View Full Version : '88 - '91 Civic / CRX
  1. idles at 6k rpm !
  2. How the heck can this be?
  3. cluster question
  4. main relay clicking
  5. b18b swap question
  6. Stupid axle question
  7. turbo questions
  8. want to play a game?
  9. [Need Help] Code 9 after ZC Swap into DX Civic
  10. 89 CRX 1.6i 16 Valve UK Spec
  11. knock sensor
  12. i have 2 things i need info on
  13. dizzy code question
  14. Where to run Power Cable on a 90 CRX Si?
  15. Buying A New Hatch- Quetions...
  16. dizzy trouble
  17. Intermittent Battery Light
  18. My Car Dies Out When I Hit The Gas Hard
  19. D16 head on D15 block
  20. Axel nut
  21. d16a6 or mpfi swap in dx.
  22. d16a6 into dx, wiring
  23. what engine should i swap into my CRX SI?
  24. Re-raising car
  25. Question about insuring CRX...
  26. eBay Spoof site...
  27. To Port or Not to Port, that is the question...
  28. b18c turbo crx
  29. racing harness help!!
  30. overhauling motor
  31. what exhaust do u have??? (poll)
  32. SOHC versus DOHC
  33. What would YOU bolt in a CRX?
  34. Harness Swap
  35. Juice
  36. F20c(s2000) bloc with B18c5 (Type R) head
  37. turbo manifolds
  38. swap question
  39. D16Z6 swap into 1989 Civic Si
  40. what dash fits..
  41. PICS: New CD Deck and Gauge Light Color
  42. ARP Head bolts and D16A6
  43. the engine revs itself ... maby its proud?
  44. b18 a or b18b
  45. help my car is a dx need to know what color the tach wire is
  46. Alternator issues
  47. video of my car
  48. HELP:91 civic 4spd w/ls motor
  49. OBX-R Cams ???
  50. a/f gauge
  51. Headgasket?
  52. 1.5 and 1.6 . im curious
  53. Exhaust sounds like crap...
  54. advancing my timing
  55. Wtb CRX hitch
  56. 88-91 Civic HB and CRX exhaust the same?
  57. Something wrong
  58. lsvtec
  59. 91 Honda Civic CX Only Runs For Few Seconds
  60. axle
  61. short shifter probmlem need help
  62. Injector resistor box
  63. Who all went to Nopi Ntls this weekend?
  64. what dose every one think is better brembo blanks or cd and slottt'd
  65. 91 si seats into a 88 dx
  66. need some info
  67. vafc??
  68. B18 alternator...
  69. Tranny shifts fine when engine is not running but, shifts hard when engine is running
  70. Ignition coil
  71. need help!!!
  72. JDM dieing out?
  73. 90 CRX Fuel System
  74. 88 Honda Civic Knocks When Turning
  75. cam gear question
  76. pulley
  77. top speed:89 crx(gutted) with b16?
  78. d16 hatch...nitrous or turbo?
  79. gutting the cat
  80. uh-oh.
  81. need help car smokes out intake
  82. b16a swap guide
  83. I need help on buying an H2. Just need some opinions.
  84. Anyone going to Nopi?
  85. Is it a challenge to change motor mounts?
  86. heh, since i'm new..
  87. uhhh ooohhhh
  88. custom 2.5" exhuast vs stock exhuast w/ cutout w/ 2' pipe
  89. question for all you d15 drivers
  90. timing issues?
  91. replacement body panels
  92. Re-Calibrate your tach!!
  93. Need your input on my new set up
  94. D15b
  95. i'm gettin an arm rest... I'm gettin an arm rest !!!!
  96. just to make sure (shifter linkage)
  97. Car Won't Start!
  98. damn main relay...
  99. Dam Garage Just Charged Me $90.00 For Nuthin
  100. si seats in a cx
  101. Almost did it
  102. got my gtech today (my results)
  103. Warped Rotors need help
  104. connecting air/fuel guage
  105. need a/c im sweatin by balls off
  106. Blown Head Gasket?
  107. Braking shaking and knocking
  108. body kit for crx.
  109. Springs move out of seat???
  110. 88 civic DX Gauge cluster
  111. Need online manual
  112. another ECU Question
  113. My brakes are smoking?!
  114. Need Help ASAP
  115. need somewhere to put my arm!
  116. crank pulley?
  117. Which parts switch over?
  118. needed
  119. 1.8 clearance
  120. Bent Frame
  121. are these brakes good enough
  122. need help
  123. UK JAp Car show pics (mostly CRX)
  124. H22a dream is commin true!
  125. chiped my B16A1
  126. replacement carpet
  127. engine overheating need help:S
  128. 90$ hatch seal???
