Our Community is 662,000 Strong. Join Us.
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic | CRX
> '88 - '91 Civic | CRX | Wagon | Shuttlee
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
Awsome civic vid
cops really suck...
spray paint primer
Joined the 4G wrecker's club today - exit JDM EF9
please help/ANY INFO
Next Question
battery output
Distributer Rotor
im about to give up on 4g civics
Fuel Tank
CRX Updates....and Photos. (56K No Way!!!)
Alternator fun..
crank pulley
Wheel wobble
b16 wiring q's
PCV Valve change on 89Civic
Dizzy probs
89CivicDX.Tranny Fluid change-DIY
89CivicDX-Too much oil
Engine Restorer vs CD2 Stop Leak w/ Amite
will my car run without the cyl. #1 position sensor.
d series piston bore
rim
Sold the hatch, in comes the rex
is this my main relay over the hood release?
short ram intake
CRX front lip
need help fixing motor running lean
Loss of power
Zc Dohc Swap !!
time for exhaust
quick motor question
i want a lip for my 4 door.
90 si hatchback seats in my 90 crx dx
You Know What Really Grinds My Gears?
Just a couple of pics of my 90 si hatch
Swap Question for future
grinding gears
quick fix for 91 crx?????
Crazy O2 Sensor
brakes
b18b1...got it..!
failed emissions again HELP
90 civic 1.6/ hot weather trouble
si calipers
injectors
Cleanest, Nicest looking CRX bumper?
yet another 88 civic
Diagnose oil usage
bad ground?
90 civic crx rear rotor question
P28 wiring into a Y8 head problem
jdm--usdm likeness???
transmisson problem
Finally got a digital camera..
SI seats are going in..56k warning
Help With Crx Please
oil pickup
A little teaser of the new setup.
Oh noes, now I have broken CRX's, woot
doesnt sound right??
Engine Question...
TransAxle in 91 Civic DX
big big problem
hoods
Oily Spark Plugs
B16A1 Sump gasket same as B16a2s ?
? starter relay location
dead starter???
1989 Crx Si #1 FUSE BLOWING
rear disks done!
Si seats in 89 dx?
Possible timing issues
pics of my b18 and question about suspention
problem with radiator????
hatchback lip
D16A6 block swap with a D16A1 Block
Strange thing happened other day
will it fit???
88-91 civic service manual
Damn old crxs...
call me stupid, obsessed, i have a one track mnd
CODE 1 pissing me off
stuck valves
just bought a crx nd dont know wat 2 do first???
What do the different bands mean on a Cobra Radar detector?
opinions???
Engine Questions...89 Wagon
b16 to b18 swap ecu question
ok new problems.
What is the deal here...
torque specs???
timing belt help
failed smog what went wrong with 15mph?
final drive swap
Brakes on my 91 Hatch..
tranny oil
91 CRX not starting
so heres the 89 si start to finish!
need help
code 1 issues
help with timing. really quik
B18 Head Problems
speedo issues
Still won't freakin start
door panels
89' purchase question
1990 CRX Alternator exchange
Ok messed up valve adjustment NEED HELP
90 si hatch (pic's)
wheel bearing
battery issues
another question on engine swaps
license plate light
stumbling
HELP engine squeal rough idle issues
my b16 compression
i replaced my main relay
propane convert
interior
Ball joint and throttle cable installation
Update
somebody please help
Stupid Question
removing CRX sticker on back
91 integra ls
aRe 17" rims "really" going to affect my 1/4 times?
dual point to mpfi
i may acutally get this
motor issue.
A Silly Question
Wiring
that's it. i hate my crx.
Won't start update
racing slicks
Tire blowout
engine swap
90 Black Si HB stolen in 626 area on 5/29, Need help from peeps in South Gate Area
pretty simple question.
Google didn't help!
1990 Civic EX -
No spark
Help please
Won't start!
my lame crx and its reluctance to start part... uh... three?
b16a fluids
Help!!!
the 89' si is comming' along (pics)
So I got a new car #2
dizzy question
Taking road trip with my car
steering click
shift linkage pin help
obd-0 to obd-1
'90 civic surges at idle
1991 Honda Civic Spark Plug Question
How to build a "RELIABLE" lsvtec/b20vtec guide.
heater motor...
s2000 cluster in CRX with B18c5?
pcv valve location
best ecu for the b16
91 HF Stuttering and Losing Power
Bad company to order from!
88 Crx acting funny
91 CRX Engine light
Gauge Cluster For Sale?
how do i take the governor out??
Fusor 147 review
blowing alternators at the track ?
Timing Belt Cover Necessary?
what is going on with my car?! (electrical)
civic parts on crx
a few more things for the B
I spent $2,200 in one day...i got pix :)
The single cam that could
How much for a "ghetto rebuild?"
CRX Auto Tranny issues
build a honda beat a vette
DOHC or SOHC?
Everybody Get A Word In!!!
Fuel Leak
timing belt sliiped.....
B16 harness help
help!!!!!!!!!
Sweet ass deal, No rip-off's here!
PM5 Ecu
Cable or Hydro?
got the seats in!
wtb: 5th gear synchro
will these fit ??? and not rub
need to buy!! pm6 crx si dizzy
brake pad problem
F20c swap possible?
d15b engine specs
New Transmission - New problem
Coolant leak again
help from anyone wh knows turboes
THIS is how low i wanna go.
Several questions for the well informed
Quick Tranny Question
Tie rod end replacement
honda civic 89 hatch back
VTEC wiring for b16a
No Power To Fuel Pump.
Sway bar question.
codes 6 10 13
really quik question
Wiring
having a problem
mini-me/timing belt
Elite Auto Sport!!!!
D16A1 head On D15B2
z6 engine rebuild then turbo setup
89 Crx
my charge pipes.
pics of the hatch
Oil Cooler
New newb here, HELP PLEASE!
B16 swap progress
Vtec
b16 with a/c
motor and ac question
i could be wrong / aka: my car may be possessed
jdm engines in Philly
PCV Valve - AutoZone or Honda?
Car sputters in 2nd gear wtd?
Back into a 4th gen
crx and civic parts question?? help
crx hf? good or bad?
88 crx tails
tranny Q
NO brake lights!
found b16a1 & bought pr4
Finished my winter projects !! Interior & Suspension .. *56k beware*
tell me what you guys think please
help with my clutch
So how bout those 4th Gen. Civic's?
Fuel Pressure
Power steering??
flywheel from 2000 d16 fit?
Tranny Noises
Help needed
Maybe off topic? But I wanted to share my new car with you old friends
Civtegra coming together
Quick Question about a car????
TDC is off help me
89 civic, need info
odd clanking sound when shifting
my 1/4 time at the tracks
what size fans?
Automotive Network, Inc., Copyright ©2012
