locking up?
  148. annoying grinding sound up front drivers side
  149. hi 1985 front suspension
  150. hi 1985 front suspension
  151. One more question
  152. best times 1/4 mile
  153. weber carbs 22r
  154. T100 vs 80's Pickup
  155. need a fuse panel diagram for 86 2wd
  156. 1987 22r lack of power
  157. 89 toyota heater fan
  158. 1985 Toyota pick up problem
  159. 1992 4Runner headlight assy removal (how?)
  160. replacing truck bed
  161. building a truck
  162. overheating??
  163. My truck idles high and low, high and low...
  164. 4x4 not engaging
  165. 1977 Toyota Pickup Probs
  166. 1984 choke problem
  167. sex sex sex sex sex sex sex sex money sex
  168. lowering a 90 toy
  169. HELP>>MORE POWER
  170. 93 4x4 22re power loss
  171. ingnition stuck
  172. stereo wiring woes
  173. 89 toyota pickup vacuum hose
  174. 1987 toyota pick-up engine seizure??
  175. tire pressure & rim size??
  176. fuel pickup tubes/lines
  177. open circut relay
  178. Oil Pan Removal w/o Removing Engine
  179. great oem engine parts source
  180. 1992 4x4 Piston Replacement Questions...Help!
  181. Bad running 89 22re
  182. Mounting a 22re on an engine stand
  183. 22re Rod Bearing sizes
  184. 85 pickup with 22r battery hooked up backwards
  185. 1991 Toyota pickup truck 4x4
  186. 92 22re engine failure swap or rebuild?
  187. Cold start low idle problem
  188. 4 wheel drive
  189. extended towing
  190. Engine Swap 3VZE
  191. 1989 Toyota Deluxe 4X4 Pickup Engine Seals Leaking
  192. Toyota rear quarter panel
  193. cd player installation
  194. 91 Pickup - rear wheel slipping? bad bearing?
  195. 77 pu won't start
  196. 87 toyota 4x4 gas tank
  197. I need help!
  198. could it be fuel pump?`
  199. 87 Pickup runs poorly when heavy on pedal
  200. 89 4W-Vibration after pinion bearing replacement
  201. Weirdest highway problem (power cut-out)
  202. Rear pinion bearing-now vibration??
  203. 84 toyota SR5
  204. theftproofing techniques for my truck
  205. Hard cold start 94 22RE pickup
  206. Break squeal
  207. help with V6 Sr5 swap
  208. 85 flatbed good project?
  209. Need Info about a 1jz conversion!!
  210. Whineing Sound
  211. Spare Tire Damnit!
  212. where to find specs in detail?
  213. 1983 Toyota charging problem
  214. 93-22RE smoking suddenly - help!
  215. Please Help
  216. Best Shop Manual - Chilton, Haynes, etc. ??
  217. rough idling and black smoke
  218. 86 p/u 22r pcv valve
  219. 35 inch tires on a...
  220. new #@$^!! problem
  221. WTB 79-84 Toyota 4x4 front calipers
  222. 86 Pickup Starter
  223. Removing Heavy Duty Springs
  224. 22rte info
  225. how to tell what used camper shell fits 92 xcab 4wd
  226. Cruise Control suddenly stopped working.
  227. squealing noise from belt?
  228. Horn not working in '94
  229. 22r
  230. oil gauge no longer working
  231. engine swaps
  232. grille guards
  233. Jackstands
  234. clutch fluid squirts out on to clutch pedal
  235. Thing under my TOY
  236. fender flares
  237. 20R rebuild ?
  238. valve cover seal leak
  239. ignition system
  240. truck noise, please help!
  241. Getting my butt kicked here!
  242. 91 Pickup Stuttering
  243. 87 toyota pickup sb MOTOR SWAP
  244. Fuel Filter
  245. ignition coils?
  246. Timing 86 22re
  247. 88 22re wont start!
  248. installing a/c
  249. supra engine in 92 yota??
  250. having problems
