Our Community is 662,000 Strong. Join Us.
View Full Version : '88 - '91 Civic | CRX | Wagon | Shuttlee
  1. smog check for newer civics? smog check experts?
  2. CRX and hatch headlights the same?
  3. pops out of 5 gear
  4. How to polish engine block / tranny yourself??
  5. interior pics
  6. turbo feul injection
  7. a/c compressor issue
  8. caliper confusion
  9. CRX - N00b
  10. Hood PIns
  11. Help!!!!!!
  12. Rear Disk Brakes
  13. Code 6: Coolant Temp. Is it bad?
  14. best pressure plate for ZC
  15. Pics Of My First B Series Swap.
  16. another problem
  17. Race with 17's or 13's??
  18. ls/vtec swap 90 crx si questions?
  19. b18c5 (w00t for pics!)
  20. car sputters
  21. Engine Pinging and lack of top end
  22. check up on multi point swap
  23. used trannys from japan
  24. what the hell???
  25. GM Syncromesh gear oil
  26. sohc zc vs. rebuilding
  27. More problems starting. code 16 related.
  28. what would you do if you had the money
  29. Civic SI question
  30. doing the mpfi swap & need a lil help
  31. 90/91 wiring into 88/89
  32. please help
  33. Project Gunmetal (56k warning)
  34. Sadly the time has come...
  35. has this been done?
  36. Engine Rebuild
  37. Very inexpensive improvement
  38. Urgent help!
  39. Urgent help!
  40. a/c compressor removal.
  41. weird noise coming from engine
  42. Rough Idle?
  43. to those who remember me......IM BACK!
  44. My b16 Turbo progress
  45. Temp sensor
  46. changeing ecu's
  47. distributer compatibility
  48. crx bumper on hatch
  49. ????Weird????
  50. Which is better
  51. 90 CRX Idles all day, sputters and dies when driven...
  52. wow.....i give up
  53. fuel problem
  54. question for all mpfi swaped people or anyone really
  55. Need a measurment
  56. help please
  57. pricing on a crx
  58. Searching for '88-'91 Civic/CRX to Sponsor
  59. wiill these fit on my car
  60. Alternator
  61. Need help?
  62. really bad problems!!! some body help me!!!
  63. Tranny Slams into gear when cold
  64. dpfi vs mpfi
  65. battery relocations diagram
  66. Prelude headlights on a CRX?
  67. Is it worth it to fix it? [PICS]
  68. lsd transmission
  69. Door panels
  70. 92-95 intake mpfi swap few questions..
  71. Help with my axles
  72. Exhaust!
  73. Tein pillow ball mount trouble!!!
  74. 92 accord climate controls into a crx
  75. Hatch struts
  76. vtech vs. vtech-e
  77. throttle body spacer
  78. evo vs. crx
  79. Carlisle Compact show, who's goin?
  80. Need Serious Help
  81. Information on HF Crx putting in a d16y8 motor
  82. Timing Issue
  83. hood latch
  84. Starting Project...NEED HELP
  85. distributor question
  86. after installing MSD 6A and the blaster coil?
  87. LS/vtec ?? what do i need to hook it up?
  88. Fully MODING My Car.. Need your approval for tools~
  89. humm alternator?
  90. Engine Swap
  91. my shit light will not come on
  92. d15b2
  93. Swap help in OH
  94. Agree or Disagree.....Why?
  95. electrical problem
  96. fourthgen and 4thgen gone? Brake help
  97. bambam's beater....tell me what ya think :P
  98. b16a bucking
  99. how much should i pay for this car?
  100. really fast question
  101. Pics of the newbies rex
  102. CRX Dash Fit In A 91 Civic Si Hatch?
  103. Colors, colors, colors. What to choose?
  104. .......need adwise!!!
  105. Is this good for my hatch
  106. another odd overheating problem...with other issues
  107. Is this 1991 CRX worth the buy?
  108. newbie
  109. Almost done
  110. Trunk Conversion (91 to a 88)
  111. Miles Per Gallon Loss?
  112. B18C OBD1 codes?
  113. ls tranny on b16a
  114. me and electronics dont mix!
  115. troubles with heater and fan control faceplate
  116. Progress pics of my rex
  117. Leaking CRX taillights
  118. Starter issues...
  119. quik question
  120. stock b16a rev limit
  121. My Car (pictures)
  122. My Sedan Project...
  123. my car is a wiring nightmare!
