Our Community is 662,000 Strong. Join Us.
View Full Version : '88 - '91 Civic | CRX | Wagon | Shuttlee
  1. can d15 JDM V-tec pass emissions?
  2. final drive swap
  3. obd3
  4. Need good sites
  5. think this is legit?
  6. almost running zc
  7. Accidents happen...
  8. Engine Coolant squirt all over the floor
  9. Problem with wireing
  10. shifting w/o using the clutch...
  11. What is the best dseries 1.6
  12. engine bearings....need help
  13. got into an accident with 06 civic
  14. Springs!!?
  15. Idleing Problem
  16. new 90 civic
  17. 13" wheels over integra rear brakes?
  18. Dif between HB and CRX front end
  19. IAT sensor, location?
  20. oil under engine
  21. My New Intake
  22. Steering Lock..Key Won't Turn!!
  23. Timing Issue.
  24. STD to Si tranny swap with just tranny
  25. p28 ecu question
  26. Pictures of my ride. (91 Sedan LX)
  27. Rusted Screws!
  28. Vibrating problem....
  29. Help Wid This Dumb Noise Prob!!!!!!
  30. help
  31. just my luck..........
  32. Don't you guys hate newbs like me.....
  33. Car fax
  34. Throttle Body SIZE?
  35. new to CRX
  36. battery keeps dying..
  37. throttle Body
  38. Throttlebody
  39. crx seatbelts
  40. crx dash in civic. question?
  41. ecu chip help?
  42. Max Performance w/SOHC ZC.
  43. No lowend power after rebuild
  44. turn signals not working
  45. axel question
  46. mugen body kit. asap.
  47. front end rattles pls help
  48. 91 civic hatch body
  49. cat problems
  50. New Toy
  51. ECU Choice..
  52. Problem getting worse
  53. D15B2 to D16Z6 swap need some help!
  54. oil line kit. hopes
  55. Help me find out what engine i have.
  56. Is this a good brake combination?
  57. importing a crx from the UK
  58. Question about dash fuse box
  59. Had a few questions about my Civic 91'
  60. 89 hatchback, backfiring, burning oil
  61. Multi Point over Duel Point
  62. b18a1 swap
  63. Advantages of oversize thickness head gasket?
  64. K22 Head fits?
  65. need wiring diagram for moon-roof switch
  66. need help quickly (brake/door ajar problem)
  67. Fuel sender unit
  68. Possible to swap seat backs?
  69. 88 honda civic hatch back VALVE TICK??
  70. Adding A/C...
  71. umm crap!
  72. Hello, I'm new here...
  73. Help im lost with gauges
  74. Need some more sources
  75. 88 versus 89 struts
  76. Really Fast Question (CRX)
  77. idle problems
  78. Who would want EURO spec Cluster?
  79. The most terrifying.....
  80. So lucky....
  81. questions about ZC
  82. ECU question
  83. Motor
  84. Getting Close
  85. what do u guys think?
  86. Mechanic Headache: '91 MT 160K+, when switching gears, i give it gas but it no go
  87. Help Please?
  88. let me know
  89. Boosting my car
  90. car is dying
  91. ECU code 10
  92. New kid, Few questions.
  93. Question
  94. The "Fog" light?
  95. Bye bye 4gen
  96. 4-2-1 header
  97. Why is my radio always drawing power?
  98. Very odd over heating...
  99. distributor leaking???
  100. crx over heating
  101. Clutch question
  102. advanced timing pinging
  103. 90 manual conversion
  104. chattering noise in engine
  105. Question about engine swap?
  106. Oh so rare......
  107. removing rack and pinion
  108. timing problems
  109. Is the engine supposed to do this or not?
  110. B16A 1st Gen or B16A 2nd Gen ?
  111. my zc swap almost done. alot of pictures
  112. Where can i buy a Chargespeed spoiler?
  113. SOHC Performance?
  114. 2007 Civic SI.....
  115. D16Z6 Swap
  116. Key stuck in the ignition
  117. Help please!?!
  118. New Suspension ! Comments?Suggestions?
  119. hatchback hoods
  120. Honda parts interchange
  121. Anyone ever seen this?
  122. Engine
  123. Need help....91 civic sedan dirt track
  124. camber question for evo
  125. crx debate..
