View Full Version : '88 - '91 Civic / CRX
  1. zc swap 1.5 to 1.6
  2. 90 hatch swap
  3. tryen to fix somebod els mess
  4. 90 civic hb dx battery light on while runnin
  5. Upgrading Injectors
  6. Really need help Major Issues!!
  7. Car died and oil in spark plug wire tube
  8. 89 hatch w/d16y7 wont rev over 4000rpms
  9. does a civic have the fuel/igniton relay??
  10. 88 civic sedan motor mounts
  11. Honda Civic problem :(
  12. Code 43 Fuel Supply System Help!
  13. Need D15b2 answers buying motor
  14. 91 Civic runs rough after timing belt fix
  15. battery drain
  16. can u put a zc sohc non-vtec head (complete) on a stock 89 engine? and good idea?
  17. 89CivicDX2door-Coolant overflow problem
  18. roaring noise
  19. Just bought another CRX, having issues...
  20. itr tranny on b16a
  21. 91 Civic HB smoking.
  22. Walker mufflers
  23. Halfshafts
  24. 91 civic 1.5 eng tensioner bearing replacement
  25. Totally stumped with my ecu problem
  26. wiring harness
  27. hey guys, long time no see!
  28. Rear engine mount 91 civic
  29. another idle issue...sorry
  30. bunch of problems
  31. CRX HF sputters when warm
  32. 90 Civic Sedan Rear Wheel Bearing Replacement???
  33. Ball Joint Torque????
  34. Need to replace upper control arms. How to????
  35. 1991 honda accord
  36. reusing a head gasket
  37. Energy Suspension or Prothane bushings??
  38. Rust Repair
  39. curious starting issue
  40. **Best Place to Find**???
  41. civic si hatch 89. will a non power steering rack fit instead ov powersteering one
  42. I dont even know
  43. Good Price for a d16a6 installed?
  44. Shocks + Springs
  45. b20 engine questions
  46. 89 civic started a light fire!!
  47. mpfi swap
  48. 1989 Civic Starting/running problem
  49. front rear crossmember
  50. Hydro trans mounts
  51. 1985 crx hf problem
  52. Eird oil leak
  53. maybe axle...i dont know
  54. That can ruin your day....
  55. ITR tranny on a b16a sir 1
  56. Rear engine mount 91 civic
  57. 1.5/1.6 part compatability
  58. Steeri9ng shimmy
  59. Which size silencer?
  60. b16a slight backfiring and pops after header install
  61. cant fight it
  62. Quarter panel repair
  63. Doors squeaking/grinding??
  64. CRX DX Rear Bushing replacement
  65. 89 crx wont start
  66. Just replaced both axles, and they're clicking/rubbing
  67. zc sohc
  68. error codes!
  69. EF Honda Meet in PA!! July 12th!!
  70. build question
  71. No Start after car has been running and shut off
  72. Driving, and the engine dies
  73. A/c help
  74. Alternator interchangeability
  75. cornerlight hell
  76. fuel pump cutting
  77. honda civic 1989 (SI) hatchback..b16a conversion.. HELP
  78. car wont start and i need to sell it
  79. mpfi
  80. What rims are these?
  81. 91 civic dx sapw with b18c1
  82. HELP me PLEz b18c1 info problems
  83. Got bored and lowered the wagon today!! (pics)
  84. timing mark mystery
  85. Sparks out exaust, Won't rev over 3,500!
  86. 91 Civic idle
  87. obd1 injectors
  88. Valve Cover Gasket Issues
  89. 1.6 valve v-tak W/ slowness switch
  90. civic/crx tail light swap?
  91. fender removal
  92. CRX Lowered the right way
  93. CRX Transmission oil....
  94. Battling the Burning oil..
  95. vibration/steering wheel off ceter
  96. help ecu and alternator fuses keep blowing
  97. What the heck is wrong with my civic?
  98. 89 civic hatchback fuel problems???
  99. 1988 CRX DX oil leak, how do you fix it?
  100. 91 lx gauges don't work
  101. Car is making a Grinding/whistling noise while driving
  102. Timing Belt Question, 2
  103. fuel pump location
  104. 91 LX rear windows are about to make me mad......
  105. b-series noob question
  106. need some code help and a main relay ?
  107. h23 swap 4th gen civic?
  108. Pan Seat Swap
  109. 88 civic fan question
  110. got pic's of my engine bay,What is it?
  111. How do I up load pics????
  112. intermediate shaft? Where?
  113. Gauge swap question
  114. MPFI Swap
  115. tranny ground?
  116. ignition problem
  117. Bitch pin
  118. Rough Idle and shuts off?
  119. I need a crank for D16a6!!!!
  120. Frying Alternators!!
  121. identifying intermediate shafts
  122. Missing vacuum hose?? *pic*
  123. can a pm6 ecu(obd0) run obd1 fuel injecters-
  124. steering problem
  125. 88-91 crx civic speaker door pods
  126. just got a 88 crx,what do i have?
