View Full Version : '88 - '91 Civic / CRX
  1. crx with 5th gen lights... how would that look?
  2. Is this Possible?
  3. trans swap
  4. Do you think its worth it?
  5. Need HELP D16Y8
  6. 89 civic wagon hood weight
  7. Will it fit?
  8. Need some help
  9. Help Me
  10. My car idles at 2000 rpm when first started
  11. Civic dont start?
  12. '88 integra LS
  13. question of the wiring sorts again
  14. Very loud valves
  15. best time to activate vtec
  16. Is this all the stuff i need the for the swap
  17. MPFI swap, other possible soruces?
  18. dim lighting
  19. sad day for the civic
  20. Problem with Rotors
  21. crank girdle
  22. my CRX SIR
  23. Is there an EGR with 91civic(made in canada)?
  24. abs vs. non abs axles
  25. tire sizes?
  26. what do you think?
  27. Code 16 Fuel Injector HELP
  28. websites where i can get a Z6 or a Y7 head
  29. car bogs out when i floor it
  30. Dash board
  31. installing coilovers
  32. ...back to ZERO with my Civic..Honda Heads Unite Please!
  33. Mystery Sound
  34. help!!
  35. problems as usual
  36. Help with turboing a crx
  37. engine swamp questions
  38. seats for my 91 crx dx
  39. Stutter on steady ideal on my b16a
  40. clean engines
  41. bogging civic
  42. car starts then dies
  43. A moment of silence...56k killer
  44. 92-95 tein coilovers on an 88-91?
  45. clutch or tranny?
  46. Dpfi To Mpfi
  47. Clutch?
  48. RPM is too high
  49. Gas Tank Issue
  50. will it fit
  51. 88 crx license plate light - please help!
  52. 88 crx si starting issue
  53. ah hell... what do I do?
  54. cigarette lighter
  55. map sensor
  56. Need to identify front spoiler
  57. rocking feeling in steering
  58. what head can i put on my soch ZC ????
  59. new pistons
  60. Type R motor in a CRX
  61. Just saying hello to any one that rembers me
  62. D16 Swap...Now Clutch issues
  63. Largest engine that mounts in the same way as my EF CRX?
  64. octane gas
  65. Strut bars(does cheap work)
  66. Help need some info on the situation
  67. 91 crx hf sputters???
  68. DA integra knuckles
  69. 1990 civic 4dr mpi anyone know any tricks???
  70. Electric Supercharger
  71. 88 crx hf won't stay running
  72. My CRXs makes clicking Noise when i got around Corners
  73. '91 civic dx runs like crap
  74. bushing pressing ect.
  75. interior pictures
  76. Steering wheele question
  77. will it fit...HELP
  78. what tranny do i have
  79. Braking Problem
  80. Water Issue
  81. 90 civic brake light & horn HELP
  82. Techno R sideskirts
  83. Bad clutch?
  84. DPFI question
  85. Ecu Question
  86. crx si interior harness
  87. fiting a si motor in 88 crx
  88. b16 wiring
  89. Tires
  90. does anyone
  91. D16z6 swap into 91 hb
  92. what do i need
  93. si seats problem
  94. starter grinding
  95. 88-89 D16A1 in 88 CRX Hf
  96. B18A1 with CRX si tranny???
  97. has anyone installed polyurethane bushings themselves?
  98. motor mount bushings
  99. parting ways with the crx
  100. smoke?
  101. Will it still Work????
  102. i need help please anyone
  103. Shaky Ride.....
  104. 1989 Civic DX hatchback fuse diagram
  105. Engine won't start!!
  106. buying new civic. what to do with crx?
  107. buying a new civic. what to do with the crx?
  108. Swap, check engine light, any ideas?
  109. 91 civic tranny grinds
  110. electrical
  111. performance parts for the ZC motor?
  112. Tachometer
  113. Introduction, questions about fenders and doors
  114. trying to figure out why my car.........
  115. tranny rebuild.
  116. wire harness
  117. shift linkage problems
  118. reverse locked up
  119. civic specs anyone?
  120. Missing Car Keys...
  121. puerto vallarta
  122. start car down hill?
