View Full Version : '88 - '91 Civic / CRX
  1. would this work well?
  2. replaced my main relay today
  3. 88 hatchback std 4spd to 5sp swap
  4. i need Help
  5. Braking Vibration
  6. 89 hf crx
  7. bought it yesterday!!!
  8. 89 Civic Zc Swap
  9. What swap is best for me?
  10. columbus ohio swaps?
  11. more problems
  12. Rusty Wheel Arches, advice?
  13. crx exxhaust
  14. green mean machine {mutant} funny timing problem
  15. oil leak
  16. Changing Gauge Cluster
  17. is this arm rest rare?
  18. header bolts
  19. Civic ZC Swap
  20. 06 Honda Meet in PA!
  21. 4g doors
  22. can you help me
  23. 4th gen HB Si
  24. 89 crx to 96 civic front end conversion help
  25. Tie rod replacement?
  26. Badges
  27. no spark
  28. rear camber issue
  29. ecu problems
  30. need help
  31. mpfi swap problem
  32. Tach on crack... any ideas?
  33. Paint question
  34. obx intake manifold
  35. 88 Honda Civic Wagon Trouble Starting
  36. Missing plastic cover screws help!
  37. So long, Civic.
  38. HELP! fuel problem is eating me up
  39. GSR wheel question
  40. Just went back to stock suspension and..
  41. Mibad...
  42. need to buy si tranny for my 89' rex
  43. transmission options
  44. Can camber be adjusted on a civic?
  45. old mpfi tutorial
  46. Sedan Fender
  47. grinding in third gear
  48. re-paint?
  49. b16a into 89sicivic swap
  50. Anyone know about a CRX license plate light?
  51. mmmm SOHC :P
  52. Buying CRX HF
  53. zc distribuidor
  54. signal light stays on
  55. how you like it?
  56. to b20 or not to b20 that is the question
  57. Got my juices flowin
  58. Compression Tester
  59. Stupid Car problem!! Please help.
  60. clock
  61. ECU code 0 on LX sedan
  62. help with my vafc hook up for mini-me with pm6
  63. 1989 CIVIC car Deck Inst. HELP
  64. Body Kits?
  65. engine codes
  66. Opinion needed. 2000 civic SI with Integra Type R motor.
  67. fuel on my spark plugs
  68. d series to b series
  69. Noob has oily spark plug wires
  70. Cam Gears
  71. Intake Mannifolds
  72. pistons
  73. powder coat stripping
  74. Head Gasket
  75. Over Clear Coated, what do i do?
  76. Production totals anyone?
  77. camshafts
  78. Camber Kits
  79. crankpulley
  80. negative camber
  81. b16 upgrade..what should i do?
  82. Compression
  83. 89 Hatch fuel tank size and maint?
  84. How do i remove glass from hatch
  85. 91civic-89teg
  86. pics of the new sedan
  87. upper strut braces
  88. where does the forth tie bar go?
  89. need part name =/
  90. JDM ecu Vs. OEM ecu
  91. o2 sensor
  92. no more 4g....
  93. annoying plastic screws
  94. Looking for books on swaps / engine modding
  95. car length differences?
  96. possible clutch problem?
  97. need specs on zc
  98. Headers
  99. Oiling problem
  100. fuel rail
  101. vtec controller question
  102. Short Circuit--but where?
  103. Head Gasket
  104. Radio
  105. Intermittent starting problem, 89 Wagovan
  106. code 11???
  107. Im back , with a 4door!
  108. new heads?
  109. master break cylinder
  110. engine check light comes on
  111. ZC Swap Question...
  112. front passenger side tire squealing
  113. allo
  114. 89 civic blinker and fuse problems!!!!!!
  115. My Turd of an '88
  116. obd0 injectors
  117. secondary 02 problem
  118. This site has some good parts.
  119. Update: 91 Hatch finally getting work done!
  120. rear tire
  121. camshaft questions
  122. tranny filling help
  123. Awsome civic vid
  124. cops really suck...
