Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '88 - '91 Civic / CRX |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
brakes
Help! Wire Problem I Think!!
replaced broken alt. belt, now won't start
In search of rear mud-flaps.
installing a turbo
HELP No spark!!!
Stuck In Mid Swap!!
Door Handles - Lubrication?
Need Help b16 obdo
Lookie what I got!
Underdrive Pulleys?
Turbo Question
How much?
D15B1 Timing
screeching noise?
Different camshafts
magnaflow exhaust
Clutch Issues
Possible Head Problem? I don't know
Ques?Boomslang Conv Harness d16z6 Swap
dizzy for ZC?
B16A6 Performance
Is this fuel or electrical?!
Possible Blower Motor Problem. HELP!
Door Latch? Ugh.
k24 swap
Another CRX won't start.
Tranny Question for 91 CIVIC
CRX wheels
90 crx d16z6 swap won't start help plz
silent chamber
what the heck is going on here, possible wire problem?
Civic sway bar
Suspension Advice
Tie Rod End
Swap gone wong, help..
1990 civic
tranny i.d
Homdmade Harness Converted
Need Help!canada 89 dx cluster swap
head questions
wanted some opinions
Civic 4g 1.6
Is this bad?
I Need Help With Vtec-e
Transformation
Driver Side Caliper Siezed :(
ecu
Lips?????
Want to swap ls/vtec into 89 dx
Hi Guys !!!
d15b2 pistons
Gas line replacement
Rings on D15B2
Problem with 88 Civic
Valve cover changes?
burning a cat :)
help changing transmission
D16Y8 Engine Swap
cold???
haha suckers
crx 89 dohc zc/d16a9 adjustable FPR
Need help blown head gasket??
transmission problem!!
Head Codes
...Z6 vs ZC...
deciding between CRX and hatch
fusebox screw
D16Z6 92 civic motor into CRX?
Extra tips to pass aircare?
Tire Pressure; per Honda
Pics of turbo parts!!
Timing belt Replacement writeup?
dc headers fucked
91 CRX won't start
exhaust pictures
tanabe exhaust
damn ricers
Inconsistent Idle and Check Engine Light
Wheel problem
88 suspension
89 integra?
Looking to Get rid of 90 Crx
problem with speedometer and code 17
window tint
A few Before and Afters.
crazy rims. have a look.
PICS of my car
place your bets.....
New Rims
Speakers?
When transmission is engaged...it's loud
87 CRX repair Question
Mirrors
tail light fuse/ small missfire
D15b swap in 89 hatchback si
gauges
bet you havent seen ?s about this before
car problems
pcv oil catch can help
need some wiring help please!!!
Gah! Rich kids are stupid!
trying to decide on a b series to get/boost
front bumper
dash/guage question
Omg my car sucks..
Carbon Fiber Sunroof
new car
subwoofers
no rpm
1990 honda civic cx
Code 12
1991 Honda Civic EX
F-ing Cobras
rpm prob
d15
Hf Mpfi
Dizzy leaking oil
d15B2 Pull Out Time?
dual cam ZC
transmission question
motor mounts..
obd1 conversion
energy suspension bushing peformance
1.6vtec head on 1.5
automatic crx rpm?
looky what I got ahold of :-)
Car got stolen into...
Wipers stopped
Before I go take it to the autoshop...
helllp fuse diagram
I'm back
Swap Engine or Buy New Car?
shop?
CRX Spongy / No Brakes
Out of curiousity...
A little of your time and mind PLEASE
Looking for some parts
Code 3 on d15b swap?
Almost ready to put turbo in!!
ZC or B16?
Catalytic converter question
obd-0 to obd-1 help
Timing Belt Snapped
Won't run past 3k rpm
cluster
hellllp car not running
help with clicking sound
po8 1 wire o2 sensor
Engine help
New Injectors for ZC??
91 HB steering wheel vibration when braking, any answers
Help Tranny Problem
Clutch slipping possibly??
map bypass missing link
obd0 to obd1 question
What Is Wrong With It
Motor Swap
rim color choice
Clutch cable problems
anyone REALLY interested?
Smoking Problem
Help converting front end to integra
89 CRX Engine Swap
headlight Question
will a d16a6 distribitor cap fit a never sohc civic motor (92-95)
need help with my alarm
swap sohc zc into 90 crx hf Problems!!!
how or is it possible
Do I need to replace my camshaft seal?
vtec questions
black smoke
bottom end rebuild
Harness Question
si tranny in crx
B16A: gouvenor?
DA front end on EF hatch??
da int. shaft
Help
running out of steam
rebuild
obd0-1 ecu wiring and ????? need help
91 Civic 1.5 Intermittently Cuts Out
Help with a air intake
subwoofer box
Washer Fluid Lines
wtf can someone help
Radiator Replace
civic distributors
1989 Honda Problem
Redline Question
new car
90-93 teg half shafts?
Good Buy?
Wiring Help
jdm front end
Where can i buy?
Clutch Pedal Vibration
Ebay B Series Mounts
Need Help!! Coilovers
exhaust
helllllpppp a couple of problems
Does 2000 Gsr Leather Fit My Ef Si???
Stolen Car!!!!!!!
Exhaust: Glasspack?
Ive sprung a leak!
What should i do?
help in phoenix
Wipers in "Feild Goal" Position.....
battery
hookin up speedometer
trans q
Temperature Gauge
Trying to replace a knock sensor..
90 Crx Wiring Diagram
'91 DX runs bad/dies with lites on.
1988 crx
PCV valve removal?
Boost Question
turbo???
Check Engine light, No speedometer
Resolved Rotor issue
ef 8 suspension help
speaker problem
BAM! lights are gone
new fog lights
Part list for D16Z6 Swap
Radio reception
fog light switch?
Diagnostic Trouble Codes
Gas Fumes?
Tail Light Mod
91 civic dx stubles
heater issue..
rim size ???
for the money... B20 or H22 both built
hmmmm
Pain in the A$$
asap asap asap
Alternator dead?
help me for a sec..clear shit up for a friend
DIY Alignment?
backyard motor swap?
Tailight Conversion
New car #10. Teaser Pic inside.
Help Needed!
Canadian parts distributor?
crx with 5th gen lights... how would that look?
Web
AF
