Our Community is 662,000 Strong. Join Us.
View Full Version : '88 - '91 Civic | CRX | Wagon | Shuttlee
  1. ZC swap into a DX
  2. Hello...and help!
  3. Give me some ideas on what to check
  4. History of the Civic: 1973-2000
  5. honda Civic lx91 problem need help
  6. 91 civic dying unless cranked over!
  7. Another Civic's Parking light problem(but difrent)
  8. seatbelt warning light. aka my car is senile
  9. How do i make my gsr vtec hit hard?help me
  10. adjustable struts?
  11. top speed
  12. What fits what?
  13. CRX breaks up @3500rpm
  14. vacuum/idle issue
  15. Here you go.........
  16. Automatic Transmission Question
  17. emergency brake light
  18. emergency brake light
  19. which chip is best for me?
  20. b20b 88hb
  21. Turn signals acting up...
  22. rear crossmember
  23. New car
  24. ignition problems
  25. Parkin Lights again!!!
  26. what should i do?
  27. Freakin' crank pulley
  28. sunroof idea
  29. No start
  30. charging problem
  31. Please Help if you know anything about this thanks..
  32. what brand speakers = honda factory speakers?
  33. Transmission Question
  34. 89 Crx Tranny Confusion?!??
  35. Need help
  36. Projector Headlights...
  37. Driveaxle Replacement (FINISHED)
  38. Checking Honda ECU's
  39. Car wont start, all the basics check out ok
  40. what air fuel gauge to buy.
  41. Driveaxle Replacement...
  42. break in period
  43. Problems
  44. hub adapters
  45. Wiring harness question
  46. New to this Forum
  47. Civic engine
  48. HB and 4dr Taillights
  49. b16a swap help
  50. what's your opinion???
  51. What is it ???? zc block d15 head
  52. Valvoline Max Life oil
  53. D16 Manifold Swap
  54. Removing A/C
  55. MSD for d16a6????
  56. Pics from the h-t meet @ MapleGrove
  57. Alternator Bolt Broke HELP
  58. eletrical problem
  59. engine stall i need help
  60. swap question
  61. Exhaust Question (engine swap)
  62. Fuel Tank Question
  63. heat hand--very strange
  64. Need help with front turn signals 88 Crx
  65. head swap
  66. ECU codes 43
  67. I Need Wiring Help
  68. Stupid Question
  69. What should I look for before buying a wrecked Civic?
  70. please i need some advice!!!!!!!!!!!!!!!!!!1
  71. using a multimeter
  72. need help tried everything
  73. so yeah, rear seats in crx?
  74. Heat Shield
  75. some quick seat help
  76. LS Swap Code Help
  77. Super Charger 91 CRX SI
  78. dust cover?
  79. need some advice
  80. High RPMs and oil
  81. Help with a 90' honda civic fuel system!!!!!!!!!
  82. sway bars
  83. ZC performance?
  84. Relay
  85. Rear intermittent wiper mod?
  86. Is 89 Acura seats in 89 Civic Hatch possible?
  87. how long do i have?
  88. squeaky hatch
  89. i need help !
  90. help with a 91 civic sedan lx
  91. my plug is stuck!!!
  92. head unit problem!
  93. is it worth it 88 crx
  94. mini me acting up
  95. D16 bore question.
  96. machine shops
  97. Issues with ignition timing
  98. '89 Civic SI Turns Over And Starts But Takes A Long Time To Start
  99. HF exhaust manifolds
  100. Long Block
  101. new to the forums...need some advice
  102. Help with 'no start'
  103. CRX Main relay or what??
  104. 89 sedan hood????
  105. head swap
  106. Almost Complete! Performance Question?
  107. H22 ina 89 Civic??? Can it be Done?
  108. My new project
  109. Parkin Lights
  110. Very Frustrated!!
  111. Need help ASAP
  112. Question?????
  113. Weird....please help
  114. clunking noise please help
  115. Ground issue
  116. Electronic rust protection?
  117. what car did this motor come from
  118. replacing RTA bushings on 90 civic si
  119. Rear Arch Trim
  120. Could someone with unlimited carfax reports help me get a report for my car.
  121. New Car
  122. tranny fluid?
