View Full Version : '88 - '91 Civic / CRX
  1. 91 civic 1.5 eng tensioner bearing replacement
  2. Totally stumped with my ecu problem
  3. wiring harness
  4. hey guys, long time no see!
  5. Rear engine mount 91 civic
  6. another idle issue...sorry
  7. bunch of problems
  8. CRX HF sputters when warm
  9. 90 Civic Sedan Rear Wheel Bearing Replacement???
  10. Ball Joint Torque????
  11. Need to replace upper control arms. How to????
  12. 1991 honda accord
  13. reusing a head gasket
  14. Energy Suspension or Prothane bushings??
  15. Rust Repair
  16. curious starting issue
  17. **Best Place to Find**???
  18. civic si hatch 89. will a non power steering rack fit instead ov powersteering one
  19. I dont even know
  20. Good Price for a d16a6 installed?
  21. Shocks + Springs
  22. b20 engine questions
  23. 89 civic started a light fire!!
  24. mpfi swap
  25. 1989 Civic Starting/running problem
  26. front rear crossmember
  27. Hydro trans mounts
  28. 1985 crx hf problem
  29. Eird oil leak
  30. maybe axle...i dont know
  31. That can ruin your day....
  32. ITR tranny on a b16a sir 1
  33. Rear engine mount 91 civic
  34. 1.5/1.6 part compatability
  35. Steeri9ng shimmy
  36. Which size silencer?
  37. b16a slight backfiring and pops after header install
  38. cant fight it
  39. Quarter panel repair
  40. Doors squeaking/grinding??
  41. CRX DX Rear Bushing replacement
  42. 89 crx wont start
  43. Just replaced both axles, and they're clicking/rubbing
  44. zc sohc
  45. error codes!
  46. EF Honda Meet in PA!! July 12th!!
  47. build question
  48. No Start after car has been running and shut off
  49. Driving, and the engine dies
  50. A/c help
  51. Alternator interchangeability
  52. cornerlight hell
  53. fuel pump cutting
  54. honda civic 1989 (SI) hatchback..b16a conversion.. HELP
  55. car wont start and i need to sell it
  56. mpfi
  57. What rims are these?
  58. 91 civic dx sapw with b18c1
  59. HELP me PLEz b18c1 info problems
  60. Got bored and lowered the wagon today!! (pics)
  61. timing mark mystery
  62. Sparks out exaust, Won't rev over 3,500!
  63. 91 Civic idle
  64. obd1 injectors
  65. Valve Cover Gasket Issues
  66. 1.6 valve v-tak W/ slowness switch
  67. civic/crx tail light swap?
  68. fender removal
  69. CRX Lowered the right way
  70. CRX Transmission oil....
  71. Battling the Burning oil..
  72. vibration/steering wheel off ceter
  73. help ecu and alternator fuses keep blowing
  74. What the heck is wrong with my civic?
  75. 89 civic hatchback fuel problems???
  76. 1988 CRX DX oil leak, how do you fix it?
  77. 91 lx gauges don't work
  78. Car is making a Grinding/whistling noise while driving
  79. Timing Belt Question, 2
  80. fuel pump location
  81. 91 LX rear windows are about to make me mad......
  82. b-series noob question
  83. need some code help and a main relay ?
  84. h23 swap 4th gen civic?
  85. Pan Seat Swap
  86. 88 civic fan question
  87. got pic's of my engine bay,What is it?
  88. How do I up load pics????
  89. intermediate shaft? Where?
  90. Gauge swap question
  91. MPFI Swap
  92. tranny ground?
  93. ignition problem
  94. Bitch pin
  95. Rough Idle and shuts off?
  96. I need a crank for D16a6!!!!
  97. Frying Alternators!!
  98. identifying intermediate shafts
  99. Missing vacuum hose?? *pic*
  100. can a pm6 ecu(obd0) run obd1 fuel injecters-
  101. steering problem
  102. 88-91 crx civic speaker door pods
  103. just got a 88 crx,what do i have?
  104. Timing belt question
  105. Motor install with Tranny on or off?
  106. da cluster in ef
  107. b16a1 into 89 std hatch
  108. 91 CRX check engline light when idle
  109. Another code 1 question.
  110. 91 1.5L Code 1 and no start are they related?
  111. 91 Hatch with DPFI needs new motor
  112. Happy Birthday Dropzone!!!
  113. 91 Civic Check Engine Light procedures
  114. OBD-0 to OBD 1 Conversion
  115. just a quick ef question
  116. hood pin question
  117. a 4g hatch- complete interior(including spare tire).
