View Full Version : Pick-Up
- Four wheel drive not good
- Emissions Problems of Carb 83 22r
- 83 Tranny Problem
- Gas pedal dies around 55mph; returns at 50
- high oil pressure 85+psi
- starting problems
- Oil Pan Leaking
- 22re rebuild/hole identification
- please help 89 toyota trouble
- 22re engine swap questions
- Back in the GAME !
- Transport
- noobie toyota owner
- bucking / hopping forward intermitently
- head gasket or what? water disappearing
- i want to take the EGR off my 22re
- Lower my Toyota Pickup
- Starter problems
- Weird overheating issues
- My p/u won't start
- Lowering a 93
- lokking for advice
- Need a little help cause I'm a tool.
- Engine and trans Identification
- Lifting a 91 22RE
- S-AFC possibilities?
- strang idle/stalling when cold
- Video you guy's might like (high speed only)
- really stiff suspension
- Heating cat? or need timing adjust?
- how many miles do you have on your yota?
- 1994 4x4 pickup Rattle/Growling noise
- Motor Swap!!
- 92' pick-up leak.
- Need advice for a 3.0 motor swap
- 1984 Toyota 22R not Charging
- 88 shift on the fly?
- codes need help
- 1985 22r running bad on low rpm... help please
- 85 or 88 pickup
- Exhaust help
- Combined Toyota Factory Truck Maintenance Manuals
- Help 1985 toyota 4x4 pickup electrical prob!
- 91 22re wont idle after its warmed up
- 20r trannie
- Still no overdrive
- Any suggestions on crate engines?
- 93 4x4 fuel relay problem
- Starter keeps turning after the ignition is turned off
- pickup not running
- 1993 Toyota P/U problem.........
- New Bed
- which tires for my rims
- Please Help
- eratic idleing
- Timing problem??
- Intermittent no start problem
- road shake
- Wheels and Tires question
- slow acceleration, poor fuel mileage, erratic Scanner readings
- Loud tap/ping noise
- 1990 pick-up 4x4 won't shift
- 87 Toy parts
- 1993 toyota idleling problem
- 81 truck 4x4 electrical problems help!
- idleing problem
- parts for a NA street 22RE engine
- Overdrive
- what parts should i get for a NA street engine?
- crashed my 89 toyota 2wd pickup - help
- GM radiator????
- cleaning coolant out of engine/oil
- starter
- I turn the brake off but its light still stays on...
- 94 Pick-up wont idle, backfires
- where to get rims
- banging sound 90 4X4
- 1982 pickup starting problems
- wiring for clock on 86 pickup
- Cup Holder!!!!!!
- O2 sensor issues
- coverting transmissions
- transmission problems
- Replace Head Gasget
- Where to buy antenna?
- matching heads
- No heat in pickup?
- matching heads
- Engine swap 92 22re to 88 22rte
- 91 Toyota 4x4 3.0 liter idle problems
- 22re top end rebuild
- looking for head
- head
- timing chain getting frusterated.
- 21R Rebuild
- vaccum diagrams?
- spark plug will not stay in head
- more bang for the buck
- Rebuild or rebuilt 22RE?
- What size bolts? My starter just fell off....
- 93 2wd Tire Size
- muffler and tailpipe replacement?
- Head gasket replacement, 22R. Any quirks???
- 93 Toy P/u 22re Vacuum Hose Diagram
- Diesel Forums?
- Best headers?
- Best plugs and wires for 22RE
- Spark Plug Gap 22R 1986 4x4 PU
- no electricity to fuel pump
- tranny snag
- looking for a little help with the 22re
- will it hold?
- tacoma engine swap
- 87 pick-up stalls after engine warms up
- wheel travel and gear ratio?
- toyota wiring diagram
- is there any 22r drag racers out there
- Anyone ever done a 3.4 swap???
- Where is my O2 sensor?
- tranny fluid
- seafoam, seafoam, seafoam, seafoam
- what engine??????????
- Does any one have any ideas?
- 88 22RE spark plug gap
- how do i install a ct26 turbo to a 1991 22re
- $8 Subscription to Car & Driver, Motor Trend, and Road & Track
- 86 pickup heater parts
- 92 3.0L getting bad gas milage
- 85 pickup engine swap
- what years are the same?
- truck
- Interior bucket seats???
- engine diesles (keeps running
- water in my oil, engine running hot
- how do I bleed the gas rail
- 92 Toyota rims
- thanks
- Code help...
