Our Community is 662,000 Strong. Join Us.
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic | CRX
> '88 - '91 Civic | CRX | Wagon | Shuttlee
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
transmission question
motor mounts..
obd1 conversion
energy suspension bushing peformance
1.6vtec head on 1.5
automatic crx rpm?
looky what I got ahold of :-)
Car got stolen into...
Wipers stopped
Before I go take it to the autoshop...
helllp fuse diagram
I'm back
Swap Engine or Buy New Car?
shop?
CRX Spongy / No Brakes
Out of curiousity...
A little of your time and mind PLEASE
Looking for some parts
Code 3 on d15b swap?
Almost ready to put turbo in!!
ZC or B16?
Catalytic converter question
obd-0 to obd-1 help
Timing Belt Snapped
Won't run past 3k rpm
cluster
hellllp car not running
help with clicking sound
po8 1 wire o2 sensor
Engine help
New Injectors for ZC??
91 HB steering wheel vibration when braking, any answers
Help Tranny Problem
Clutch slipping possibly??
map bypass missing link
obd0 to obd1 question
What Is Wrong With It
Motor Swap
rim color choice
Clutch cable problems
anyone REALLY interested?
Smoking Problem
Help converting front end to integra
89 CRX Engine Swap
headlight Question
will a d16a6 distribitor cap fit a never sohc civic motor (92-95)
need help with my alarm
swap sohc zc into 90 crx hf Problems!!!
how or is it possible
Do I need to replace my camshaft seal?
vtec questions
black smoke
bottom end rebuild
Harness Question
si tranny in crx
B16A: gouvenor?
DA front end on EF hatch??
da int. shaft
Help
running out of steam
rebuild
obd0-1 ecu wiring and ????? need help
91 Civic 1.5 Intermittently Cuts Out
Help with a air intake
subwoofer box
Washer Fluid Lines
wtf can someone help
Radiator Replace
civic distributors
1989 Honda Problem
Redline Question
new car
90-93 teg half shafts?
Good Buy?
Wiring Help
jdm front end
Where can i buy?
Clutch Pedal Vibration
Ebay B Series Mounts
Need Help!! Coilovers
exhaust
helllllpppp a couple of problems
Does 2000 Gsr Leather Fit My Ef Si???
Stolen Car!!!!!!!
Exhaust: Glasspack?
Ive sprung a leak!
What should i do?
help in phoenix
Wipers in "Feild Goal" Position.....
battery
hookin up speedometer
trans q
Temperature Gauge
Trying to replace a knock sensor..
90 Crx Wiring Diagram
'91 DX runs bad/dies with lites on.
1988 crx
PCV valve removal?
Boost Question
turbo???
Check Engine light, No speedometer
Resolved Rotor issue
ef 8 suspension help
speaker problem
BAM! lights are gone
new fog lights
Part list for D16Z6 Swap
Radio reception
fog light switch?
Diagnostic Trouble Codes
Gas Fumes?
Tail Light Mod
91 civic dx stubles
heater issue..
rim size ???
for the money... B20 or H22 both built
hmmmm
Pain in the A$$
asap asap asap
Alternator dead?
help me for a sec..clear shit up for a friend
DIY Alignment?
backyard motor swap?
Tailight Conversion
New car #10. Teaser Pic inside.
Help Needed!
Canadian parts distributor?
crx with 5th gen lights... how would that look?
Is this Possible?
trans swap
Do you think its worth it?
Need HELP D16Y8
89 civic wagon hood weight
Will it fit?
Need some help
Help Me
My car idles at 2000 rpm when first started
Civic dont start?
'88 integra LS
question of the wiring sorts again
Very loud valves
best time to activate vtec
Is this all the stuff i need the for the swap
MPFI swap, other possible soruces?
dim lighting
sad day for the civic
Problem with Rotors
crank girdle
my CRX SIR
Is there an EGR with 91civic(made in canada)?
abs vs. non abs axles
tire sizes?
what do you think?
Code 16 Fuel Injector HELP
websites where i can get a Z6 or a Y7 head
car bogs out when i floor it
Dash board
installing coilovers
...back to ZERO with my Civic..Honda Heads Unite Please!
Mystery Sound
help!!
problems as usual
Help with turboing a crx
engine swamp questions
seats for my 91 crx dx
Stutter on steady ideal on my b16a
clean engines
bogging civic
car starts then dies
A moment of silence...56k killer
92-95 tein coilovers on an 88-91?
clutch or tranny?
Dpfi To Mpfi
Clutch?
RPM is too high
Gas Tank Issue
will it fit
88 crx license plate light - please help!
88 crx si starting issue
ah hell... what do I do?
cigarette lighter
map sensor
Need to identify front spoiler
rocking feeling in steering
what head can i put on my soch ZC ????
new pistons
Type R motor in a CRX
Just saying hello to any one that rembers me
D16 Swap...Now Clutch issues
Largest engine that mounts in the same way as my EF CRX?
octane gas
Strut bars(does cheap work)
Help need some info on the situation
91 crx hf sputters???
DA integra knuckles
1990 civic 4dr mpi anyone know any tricks???
Electric Supercharger
88 crx hf won't stay running
My CRXs makes clicking Noise when i got around Corners
'91 civic dx runs like crap
bushing pressing ect.
interior pictures
Steering wheele question
will it fit...HELP
what tranny do i have
Braking Problem
Water Issue
90 civic brake light & horn HELP
Techno R sideskirts
Bad clutch?
DPFI question
Ecu Question
crx si interior harness
fiting a si motor in 88 crx
b16 wiring
Tires
does anyone
D16z6 swap into 91 hb
what do i need
si seats problem
starter grinding
88-89 D16A1 in 88 CRX Hf
B18A1 with CRX si tranny???
has anyone installed polyurethane bushings themselves?
motor mount bushings
parting ways with the crx
smoke?
Will it still Work????
i need help please anyone
Shaky Ride.....
1989 Civic DX hatchback fuse diagram
Engine won't start!!
buying new civic. what to do with crx?
buying a new civic. what to do with the crx?
Swap, check engine light, any ideas?
91 civic tranny grinds
electrical
performance parts for the ZC motor?
Tachometer
Introduction, questions about fenders and doors
trying to figure out why my car.........
tranny rebuild.
wire harness
shift linkage problems
reverse locked up
civic specs anyone?
Missing Car Keys...
puerto vallarta
start car down hill?
Automotive Network, Inc., Copyright ©2012
