Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '88 - '91 Civic / CRX |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
D series R'active header..
Main Relay
91 Honda Civic...License Plate Lights..
master brake cylinder ?
5500 RPM limit?!?!?
vtec problem
found hf crx what do i take
90 crx W/b16 axle question
91 Civic Dx...License Plate light replacement
91 Civic HatchBack
brake question
91 Civic Dx Manual 5 Speed...What motor can I swap ??
ZC Stumble
engine help
cluster ?
91 Honda Civic DX....cv axel needs replacing
Diff's between A1 and ZC
found older si civic
head question
cooling
No Start (Fuel Pump Question...)
tranny prob
How much Power can a Stock Internal D15B2 Handle?
Swap ?
Front brake rust problem
89 Civic dual-point FI to mpi
Trailing arm Bushing question
89CivicDX - Question on header and fuel
Swap Idea
Opinions please!
Problems Problems ...
Car won't start!! Immediate AID!! Please!
Brake lights messed up/stuck in park
CRX seat belts
stock air intake question.
now that i got the trans in i have more trouble
What color?
HID's in my CRX
90 Civic Hood Types
rear disc brake lines
Hallelueah!!!- Niagra Falls is dry!!!
turbo ?
91' light short
tranny PROBLEMS?
HELP! a/c comp. blowing fuses-crx
90 Civic dual-point FI: Best place to Check Fuel Sys Pressure?
Window problems
glass question
speedo lights wont come on
Dash/Console swap
axle question
Possible to clean the ignition switch?
b18b in a 91 EF-Fan Problem
91 crx Si speedometer swap....
'91 Civic Won't Start
B18A1 Problems
aftermarket tachometer
alternator question.
crx wont start.
Back!
17yr. old body seams = Niagra Falls
what seat brackets will work for my car?
CRX sunroof problem
2nd Annual Maple Grove PA Honda Meet OCT 21st!
B16A2 w/Hydro into 89 ef sedan HELP
Omg...what's Wrong??? Please Help W/ My Si Civic
Help! How bad is it?
light connection
on to a darker side
91 cx with 1.6?
corner light blub help please!
Car wobbling
Hesitation and backfire
took some pics of my EF
Help!
Updated pics finally. Been working on her for over a decade....
Password jdm hood dampers.
help
Messing around with LEDs
fuel filter question.
Removing Seats...
PLS HELP!!! 1990 Honda Civic CRX
Replacing Radiator....auto tranny
crx
Recently acquired civic
type r lip
Need some help
zc dohc help
The day is finally arriving!
1990 civic DX HB - clutch problem (manual transm.)
What Dizzy should my 1990 HF have.
skunk2 d16 intake manifolds
NOOB 101; Where do you go to buy engines/ trannies for swaps etc...
Crx Problem..need Help Fast
Just bought, what to do?
no vaccum?
My pics of the crx
need help fast
01 D17 Crank pulley on Z6
Tampa Where you at????
D15 to B18???
Help :(
Flywheel Help Plz!!
<b> I Need Help !!!!!
89 crx hf with ls b18a1 and 4 wheel ls disk breaks for sale!
So I got another EF...new winter beater/daily driver
'91 Civic questions
cowl hoods
zc problems
aftermarket head gaskets
rattle car :)
temp gauge and fuel pump?
Ecm
she died on me today :(
tranny refill help.
Need expert's help: 91 1.5 TBI Doesn't start well when hot
p1 front lip
valve/cam timing
Battery Light??
aftermarket header
i need help any 1 please !!!
I Need Help Badly!!!!
Clicking from brake
Electrical Issue
Civic 90 dash issues
Clutch Problems
odd noise when i turn corners
better wheel size
90 Jdm Crx quick and cheap upgrades???
driver axle install help please.
Fuel injection help
New engine, new motor mounts?
complete H-series kit?
stripped CRX
Which Intake to buy?
How good are the $40 eBay headers?
Headlights No Workie! Help
odd noise (front end)
what trans fluid
91 si hatch jdm trpe r swap
body advice
A/C heater controls
89 civic dx - brake pedal issue
speed sensor
New way to remove trailing arm bushing
1988 honda crx hf rear suspension
header question
89 Civic 1.5 DX. Front Brake Maintenance.
stock 1990 civic with rev limiter?
weird noise in front
89 CRX main relay
'88 civic hatch 4spd
89 civic
New spark/wires, now no speed?
Head question
H23 Engine Build
master cylinders
crx decal.
Suspension and brake advice
hatch struts
got a 91 civic dx need advice
91 CRX for 1500
Inner joint problem
CRX Si sunroof
1990 civic won't start
wiper problem
the main difference...
My car comes home..
Squeaky clutch
torque spec
Engine change (transmision?)
car wont start.
Map sensor
crv vtec
civic tow rig
stupid question - Search option
Engine RPMs go Up and Down - Urgent please
lots of problems..
Looking for some opinions..
can I change the Trans?
typer springs
is a cold air intake right for my car?
Hello!!!!
New and Need Help... Fast!
a/c overfill?
Spark Plug Gap
Wipers Stopped
got my hatch.......FINALLY :D
timming
4th gen engine swap
tranny problem
USDM engine sales
91 CRX Started but stalled
k20a2 swap
Smoke and oil form exhaust
IAT sensor location
1.6L DOHC ZC for sale in Bronx NY
Bought my CRX today
running rich?
whats a faster??
B16 and crv tranny?
mini me questions
Fucking Thieves...
A/C Thermostat or evaporator temp sensor ... same thing?
info on a 1990 civic si?
Running Problems - Need Help
Coilovers & other suspension
Value of our cars? (feel free to post whore)
1991 Honda CRX Swap.............
d Series 8 or 12 Valve Head
B16A into 91 civic axle question
Civic 91 side skirt
90 CRX LOOKING FOR jdm D15b OR OTHER.....
tranny question
90' Civic + 90' Integra Front End Swap
2nd gear
flywheel question
cluuuuuuutch
Need advice on b20 swap
Hitachi HT12 Twin Turbo Civic
CRV Question
shit more problems?!?!?!?!
Fresh oil solves consumption problem
Fuel in Radiator....
Wiring Harness help!!!
E-brake....self adjusters?
89 crx wont rev past 4000
91 CX idle erratic cuts out and in
What swap?
Speedometer cable end/pinion stuck...
88-91 crx climate control unit issues
fuse diagram pics please
Buying CRX Tomorrow!
hey my build link
D16A6 turbo swap
91 civic - rattle in front end
help me - Fuel Pump
STUPID FIX IT TICKET! I need your opinions.
Integra sporting its new weave
Integra radiator in Civic?
D-Series Single Pulley
mpfi swap help
ah sh-t anouther one bites the dust
civic won't start
Spark Plugg problem
how to belt removal?
Bad Transmission?
It's painted!!!!
nology hot wires
tranny fluid
Web
AF