- Truck is driving me crazy........
- 86 toyota p/u wont start
- Front brakes freeze up after driving!?!
- I want to turbo my 1993 22R
- Transfer Case Stuck In 4wd
- 1992 deluxe toyota pick-up
- 84 toyota pickup-starting/electrical problems
- Excessive Pinging
- 1985 Hilux 4 speed to 5 speed ?
- Driving without doors
- 85 toyota aftermarket gauges
- 82' yota sr5, stereo removal and installation!
- 22r-e S-AFC?
- 1990 toy carburated running poorly
- 89 toyota will not turn over W/ new starter, batterie, and alternator
- 22r to a late 80's Supra Swap?
- 22r Can you convert to EFI(fuel injection)
- My Pick-up rides ROUGH!!!!!!
- rough starting
- gargling gas
- 82 22r carb problems
- 5 bolt to six bolt swap questions (hubs/rear end)
- Replace 5 bolt 1 ton rear end with 6 bolt
- 22r-e to 3RZ?
- No dash lights...HELP!
- Speedo cable replacement?
- 1984 Pickup, how to install antenna
- Toyota Diesel wont turn over
- Rebuilding 1986 Pick-up 22R engine with A/C
- 1992 2WD llits kit
- Steering wheel...?
- 82 toy truck charge lamp
- 1986 22R-E Rough Idle
- timing chain too short or too long
- seized fill plug
- timing chain questions
- stereo wiring probs
- 1984 2WD pickup, adjusting choke...what allen wrench size?
- Any A/C guys out there???
- release same as slave?
- Rotor to Pad Clearance
- 93/4x4/offroad/parts/money
- Brakes-Can't get piston back in caliper
- 22r-e timing chain problem
- 5.0 engin swap
- 1991 4X$ Toyota Pickup hard to start when warm
- How to disconnect speedo cable...1984 Pickup
- No dash lights and won't start
- Throttle senser
- Rotors
- 1984 2WD pickup, tracking down a short...isolating circuits
- 3.0 v6 swap to a carb. 22r need help!!!!
- Quick shout out
- Cigarette lighter help
- Brake pedal travel
- Problems with 1982 Toyota 4x4 pickup
- Clutch Fan?
- 89 toyota pickup V6 EFI Won't start
- 89 toy pkup 6cyl Ignition Ignitor test
- 89 Toy Pkup 4x4 6cyl (3vz-e) No Spark
- '92 toyota pickup won't start
- 1990 Toyota Pickup 22R fails CO2 emissions
- emergency brake light
- big lose of power running lean help
- ignition timing irratic
- Preformance headers
- 92 4wd gas mileage
- Turn sigs, fuel gauge, temp gauge don't work, Haz light works 1984 2WD pickup
- 22r to 22re engine swap
- Tire Noob Question
- coolant leak
- Power Steering
- differences in years
- Front Differential Removal
- 86 toy 4x4
- Wiring Diagrams
- 92 having problems
- 92 4wd 3.0 ext cab 57000 having issues
- Parking/Emergency Brake BROKE?!?!
- problem with ignition
- High and low idiling after warm up
- Click / Flap Noise
- Heater core
- 85 4X EFI Firing only 1 & 3. Test says RPM Help
- date of manufacture
- Congested noise at high rpm
- 86 toyota pickup, clutch swap, questions
- clutch woes
- tacoma or Regular PICKUP???
- 1989 Pickup Oxygen Sensor mounting nuts.
- 1989 4WD 22RE real high idle!
- 1989 toyota pickup- gas leaking out of charcoal cannister
- need advise on tranny and possible motor swap
- 22re makes loud tapping sound
- '92 Toyota Engine hard to turn over and will not start
- 91 Sr5 V6 3vez Does Not Start
- front end tie rods for steering...how hard is this to do?
- overheating problem!
- 1988 toyo p/u 3.0 smokes badly from oil filler and has no power
- Hesitation, is this fuel related?
- Backfires Crazy Like
- Is it the brake booster?
- 1989 Toyota pickup 22RE won't fire
- Ring and pinion issue
- how to change cluster light
- 94 pickup gear shift removal
- Totally f****d up 88 toy 4x4 pickup....please help?
- how important is it to replace the timing chain?
- whistle / ringing noise at idle ??
- Excelleration Vibration
- New Engine Won't Run