  123. ZC swap into a DX
  124. Hello...and help!
  125. Give me some ideas on what to check
  126. History of the Civic: 1973-2000
  127. honda Civic lx91 problem need help
  128. 91 civic dying unless cranked over!
  129. Another Civic's Parking light problem(but difrent)
  130. seatbelt warning light. aka my car is senile
  131. How do i make my gsr vtec hit hard?help me
  132. adjustable struts?
  133. top speed
  134. What fits what?
  135. CRX breaks up @3500rpm
  136. vacuum/idle issue
  137. Here you go.........
  138. Automatic Transmission Question
  139. emergency brake light
  140. emergency brake light
  141. which chip is best for me?
  142. b20b 88hb
  143. Turn signals acting up...
  144. rear crossmember
  145. New car
  146. ignition problems
  147. Parkin Lights again!!!
  148. what should i do?
  149. Freakin' crank pulley
  150. sunroof idea
  151. No start
  152. charging problem
  153. Please Help if you know anything about this thanks..
  154. what brand speakers = honda factory speakers?
  155. Transmission Question
  156. 89 Crx Tranny Confusion?!??
  157. Need help
  158. Projector Headlights...
  159. Driveaxle Replacement (FINISHED)
  160. Checking Honda ECU's
  161. Car wont start, all the basics check out ok
  162. what air fuel gauge to buy.
  163. Driveaxle Replacement...
  164. break in period
  165. Problems
  166. hub adapters
  167. Wiring harness question
  168. New to this Forum
  169. Civic engine
  170. HB and 4dr Taillights
  171. b16a swap help
  172. what's your opinion???
  173. What is it ???? zc block d15 head
  174. Valvoline Max Life oil
  175. D16 Manifold Swap
  176. Removing A/C
  177. MSD for d16a6????
  178. Pics from the h-t meet @ MapleGrove
  179. Alternator Bolt Broke HELP
  180. eletrical problem
  181. engine stall i need help
  182. swap question
  183. Exhaust Question (engine swap)
  184. Fuel Tank Question
  185. heat hand--very strange
  186. Need help with front turn signals 88 Crx
  187. head swap
  188. ECU codes 43
  189. I Need Wiring Help
  190. Stupid Question
  191. What should I look for before buying a wrecked Civic?
  192. please i need some advice!!!!!!!!!!!!!!!!!!1
  193. using a multimeter
  194. need help tried everything
  195. so yeah, rear seats in crx?
  196. Heat Shield
  197. some quick seat help
  198. LS Swap Code Help
  199. Super Charger 91 CRX SI
  200. dust cover?
  201. need some advice
  202. High RPMs and oil
  203. Help with a 90' honda civic fuel system!!!!!!!!!
  204. sway bars
  205. ZC performance?
  206. Relay
  207. Rear intermittent wiper mod?
  208. Is 89 Acura seats in 89 Civic Hatch possible?
  209. how long do i have?
  210. squeaky hatch
  211. i need help !
  212. help with a 91 civic sedan lx
  213. my plug is stuck!!!
  214. head unit problem!
  215. is it worth it 88 crx
  216. mini me acting up
  217. D16 bore question.
  218. machine shops
  219. Issues with ignition timing
  220. '89 Civic SI Turns Over And Starts But Takes A Long Time To Start
  221. HF exhaust manifolds
  222. Long Block
  223. new to the forums...need some advice
  224. Help with 'no start'
  225. CRX Main relay or what??
  226. 89 sedan hood????
  227. head swap
  228. Almost Complete! Performance Question?
  229. H22 ina 89 Civic??? Can it be Done?
  230. My new project
  231. Parkin Lights
  232. Very Frustrated!!
  233. Need help ASAP
  234. Question?????
  235. Weird....please help
  236. clunking noise please help
  237. Ground issue
  238. Electronic rust protection?
  239. what car did this motor come from
  240. replacing RTA bushings on 90 civic si
  241. Rear Arch Trim
  242. Could someone with unlimited carfax reports help me get a report for my car.
  243. New Car
  244. tranny fluid?
  245. I need to remove these valves........
  246. vtec not engaging
  247. wiring for a obd1 dizzy
  248. Any ideas?
  249. Question About 88/89-90/91 Civic To Crx Dash Conversion
  250. 89 Crx Brakes
