View Full Version : Pick-Up
- '85 1-Ton
- '89 Toyota Pick-up "Fuel pump - Sending unit??"
- 1990 22RE Temp went to 3/4 hot, then drop to normal. Why?
- obd1 or obd2?
- 22re Gas mileage
- 1990 toyota truck problem
- 93 PU 2WD-Emmissions Label
- 4.3 swap radiator?
- Need help making the decision on 22RE engine swap
- 1983 Toyota pickup electrical issues
- 1987 toyota 4runner power windows
- Oil pump o-ring leak...
- How much
- 89 Toyota Pickup 22re Radiator Problem
- how do i get codes on 86 yoda 22r truck?
- Body Swap... 81 yota 4x4 to a 2wd body
- help 86 toyota problems
- Steering Damper?
- CD Player Installation for 1980 PU
- EGR situation
- 93 22re will not idle
- Missing Mirror
- removing bell housing bolts
- Losing coolant
- Bad park-neutral switch on 89 4x4 automatic pickup
- 1994 fuel filter location-help.
- Rigging relay to starter to overcome intermittent starting issue on 4x4 Toyota
- Park-neutral switch on 89 4x4 Toyota w/ intermittent starting problem
- Compression repair product for 89 4x4 V-6 toyota
- compression readings
- Bleeding clutch on 86 50r? truck
- 22re motor swap HELP
- Accessories for 2007 Toyota Hilux in USA
- Dumby lights driving me up a wall!!!
- Swap Help
- What is this part on an 89 4x4 V-6 Toyota pickup (xcab/deluxe model)??
- New owner with shock questions
- 1989 Toyota xcab V-6 deluxe pickup--starter
- 89, V6, Doesn't Start
- What have you done and what has worked?
- 94 22r idle high, brake makes idle fluctuate
- What should I do?
- 1989 Instrument cluster
- 86 Yoda, Coolant Temp Gauge
- Manual trans to automatic
- '89 22re won't start
- Speedometer noise on 1989 extra cab 4x4
- OD problem with 86 Toyota
- 1989 Toyota 4X4 4 speed SR5 pickup won't start
- check engine light
- Question about overheating, 86 Yoda Pickup
- holes in manifold?! input appreciated
- Which bed
- Idler Arm Replacement 86 yoda Pickup
- 94 pickup part out
- 1994 4x4 Pick Up Toyota
- 20R distributer points problem? truck wont start
- 86 4runner starting problem
- performance chips / ECM mods
- crankshaft pulley bolt
- 22 r harmonic bal removal
- Thought I was a Mechanic!
- New Here, Questions!
- 22R running crazy.....help
- vsv locations 94 22re pu
- U-Joint help please
- metal pipes
- Interior for a 1985 Toyota Truck
- Pollution equipment on 86 22R
- Hard Start when warm.
- 1980 toyota pickup 20R engine
- 20r/22r hybrid rocker arm binding
- 3.4 Supercharged swap into 94 Pickup
- Parking Brake
- 22re quits after 7or8miles
- Wheel and Tires
- 86 toyota
- replacing 02 sensor
- no compression at all
- inner frame dirt
- water leak
- warm idle, or lack there of
- oil pressure gauge
- clutch pedal, to far forward
- asking price for 88
- 88 pickup, about asking price
- swap 22re for a 22r
- 1991 Shortbed - Should I buy this???
- 88 manual transmission
- 22r won't heat
- 93 4x4 clutch
- 88 22r fuel pump return problem??
- 86 toyota 4x4 (22R) Gradual Overheating
- tach wiring
- 22re rebuilt engine
- 88 Pickup/ how easy to fix/parts
- 1980 Toyota Pickup Parts?
- Problem starting 92 toyota pickup
- 86 toyota pickup 22r automatic electronic overdrive
- Will a 22re stand up to a small turbo
- 86 pickup w/ 22R temp goes to 220 initially then back to 190
- how simple fixes can ruin a day.
- carb adjustment
- 92 Toyota Pickup 22RE turns over won't start
- Speedometer Not Working When First Starting Off
- 95 Excab 6cyl 2wd code reader
- bleed fuel line?
- dimensions of the 3v
- Removing heater control assembly, 1984 pickup
- tranny
- New truck, looking for a little more performance and efficiency
- Vacuum Diagrams
- rough idle '94 pickup
- cooling problem in '94 pickup
- 93 toyota pick up 4cyl. knocking and squealing??
- Help me please?
- Idle keeps me cold!