  123. I need to remove these valves........
  124. vtec not engaging
  125. wiring for a obd1 dizzy
  126. Any ideas?
  127. Question About 88/89-90/91 Civic To Crx Dash Conversion
  128. 89 Crx Brakes
  129. would this work well?
  130. replaced my main relay today
  131. 88 hatchback std 4spd to 5sp swap
  132. i need Help
  133. Braking Vibration
  134. 89 hf crx
  135. bought it yesterday!!!
  136. 89 Civic Zc Swap
  137. What swap is best for me?
  138. columbus ohio swaps?
  139. more problems
  140. Rusty Wheel Arches, advice?
  141. crx exxhaust
  142. green mean machine {mutant} funny timing problem
  143. oil leak
  144. Changing Gauge Cluster
  145. is this arm rest rare?
  146. header bolts
  147. Civic ZC Swap
  148. 06 Honda Meet in PA!
  149. 4g doors
  150. can you help me
  151. 4th gen HB Si
  152. 89 crx to 96 civic front end conversion help
  153. Tie rod replacement?
  154. Badges
  155. no spark
  156. rear camber issue
  157. ecu problems
  158. need help
  159. mpfi swap problem
  160. Tach on crack... any ideas?
  161. Paint question
  162. obx intake manifold
  163. 88 Honda Civic Wagon Trouble Starting
  164. Missing plastic cover screws help!
  165. So long, Civic.
  166. HELP! fuel problem is eating me up
  167. GSR wheel question
  168. Just went back to stock suspension and..
  169. Mibad...
  170. need to buy si tranny for my 89' rex
  171. transmission options
  172. Can camber be adjusted on a civic?
  173. old mpfi tutorial
  174. Sedan Fender
  175. grinding in third gear
  176. re-paint?
  177. b16a into 89sicivic swap
  178. Anyone know about a CRX license plate light?
  179. mmmm SOHC :P
  180. Buying CRX HF
  181. zc distribuidor
  182. signal light stays on
  183. how you like it?
  184. to b20 or not to b20 that is the question
  185. Got my juices flowin
  186. Compression Tester
  187. Stupid Car problem!! Please help.
  188. clock
  189. ECU code 0 on LX sedan
  190. help with my vafc hook up for mini-me with pm6
  191. 1989 CIVIC car Deck Inst. HELP
  192. Body Kits?
  193. engine codes
  194. Opinion needed. 2000 civic SI with Integra Type R motor.
  195. fuel on my spark plugs
  196. d series to b series
  197. Noob has oily spark plug wires
  198. Cam Gears
  199. Intake Mannifolds
  200. pistons
  201. powder coat stripping
  202. Head Gasket
  203. Over Clear Coated, what do i do?
  204. Production totals anyone?
  205. camshafts
  206. Camber Kits
  207. crankpulley
  208. negative camber
  209. b16 upgrade..what should i do?
  210. Compression
  211. 89 Hatch fuel tank size and maint?
  212. How do i remove glass from hatch
  213. 91civic-89teg
  214. pics of the new sedan
  215. upper strut braces
  216. where does the forth tie bar go?
  217. need part name =/
  218. JDM ecu Vs. OEM ecu
  219. o2 sensor
  220. no more 4g....
  221. annoying plastic screws
  222. Looking for books on swaps / engine modding
  223. car length differences?
  224. possible clutch problem?
  225. need specs on zc
  226. Headers
  227. Oiling problem
  228. fuel rail
  229. vtec controller question
  230. Short Circuit--but where?
  231. Head Gasket
  232. Radio
  233. Intermittent starting problem, 89 Wagovan
  234. code 11???
  235. Im back , with a 4door!
  236. new heads?
  237. master break cylinder
  238. engine check light comes on
  239. ZC Swap Question...
  240. front passenger side tire squealing
  241. allo
  242. 89 civic blinker and fuse problems!!!!!!
  243. My Turd of an '88
  244. obd0 injectors
  245. secondary 02 problem
  246. This site has some good parts.
  247. Update: 91 Hatch finally getting work done!
  248. rear tire
  249. camshaft questions
  250. tranny filling help