  124. rims
  125. leaking AEM fuel rail
  126. Brake problems
  127. Pics of my new car
  128. 1988 dx w/ z16z6 bottom end.
  129. found this thought id share it...
  130. Mounting a Battery
  131. Is That All I Need For My B16A 88-91 (SiR I)
  132. a few pics of the hatch and 4door
  133. B20 Non-Vtec FAQ Guide
  134. Engine Trouble
  135. AAAH CRX died on highway...
  136. System Pictures, post em up.
  137. 1988 civic dx gauge cluster
  138. Help Please!!!
  139. Honda parts interchange
  140. Plzzzzz Help
  141. Update...lsvtec crx project nearly completed!
  142. fitting 90-91 civic si interior into 88-89 std
  143. Uhh
  144. just in case anyone wanted to know...
  145. Engine Swapping
  146. MSD into vtec...
  147. Tein SS, Skunk2, or Progress Tech ... Suspension Question ...
  148. quick question about tail lights
  149. Seat question...
  150. coilovers
  151. How to wash engine without blowing it up? Please let me know
  152. What are the most common problems with this generation of civic?s
  153. updated pics of progress,head work
  154. '89 CRX motor SWAP help!!
  155. Gotta new car!
  156. What spark plugs should I use?
  157. Finally! Pics of myRace Car
  158. need help please!
  159. 1989 Civic w/ 168,000ish miles. What maintainance should I do ASAP; Want to see 500k!
  160. My db: HondaCivicSedan 90'
  161. Timing Belt Change; Level of Difficulty for the newbie, but desired!
  162. man, another problem
  163. Wings West Body Kit install issue
  164. Hey Guys!
  165. Door Trim 88 CRX
  166. CRX center console possiablities
  167. Cleaning The Eacv.
  168. Will it fit??????
  169. engine spiting flames
  170. no instrument lights
  171. Help, b16 - vtec cuts out
  172. vtec activation
  173. s1 tranny question
  174. Quick Release Bumper Mounts??
  175. z6 head on a6 block
  176. shift linkage and axles
  177. idle is racing when out of gear
  178. Burning Oil BAD!!!
  179. 4ws prelude to crx
  180. door poppers install help ASAP
  181. swap for at. engine.
  182. Question About Headlights (projectors)
  183. Crash!
  184. couple pics of my hatch
  185. took out butterfly plate
  186. Tach Wire
  187. a little help please!!
  188. Car Died.. help me not pay to repair
  189. The time has come...56k maybe?
  190. Goodbye b18a Hello JDM B18C...
  191. Oil light problem
  192. Oil light problem
  193. 89 civic 2-door hatch. Fuel tank
  194. Won't start
  195. help me please. no spark
  196. Lower Control Arm Help
  197. 88 HF engine harness..
  198. engine question
  199. squeeky front end (((HELP)))
  200. 90 integ ecu work with zc in crx
  201. engine wont start
  202. wiring sucks
  203. no more crx
  204. trans swap issue
  205. My MPFI swap experience
  206. A1 transmission
  207. clutch disengagement problems
  208. Transmission help!
  209. 4dr
  210. MAP sensor
  211. Just shows how damn good honda's engines are
  212. 88 Crx
  213. What oil are you guys using
  214. D15 SOHC to DOHC things needed???
  215. Fitv
  216. quik question
  217. quick question
  218. grinds in third gear..?
  219. Sorry guys...Engine Help
  220. Crx Body Conversion
  221. Clutch Issues 91' Hatch STD
  222. deadpedal
  223. JDM or USDM replacement?
  224. 9006 HID Conversion kits
  225. 90 crx tie bars
  226. Cheap Websites!!!! L@@K!!!
  227. 1990 crx dx
  228. Cooling/Radiator FAN
  229. F*ck Theifs
  230. Tach not reading right?
  231. Bye Bye Si
  232. Freebee
  233. Question
  234. A bum sleeps in my car
  235. Squealing Seatbelt
  236. Replacing the dash
  237. urethane prices!!!
  238. My new EF! WHAT CHA THiNK?
  239. right amount of parts for d15b?
  240. Exhaust
  241. 1991 civic dx zc swap
  242. a/c belt diagram
  243. 91 civic 4dr
  244. Engine problems
  245. Newbie Here
  246. Front brake ubgrade
  247. Type R history video
  248. Oil light is on
  249. 4 wire o2 sensor
  250. My compression results