  129. Fuel pump
  130. Old beater out, new hooptie in
  131. help me plz
  132. abs
  133. Suspension techniques question
  134. ls,rs,gs
  135. Where to buy steering knuckles
  136. Squeaky Distributor?
  137. Y1 LSD in a S1 tranny ?
  138. installing clutch disc?
  139. Body kits for 4g4d civic 88-91
  140. PLEASE HELP!! :important b16a axle question
  141. Axle removal
  142. The Bourne Supremecy: Movie Review
  143. came in second place in the db drag
  144. Clutch questions...........
  145. I got two CRX's problem is...
  146. PepBoys won't align my car
  147. JDM CRX for sale as well as many other cars
  148. fuel, coil, relay????
  149. Confused with camber kits.
  150. seriously off topic car audio question
  151. b16 turbo
  152. Help Me Plz!!!
  153. Maybe fuel?
  154. replacing my d16a6 for a d15b7
  155. help removing flywheel bolts
  156. Painting carbon fiber hood.....?
  157. i need help...
  158. New Interior Upgrade
  159. Finished brake job, but one problem
  160. Hood options...
  161. hehehe i'm a tease :) (pics)
  162. Transaxle mount
  163. Cluster Swap
  164. Need help PLEASE! Mini me probs
  165. Air Conditioning Vents
  166. traitor D:!!
  167. Clutched replaced, reverse now grinding, can't get into gears!
  168. Type of Music
  169. july 31st Bend, OR
  170. I got the car jacked up!
  171. Help me seperate my tranny!
  172. new OEM source...
  173. F/S '99 Black Civic Coupe
  174. Goin to look at a car
  175. code 20
  176. crap Classifieds only thread.
  177. home made ITB
  178. What do the tire numbers mean?
  179. rad swap
  180. TUNER TRANSFORMATION does a CRX
  181. PGM FI main relay fix?
  182. Cast iron exhuast cut-out
  183. HB lowered on 17"s
  184. My New project
  185. 1badcrx????
  186. 92 ls spindle and callipers.
  187. What Can Cause A Weak Spark
  188. Break Problems
  189. DOHC ZC larger intake/tb cause problems
  190. Howdy Ya'll
  191. Brake pedal adjustment?
  192. [Need Help] Problem after ZC Swap
  193. body kit
  194. Mini me Users --> Was it worth it??
  195. Ebay is going nuts.
  196. 88 Honda civic won't consistantly start when warm
  197. z6 head on.. turns over but no start
  198. tire size
  199. RPM Tach...
  200. Help! ZC problem
  201. 91 civic info
  202. best for TURBO
  203. electric
  204. O2 sensor questions
  205. 5'' tach problem
  206. wich one of these motor is the best set up
  207. exhausts(give me your opinion)
  208. OBD0 to OBD1 conversion having problems.
  209. 89 civic won't shift past 3rd tach only goes to 3500 rpms.
  210. What should I set my shocks at for daily driving?
  211. tach problem
  212. The washer trick?
  213. VW lip fits the Hatch!!!
  214. I need a passenger fender for my 91 crx
  215. ZC crank = d16a6 crank ?
  216. Need a beverage holder
  217. b16 parts
  218. 1 reason to watch your car at shops....lol
  219. Will obd-1 dizzy fit my crx obd-0
  220. smoking tail pipe
  221. A wierd thought.......
  222. Cars on ebay
  223. Painted Valve Cover
  224. 90 std hatch questions
  225. where can you find good alternator for sale for cheap
  226. New Coolant????
  227. mini me swap question with 88 dizzy
  228. d16z6 out of delSol if i use delsol computer...
  229. Radiator fan
  230. gastank question
  231. What OiL and spark pLugs do you recommend?
  232. Tutorial on b16a conversion?
  233. anyone have pics of the R33 style front bumper on a HB?
  234. looking for a a6/b2/b1
  235. Me vs Teg GSR (video)
  236. whats is the zc enigne number
  237. will this center console work?
  238. Positive Output after Start????
  239. which motor should i get?
  240. How much boost???
  241. 8 injectors on a turbo si???
  242. 91 dx civic for cheap
  243. Grease ball joints/Messed up injectors!
  244. Muffler ?
  245. Parting out an 88 CRX si
  246. making carbon fiber
  247. Where My Florida Peeps??
  248. Female Member Roll Call
  249. body kits
  250. Damn master Cylinder...