  127. Timing belt question
  128. Motor install with Tranny on or off?
  129. da cluster in ef
  130. b16a1 into 89 std hatch
  131. 91 CRX check engline light when idle
  132. Another code 1 question.
  133. 91 1.5L Code 1 and no start are they related?
  134. 91 Hatch with DPFI needs new motor
  135. Happy Birthday Dropzone!!!
  136. 91 Civic Check Engine Light procedures
  137. OBD-0 to OBD 1 Conversion
  138. just a quick ef question
  139. hood pin question
  140. a 4g hatch- complete interior(including spare tire).
  141. cant find a good idle
  142. code 17
  143. 90 civic fuel prob
  144. new headers problem
  145. lights going crazy, could use some help
  146. bad idle, and elc problem
  147. stock d16z6 and the d15b vtec(w/pm6 rods) - w/ p29 dome pistons
  148. 90 civic / high rpm's or no start
  149. K24 Vtec V.s. G23 Vtec
  150. Stock Axle wrong size 91 civic
  151. System short
  152. Starting problems?
  153. oil cooled vs oil and water cooled turbo
  154. D15 help
  155. rear suspension combo questions
  156. please help me get my b16 90si running
  157. turbo oil return line ect.
  158. H22A to Civic coil connection question
  159. White Faced Gauges (Km/H)
  160. Is it possible to swap a 20 spline 4 speed m/t input shaft into a 21 splined si trans
  161. Ammeter, oil pressure, water temp
  162. Random plug and integra console swap
  163. da vs ef rear lca
  164. Honda Swap Meet **pics**
  165. switched 12V problem
  166. I have 1 pm9 m/t ecu and 2 pm5 a/t ecu's and a d15b2 w/ a m/t.
  167. A question
  168. 88-91 D15
  169. HELP! Car alarm removal gone wrong....
  170. Will 88 crx parts fit a 91 Crx
  171. reverse lights?????
  172. question
  173. Need a helping hand North Chicago
  174. b20a5
  175. 89Civic1.5DX Hatch - Replace hood
  176. 89Civic1.5DX Hatch - Engine coolant Drain Plug
  177. Steering Rack differences
  178. A few '91 LX questions
  179. suspension info
  180. timing belt question
  181. hand brake light not working
  182. give me your opnions
  183. car failed smog
  184. B18B1 OBD2 to OBD1
  185. Civic89DX-Emission Test Failure.
  186. oil pressure problem
  187. Engine Swap
  188. car wont start
  189. Horrible gas mileage... Any ideas...
  190. Fuel Problems??
  191. Fuel Problems??
  192. 1990 SI Electrical Problems
  193. sway bar upgrades
  194. Rear Mud Flaps
  195. traction bars
  196. My car wont stay on :(
  197. lsd tansmission?
  198. injector Q's
  199. air/fuel
  200. b16a1 swap question
  201. GT Live '08 @ VIR
  202. clutch problem
  203. Temp gauge problem
  204. MPFI Conversion for Dummies
  205. 91 Civic 1.5L Stalling problem...HELP!
  206. Where to ground on Thermostat 88 crx dx
  207. 89CivicDX1.5 - Question on fuel
  208. How hard is it to replace crank/cam seals?
  209. NEW FAQ: Please read before posting! That means you!
  210. got some work done today
  211. Removal of Control Arm/Bushing
  212. How to install radiator? I removed it, just want to see best way...
  213. obd0 to 0bd1?
  214. Best Crx Dx Swap!!!!!!!!!!!!
  215. Whistling noise in intake... WTF?!?
  216. 90-99 spark plug question
  217. Axle question
  218. 1990 civic dx swap please read and help
  219. B-swap confusion
  220. Air intake for 88crx dx???
  221. 90 Civic - flooding/fuel in intake manifold
  222. Honda Axles
  223. 88 crx dx coolant question
  224. 88 crx dx temp gauge
  225. Weight Reduction - Ceramic Heater core.
  226. civic ac/heater
  227. My own MPFI swap
  228. Water for fuel... the longest single post I've ever made.
  229. Smoke coming from steering wheel
  230. New toy
  231. Body part question
  232. 2 questions...crx sunroof and motor
  233. A few wiper questions
  234. Serious gas smell
  235. CRX question
  236. hondata s300
  237. B18 crank pully rubbing on traction bar!!
  238. wiring problem
  239. ODBI Distributor wiring
  240. 91 civic distributor swap
  241. Suspension questions CRX
  242. 92-95 zc sohc swap
  243. What's with my Honda Accord? ! HELP PLZ! !?
  244. 88 Civic DX Cluster... swapped, now runs rough!???
  245. 90 civic "zc" fuel problems
  246. 90 Accord
  247. Anyone Instrested In A Jeep Cherokee?
  248. Water Temperature Sender Attachments
  249. adjustable fpr
  250. need motor swap info on my 88 si'