  118. cant find a good idle
  119. code 17
  120. 90 civic fuel prob
  121. new headers problem
  122. lights going crazy, could use some help
  123. bad idle, and elc problem
  124. stock d16z6 and the d15b vtec(w/pm6 rods) - w/ p29 dome pistons
  125. 90 civic / high rpm's or no start
  126. K24 Vtec V.s. G23 Vtec
  127. Stock Axle wrong size 91 civic
  128. System short
  129. Starting problems?
  130. oil cooled vs oil and water cooled turbo
  131. D15 help
  132. rear suspension combo questions
  133. please help me get my b16 90si running
  134. turbo oil return line ect.
  135. H22A to Civic coil connection question
  136. White Faced Gauges (Km/H)
  137. Is it possible to swap a 20 spline 4 speed m/t input shaft into a 21 splined si trans
  138. Ammeter, oil pressure, water temp
  139. Random plug and integra console swap
  140. da vs ef rear lca
  141. Honda Swap Meet **pics**
  142. switched 12V problem
  143. I have 1 pm9 m/t ecu and 2 pm5 a/t ecu's and a d15b2 w/ a m/t.
  144. A question
  145. 88-91 D15
  146. HELP! Car alarm removal gone wrong....
  147. Will 88 crx parts fit a 91 Crx
  148. reverse lights?????
  149. question
  150. Need a helping hand North Chicago
  151. b20a5
  152. 89Civic1.5DX Hatch - Replace hood
  153. 89Civic1.5DX Hatch - Engine coolant Drain Plug
  154. Steering Rack differences
  155. A few '91 LX questions
  156. suspension info
  157. timing belt question
  158. hand brake light not working
  159. give me your opnions
  160. car failed smog
  161. B18B1 OBD2 to OBD1
  162. Civic89DX-Emission Test Failure.
  163. oil pressure problem
  164. Engine Swap
  165. car wont start
  166. Horrible gas mileage... Any ideas...
  167. Fuel Problems??
  168. Fuel Problems??
  169. 1990 SI Electrical Problems
  170. sway bar upgrades
  171. Rear Mud Flaps
  172. traction bars
  173. My car wont stay on :(
  174. lsd tansmission?
  175. injector Q's
  176. air/fuel
  177. b16a1 swap question
  178. GT Live '08 @ VIR
  179. clutch problem
  180. Temp gauge problem
  181. MPFI Conversion for Dummies
  182. 91 Civic 1.5L Stalling problem...HELP!
  183. Where to ground on Thermostat 88 crx dx
  184. 89CivicDX1.5 - Question on fuel
  185. How hard is it to replace crank/cam seals?
  186. NEW FAQ: Please read before posting! That means you!
  187. got some work done today
  188. Removal of Control Arm/Bushing
  189. How to install radiator? I removed it, just want to see best way...
  190. obd0 to 0bd1?
  191. Best Crx Dx Swap!!!!!!!!!!!!
  192. Whistling noise in intake... WTF?!?
  193. 90-99 spark plug question
  194. Axle question
  195. 1990 civic dx swap please read and help
  196. B-swap confusion
  197. Air intake for 88crx dx???
  198. 90 Civic - flooding/fuel in intake manifold
  199. Honda Axles
  200. 88 crx dx coolant question
  201. 88 crx dx temp gauge
  202. Weight Reduction - Ceramic Heater core.
  203. civic ac/heater
  204. My own MPFI swap
  205. Water for fuel... the longest single post I've ever made.
  206. Smoke coming from steering wheel
  207. New toy
  208. Body part question
  209. 2 questions...crx sunroof and motor
  210. A few wiper questions
  211. Serious gas smell
  212. CRX question
  213. hondata s300
  214. B18 crank pully rubbing on traction bar!!
  215. wiring problem
  216. ODBI Distributor wiring
  217. 91 civic distributor swap
  218. Suspension questions CRX
  219. 92-95 zc sohc swap
  220. What's with my Honda Accord? ! HELP PLZ! !?
  221. 88 Civic DX Cluster... swapped, now runs rough!???
  222. 90 civic "zc" fuel problems
  223. 90 Accord
  224. Anyone Instrested In A Jeep Cherokee?
  225. Water Temperature Sender Attachments
  226. adjustable fpr
  227. need motor swap info on my 88 si'
  228. no pedal when i crank the car
  229. running rich
  230. Don't make this mistake
  231. headlight turn signal trouble
  232. Automatic seat belt
  233. 89 civic
  234. 89 civic 1/2 tank stalls
  235. would 92-95 upper ball joint fit 91?
  236. swapping seat backs?
  237. jdm swap + smog troubles
  238. 88 CRX Si "popping"
  239. skipping and sputtering
  240. 1987 mugen crx stock
  241. what would be a good motor for my ef ?
  242. Motor Mounts??
  243. 99 civic lx green paint is fading off?
  244. what should i do to the b18a1 motor that is in my ef?
  245. b18c1 overheating and injectors????
  246. P28 ecm for mpfi conversion on d15?
  247. 91 civic Timing
  248. Axle Help - axle to intermediate shaft disconnect
  249. 94 Integra Seats in EF???
  250. Will a 5th civic coupe center console fit??