  125. spray paint primer
  126. Joined the 4G wrecker's club today - exit JDM EF9
  127. please help/ANY INFO
  128. Next Question
  129. battery output
  130. Distributer Rotor
  131. im about to give up on 4g civics
  132. Fuel Tank
  133. CRX Updates....and Photos. (56K No Way!!!)
  134. Alternator fun..
  135. crank pulley
  136. Wheel wobble
  137. b16 wiring q's
  138. PCV Valve change on 89Civic
  139. Dizzy probs
  140. 89CivicDX.Tranny Fluid change-DIY
  141. 89CivicDX-Too much oil
  142. Engine Restorer vs CD2 Stop Leak w/ Amite
  143. will my car run without the cyl. #1 position sensor.
  144. d series piston bore
  145. rim
  146. Sold the hatch, in comes the rex
  147. is this my main relay over the hood release?
  148. short ram intake
  149. CRX front lip
  150. need help fixing motor running lean
  151. Loss of power
  152. Zc Dohc Swap !!
  153. time for exhaust
  154. quick motor question
  155. i want a lip for my 4 door.
  156. 90 si hatchback seats in my 90 crx dx
  157. You Know What Really Grinds My Gears?
  158. Just a couple of pics of my 90 si hatch
  159. Swap Question for future
  160. grinding gears
  161. quick fix for 91 crx?????
  162. Crazy O2 Sensor
  163. brakes
  164. b18b1...got it..!
  165. failed emissions again HELP
  166. 90 civic 1.6/ hot weather trouble
  167. si calipers
  168. injectors
  169. Cleanest, Nicest looking CRX bumper?
  170. yet another 88 civic
  171. Diagnose oil usage
  172. bad ground?
  173. 90 civic crx rear rotor question
  174. P28 wiring into a Y8 head problem
  175. jdm--usdm likeness???
  176. transmisson problem
  177. Finally got a digital camera..
  178. SI seats are going in..56k warning
  179. Help With Crx Please
  180. oil pickup
  181. A little teaser of the new setup.
  182. Oh noes, now I have broken CRX's, woot
  183. doesnt sound right??
  184. Engine Question...
  185. TransAxle in 91 Civic DX
  186. big big problem
  187. hoods
  188. Oily Spark Plugs
  189. B16A1 Sump gasket same as B16a2s ?
  190. ? starter relay location
  191. dead starter???
  192. 1989 Crx Si #1 FUSE BLOWING
  193. rear disks done!
  194. Si seats in 89 dx?
  195. Possible timing issues
  196. pics of my b18 and question about suspention
  197. problem with radiator????
  198. hatchback lip
  199. D16A6 block swap with a D16A1 Block
  200. Strange thing happened other day
  201. will it fit???
  202. 88-91 civic service manual
  203. Damn old crxs...
  204. call me stupid, obsessed, i have a one track mnd
  205. CODE 1 pissing me off
  206. stuck valves
  207. just bought a crx nd dont know wat 2 do first???
  208. What do the different bands mean on a Cobra Radar detector?
  209. opinions???
  210. Engine Questions...89 Wagon
  211. b16 to b18 swap ecu question
  212. ok new problems.
  213. What is the deal here...
  214. torque specs???
  215. timing belt help
  216. failed smog what went wrong with 15mph?
  217. final drive swap
  218. Brakes on my 91 Hatch..
  219. tranny oil
  220. 91 CRX not starting
  221. so heres the 89 si start to finish!
  222. need help
  223. code 1 issues
  224. help with timing. really quik
  225. B18 Head Problems
  226. speedo issues
  227. Still won't freakin start
  228. door panels
  229. 89' purchase question
  230. 1990 CRX Alternator exchange
  231. Ok messed up valve adjustment NEED HELP
  232. 90 si hatch (pic's)
  233. wheel bearing
  234. battery issues
  235. another question on engine swaps
  236. license plate light
  237. stumbling
  238. HELP engine squeal rough idle issues
  239. my b16 compression
  240. i replaced my main relay
  241. propane convert
  242. interior
  243. Ball joint and throttle cable installation
  244. Update
  245. somebody please help
  246. Stupid Question
  247. removing CRX sticker on back
  248. 91 integra ls
  249. aRe 17" rims "really" going to affect my 1/4 times?
  250. dual point to mpfi
