Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '88 - '91 Civic / CRX |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
b7 camshaft on b2 Valve Clearance
compression test results!
Does your car idle like it should?
transmission/clutch
Speedometer cable.
88 CRX DX Timing
Pgm-fi
Trans Swap
homemadeturbo.com
installing cigarette lighter in 89 std
questions about axels
b16a engine swap
Speakers
no power
seriously help me
Idle Problems Worse
Parking Lights
89 Civic LX code 15 and 16
weird thing i found in my car..
mpfi swap question.......
New OEM bumpers?
identifying tranny
brake question
motor gone?
Auto to Manual Conversion
Fender
1988 CRX HF Gas Sender unit
conversion harness
1991 CRX Si Problems
what will fit?
vtec head for sale!!
pics of my car
Wheels: How Big???
Valve Job.
Got it Started now comes some Q's
88 CRX DX Bad Idle/Miss
CRX Build Guide
stock springs spring rate.
Rear Disc Brake Conversion
89 dx tranny with dohc ZC? or d15b? or?
oxygen sensor mod
some Qs on swaps
Engine Swap
turbo
timing
Engine Sites
projector headlights
Smoking Problems
High Rpm Idleing
Instal guide
another TURBO Question?
4dr dx blows fuses
Is this right?
question on my axles!
Idle Problems
CRX Cometic Headgasket questions
looking for the pdf manual for the 89-91 civic
Dont want a blown engine.Help.
crx rear bumper support and windshield?????
strip question
Needed for a swap
B16
Wiring Diagram
Heater Core Change
gas and oil shock absorber
JDM Glass roof Done by Honda-Tech member
Swaping to B16A
carbon fiber hood...
K20 or K24 frankinstian?
D16z6 And Vtec Head W/o Mpfi Or Vtec?
Duh Latest on my 88 CRX fuel problem
Stock engine on a 90 dx need to know what cluth to buy
all on my own replacing vavles on my b16a need advice!
Front Bumper Filler
Got Questions
http://www.autopartswarehouse.com/
Civic heater problem
1990 civic battery or alt problems
88-89 and 90-91 seats the same?!
Wiring
WOO! Got my car back! couple ?s....
New pics of my 91 Si
Sensor Emmision box q's?
headlights
swaps 90 dx body gettin done ...
i got a code violation yesterday.. check it
D16A1 Head On2 1.6L ZC?
1990 CRX brake pedal sinks
Fender Deffrence
Will I EVER get one :(
WW vs ebay, Techno
100-120Mph
PR4 vs PG7 WTF?
Your opinion needed.....
Sorry Guys..
Headlight switch help please.
Car Decision
bogging question.
Need help with engine build
bushings and ball joints
Weird Noise in Wheel
engine question
distributor???
Where did you run your amp wires?
Weird Question
Fuel Pump.
91 Sedan, Questions.
88 hatch idle issues need help
89 dpfi to mpfi please help
security issues
d15 and dohc zc tranny help
mpfi from 1st gen teg
Engine problems
Gas tank question
I got sponsored...
Body Kit Q
crank angle codes
rear bumper support rusted out...
dx/std to obd1 with upgrade obd2 rywire???
1988 CRX HF Main Relay
Main Relay, To Crank Or Not To Crank...
Best D series traction bar???
zc d15 head help
problem with headlights and blinker
Am I the only one that can't figure out this motor mount?
Mounting new radio?
Hey Guys HElp me out
Fuel Intake
Sunroof Q..
bumpers
Notchy shifter
ecu wiring diagram please
Rev Limiter
Race Car
Hook up Questions
Timing Belt 89 Civic Hatchback...
Tie rod ends and fuel gauge
exhaust bolt springs
gas tank gallons?
wont start
hazard fuse
Transmission compatability
fuses
temp
Few pictures of my new 91 SI
This normal for setting timing?
ecu blinking 3 times
Which one?
My transmission will last a long time
windshield wipers
clicking noise
New project
Auto harness....manual ecu
ecu code 23 on pr3?????what??
Blown tranny?
engine swap advice
problem with new clutch kit
failed smog in cali, here are the results!
What body kit is this?
ecu throwing code 5
Z3 Fenders and body kit
How hot does coolant get?
anybody recommend taking dust covers off brakes
91 Crx Hf
car wont stay running and plugs look like this after few minutes....
Motor possibly shot?
Integra interior fit in a crx?
gas guage
whats a good fuel pump?
How-to test fuel pressure on my 90 CRX Si?
Good Import Car Club Name?
zc question
Which sensor is this again?
Piston rings? Head gasket? Bent Valve/s?
Seafty cage
Fuel Bar on Intake Manifold
intake manifold
hesitation at low rpm and back fire
tranny question
engine trouble
1999 V-Tec B16 Ob1 computer setup.
E-brake isnt strong
Rust on the undercarriage of my 1991 Civic
Custom Transmission Gearing?
89 hatchback standard b16
Brake Noise
looking for starter crx in the ny, nj area
megan exhaust pics
Dash swap
d16z6 vtec head, shot?
ZC exhaust manifold question
friggin' steering knuckle trouble
Which one would be best?
How long will my transmission last?
91 CRX Overheat
Pulley Question
steering wheel shake, not rotors or wheels
Help Removing Pully
cv joint click, what side?
How much?
1st gen CRX vs 2nd gen CRX
the newb is back with questions!!
Civic Si Harness compared to Crx
dpfi-mpfi vtec?
Car Truble
Frustrated with Idle
Please Need Help
kyb gr-s bottom bolt
Z6-Fuel, but No Spark
More shiznit
fuel rail
yea i know i am dumb. just answer please
will a 94 teg fuel rail work on a DOHC ZC ?
sticky throttle
muffler on civic hb?
Piston Rings
Guess who's back
piston ring question
Exhaust shiznit????
Can i drive stick shift?
bung hole
Did i get ripped off?
piston question
Newbie Help!!
msd ignition
Not Again!
ground wire ???
carbon fiber how 2's
ZC swap Help
What is needed for a DPFI to MPFI swap
wire harness
Help!!!!!!!!! QUick!!!!!!!!!!!!!
A Little Help Please
1/4 panels
Dumbest question of alltime
91 hatch oil buring/ intermitent stalling
what do u guys/girls think????
now it won't start
sir wing
Slammedcivicsi's winter Project ZC 88 Hatch **PICS**
z6/y8 head gasket
Starter Question
steering wheel shakes on 91civic dx!
i've heard that humid exhaust = cracked head gasket
Will a 88 civic 1.6 throttle body work on a 88 civic with 1.5 engine?
what could be the problem?
14 Inch Steelies, Gas Mileage?
Good deal?? or not???
code 8 need help
Sea foam in high mileage engine?
Web
AF
