Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '88 - '91 Civic / CRX |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
found this thought id share it...
Mounting a Battery
Is That All I Need For My B16A 88-91 (SiR I)
a few pics of the hatch and 4door
B20 Non-Vtec FAQ Guide
Engine Trouble
AAAH CRX died on highway...
System Pictures, post em up.
1988 civic dx gauge cluster
Help Please!!!
Honda parts interchange
Plzzzzz Help
Update...lsvtec crx project nearly completed!
fitting 90-91 civic si interior into 88-89 std
Uhh
just in case anyone wanted to know...
Engine Swapping
MSD into vtec...
Tein SS, Skunk2, or Progress Tech ... Suspension Question ...
quick question about tail lights
Seat question...
coilovers
How to wash engine without blowing it up? Please let me know
What are the most common problems with this generation of civic?s
updated pics of progress,head work
'89 CRX motor SWAP help!!
Gotta new car!
What spark plugs should I use?
Finally! Pics of myRace Car
need help please!
1989 Civic w/ 168,000ish miles. What maintainance should I do ASAP; Want to see 500k!
My db: HondaCivicSedan 90'
Timing Belt Change; Level of Difficulty for the newbie, but desired!
man, another problem
Wings West Body Kit install issue
Hey Guys!
Door Trim 88 CRX
CRX center console possiablities
Cleaning The Eacv.
Will it fit??????
engine spiting flames
no instrument lights
Help, b16 - vtec cuts out
vtec activation
s1 tranny question
Quick Release Bumper Mounts??
z6 head on a6 block
shift linkage and axles
idle is racing when out of gear
Burning Oil BAD!!!
4ws prelude to crx
door poppers install help ASAP
swap for at. engine.
Question About Headlights (projectors)
Crash!
couple pics of my hatch
took out butterfly plate
Tach Wire
a little help please!!
Car Died.. help me not pay to repair
The time has come...56k maybe?
Goodbye b18a Hello JDM B18C...
Oil light problem
Oil light problem
89 civic 2-door hatch. Fuel tank
Won't start
help me please. no spark
Lower Control Arm Help
88 HF engine harness..
engine question
squeeky front end (((HELP)))
90 integ ecu work with zc in crx
engine wont start
wiring sucks
no more crx
trans swap issue
My MPFI swap experience
A1 transmission
clutch disengagement problems
Transmission help!
4dr
MAP sensor
Just shows how damn good honda's engines are
88 Crx
What oil are you guys using
D15 SOHC to DOHC things needed???
Fitv
quik question
quick question
grinds in third gear..?
Sorry guys...Engine Help
Crx Body Conversion
Clutch Issues 91' Hatch STD
deadpedal
JDM or USDM replacement?
9006 HID Conversion kits
90 crx tie bars
Cheap Websites!!!! L@@K!!!
1990 crx dx
Cooling/Radiator FAN
F*ck Theifs
Tach not reading right?
Bye Bye Si
Freebee
Question
A bum sleeps in my car
Squealing Seatbelt
Replacing the dash
urethane prices!!!
My new EF! WHAT CHA THiNK?
right amount of parts for d15b?
Exhaust
1991 civic dx zc swap
a/c belt diagram
91 civic 4dr
Engine problems
Newbie Here
Front brake ubgrade
Type R history video
Oil light is on
4 wire o2 sensor
My compression results
can d15 JDM V-tec pass emissions?
final drive swap
obd3
Need good sites
think this is legit?
almost running zc
Accidents happen...
Engine Coolant squirt all over the floor
Problem with wireing
shifting w/o using the clutch...
What is the best dseries 1.6
engine bearings....need help
got into an accident with 06 civic
Springs!!?
Idleing Problem
new 90 civic
13" wheels over integra rear brakes?
Dif between HB and CRX front end
IAT sensor, location?
oil under engine
My New Intake
Steering Lock..Key Won't Turn!!
Timing Issue.
STD to Si tranny swap with just tranny
p28 ecu question
Pictures of my ride. (91 Sedan LX)
Rusted Screws!
Vibrating problem....
Help Wid This Dumb Noise Prob!!!!!!
help
just my luck..........
Don't you guys hate newbs like me.....
Car fax
Throttle Body SIZE?
new to CRX
battery keeps dying..
throttle Body
Throttlebody
crx seatbelts
crx dash in civic. question?
ecu chip help?
Max Performance w/SOHC ZC.
No lowend power after rebuild
turn signals not working
axel question
mugen body kit. asap.
front end rattles pls help
91 civic hatch body
cat problems
New Toy
ECU Choice..
Problem getting worse
D15B2 to D16Z6 swap need some help!
oil line kit. hopes
Help me find out what engine i have.
Is this a good brake combination?
importing a crx from the UK
Question about dash fuse box
Had a few questions about my Civic 91'
89 hatchback, backfiring, burning oil
Multi Point over Duel Point
b18a1 swap
Advantages of oversize thickness head gasket?
K22 Head fits?
need wiring diagram for moon-roof switch
need help quickly (brake/door ajar problem)
Fuel sender unit
Possible to swap seat backs?
88 honda civic hatch back VALVE TICK??
Adding A/C...
umm crap!
Hello, I'm new here...
Help im lost with gauges
Need some more sources
88 versus 89 struts
Really Fast Question (CRX)
idle problems
Who would want EURO spec Cluster?
The most terrifying.....
So lucky....
questions about ZC
ECU question
Motor
Getting Close
what do u guys think?
Mechanic Headache: '91 MT 160K+, when switching gears, i give it gas but it no go
Help Please?
let me know
Boosting my car
car is dying
ECU code 10
New kid, Few questions.
Question
The "Fog" light?
Bye bye 4gen
4-2-1 header
Why is my radio always drawing power?
Very odd over heating...
distributor leaking???
crx over heating
Clutch question
advanced timing pinging
90 manual conversion
chattering noise in engine
Question about engine swap?
Oh so rare......
removing rack and pinion
timing problems
Is the engine supposed to do this or not?
B16A 1st Gen or B16A 2nd Gen ?
my zc swap almost done. alot of pictures
Where can i buy a Chargespeed spoiler?
SOHC Performance?
2007 Civic SI.....
D16Z6 Swap
Key stuck in the ignition
Help please!?!
New Suspension ! Comments?Suggestions?
hatchback hoods
Anyone ever seen this?
Engine
Need help....91 civic sedan dirt track
camber question for evo
crx debate..
Spun Bearing?
third crx starter
fuel injection wiring diagram
Web
AF