- How do I remove oil pan 92 Toyota pickup?
- Toyota pickup audio speakers
- 91 22 RE spark knock problem
- 1986 pick up
- 22re engine rebuild or new
- Not in the manual, does anyone know what it is called?
- Shock Problem on 2WD with Suspension Lift
- 92 SR5 keeps blowing the EFI fuse
- $4.89 Head Gasket Repair, Done!
- I need help Boys!
- Help
- 1989 Toyota Pick-up NEED HELP
- fuel system question
- Fuel Filter Location?
- 89 hard starting?
- 1989 rearend
- Toyota pickup won't turn over, just whirring noise
- 1989 In Dier need of HELP!!!!
- Fair Estimate Suspenion/Steering Work???
- what is a fair price for clutch work.
- 1986 Toyota Truck Dual Rear Wheels Brake Drum Removal
- Carbs: TO remove or not to remove is the ?
- engine code 21 and 51
- 22RE using oil
- im new to the truck game.
- strange chirping noise
- 86' starting & running problem, carberator
- 93 starting problem
- Just a wild hair!!!
- Idle Problem
- Room to drill?
- PCV Hose
- muffler horsepower
- noob with questions
- Turbo boost fuel cut off
- 22RE Emissions Removal ?
- power upgrade on 22re!!
- 1987 4x4 toy turbo pickup problem
- 22re serpentine conversion
- Enging noise, one last resort
- 22RE 20 Miles per Gallon
- 84 Toyo Pickup with no brakes
- swap out 22re
- "Turbo-lag" on a 22RE
- 87 Spits and sputters
- radiator question for 86 pickup
- Mechanical Fuel Pump
- Mustang Rims
- Different Valve Covers??
- 1994 pickup making loud noise
- tips on 4x4 front brakes!
- '94 toyota pickup gauges not working
- Toyota Pickup Desiccant Dryer Replacement
- 1980 pickup upgrades
- 22R rebuild kit
- Newbie here with some questions....
- my brake light on the dash wont turn off
- 22R vs.22RE Engine
- would 35's fit my 84 yota with 5inches of lift
- 1985 4x4 22r running rough please help!
- 1987 Pickup Intermittent starting problem
- surges badly when floored
- my air and heater switches done light up
- how would i sawp a 22r for a 302 into my 84 yota 4by4
- 1989 toyo4x4 how much?
- Ignition Question?
- 86 22rte turbo 2.4
- 93 5 speed 2wd?
- custom intake
- Multiple electrical failure
- oil gauge pressures
- making my truck louder
- Overheat causes valve damage?
- Vacuum line diagram
- How Do I get a title?
- dumb question but i need to know
- 1991 power steering
- Idle, exhaust, oil pressure: Is my engine dying?
- I have an egr system question
- loss of ignition power on a 81 4x4
- smoky emission smelled like coolant....
- 1982 22R vs 1989 22RE
- Clicking Sound
- Rear disc brake conversion
- EGR: Is it really necessary?
- 20r to 22r swap question
- Replacing front brake pads...
- looking for helpful links
- 93 22re auto trans shift points
- rough idle
- windshield question
- recurring exhaust leak- any ideas?
- is it possible..
- Towing my 1993 SR-5 4x4 Manual 5 Sp.
- Adjusting rear brakes, 1984 pickup
- tire size
- building 85 trail rigg
- Which is the Better Auto Trans?
- 1984 2WD pickup, adjusting the choke...rivets???
- stereo problems
- o/d solenoid death
- 1992 Toyota 4x4 V6 wont' start, need help.
- v-8 conversion
- Almost done with mine. Need help
- need help
- stereo problems
- canopie size
- Crankshaft bolt removal
- Spark plug gap for 87 pickup - 22R
- Soft brake pedal - no fluid loss
- Brakes Nitemare!!
- injector wire identification question
- first tym buyer air bags
- Jet chip ???
- Need a fuse diagram for an 88 toy
- 1980 4X4 Dies After Restart
- 1977 Toyota SR5
- New here: '86 SR5 (Help?)
- brake & battery light coming on???
- in-destructible '91 toyota
- 90 p/u shock absorber recommendations
- 1989 Toyota 4x2 - missing out
- Spark situation ideas Welcome.
- 1986 Toyota poor accelaration good compresion
- transfer case leaking, can't shift all the gears..
- Clutch Problem
- '92 - dash lights on right side out
- Pinging like crazy
- toy p/u wont start in the rain