  126. Spun Bearing?
  127. third crx starter
  128. fuel injection wiring diagram
  129. b7 camshaft on b2 Valve Clearance
  130. compression test results!
  131. Does your car idle like it should?
  132. transmission/clutch
  133. Speedometer cable.
  134. 88 CRX DX Timing
  135. Pgm-fi
  136. Trans Swap
  137. homemadeturbo.com
  138. installing cigarette lighter in 89 std
  139. questions about axels
  140. b16a engine swap
  141. Speakers
  142. no power
  143. seriously help me
  144. Idle Problems Worse
  145. Parking Lights
  146. 89 Civic LX code 15 and 16
  147. weird thing i found in my car..
  148. mpfi swap question.......
  149. New OEM bumpers?
  150. identifying tranny
  151. brake question
  152. motor gone?
  153. Auto to Manual Conversion
  154. Fender
  155. 1988 CRX HF Gas Sender unit
  156. conversion harness
  157. 1991 CRX Si Problems
  158. what will fit?
  159. vtec head for sale!!
  160. pics of my car
  161. Wheels: How Big???
  162. Valve Job.
  163. Got it Started now comes some Q's
  164. 88 CRX DX Bad Idle/Miss
  165. CRX Build Guide
  166. stock springs spring rate.
  167. Rear Disc Brake Conversion
  168. 89 dx tranny with dohc ZC? or d15b? or?
  169. oxygen sensor mod
  170. some Qs on swaps
  171. Engine Swap
  172. turbo
  173. timing
  174. Engine Sites
  175. projector headlights
  176. Smoking Problems
  177. High Rpm Idleing
  178. Instal guide
  179. another TURBO Question?
  180. 4dr dx blows fuses
  181. Is this right?
  182. question on my axles!
  183. Idle Problems
  184. CRX Cometic Headgasket questions
  185. looking for the pdf manual for the 89-91 civic
  186. Dont want a blown engine.Help.
  187. crx rear bumper support and windshield?????
  188. strip question
  189. Needed for a swap
  190. B16
  191. Wiring Diagram
  192. Heater Core Change
  193. gas and oil shock absorber
  194. JDM Glass roof Done by Honda-Tech member
  195. Swaping to B16A
  196. carbon fiber hood...
  197. K20 or K24 frankinstian?
  198. D16z6 And Vtec Head W/o Mpfi Or Vtec?
  199. Duh Latest on my 88 CRX fuel problem
  200. Stock engine on a 90 dx need to know what cluth to buy
  201. all on my own replacing vavles on my b16a need advice!
  202. Front Bumper Filler
  203. Got Questions
  204. http://www.autopartswarehouse.com/
  205. Civic heater problem
  206. 1990 civic battery or alt problems
  207. 88-89 and 90-91 seats the same?!
  208. Wiring
  209. WOO! Got my car back! couple ?s....
  210. New pics of my 91 Si
  211. Sensor Emmision box q's?
  212. headlights
  213. swaps 90 dx body gettin done ...
  214. i got a code violation yesterday.. check it
  215. D16A1 Head On2 1.6L ZC?
  216. 1990 CRX brake pedal sinks
  217. Fender Deffrence
  218. Will I EVER get one :(
  219. WW vs ebay, Techno
  220. 100-120Mph
  221. PR4 vs PG7 WTF?
  222. Your opinion needed.....
  223. Sorry Guys..
  224. Headlight switch help please.
  225. Car Decision
  226. bogging question.
  227. Need help with engine build
  228. bushings and ball joints
  229. Weird Noise in Wheel
  230. engine question
  231. distributor???
  232. Where did you run your amp wires?
  233. Weird Question
  234. Fuel Pump.
  235. 91 Sedan, Questions.
  236. 88 hatch idle issues need help
  237. 89 dpfi to mpfi please help
  238. security issues
  239. d15 and dohc zc tranny help
  240. mpfi from 1st gen teg
  241. Engine problems
  242. Gas tank question
  243. I got sponsored...
  244. Body Kit Q
  245. crank angle codes
  246. rear bumper support rusted out...
  247. dx/std to obd1 with upgrade obd2 rywire???
  248. 1988 CRX HF Main Relay
  249. Main Relay, To Crank Or Not To Crank...
  250. Best D series traction bar???
