Our Community is 662,000 Strong. Join Us.
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic | CRX
> '88 - '91 Civic | CRX | Wagon | Shuttlee
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
cant find a good idle
code 17
90 civic fuel prob
new headers problem
lights going crazy, could use some help
bad idle, and elc problem
stock d16z6 and the d15b vtec(w/pm6 rods) - w/ p29 dome pistons
90 civic / high rpm's or no start
K24 Vtec V.s. G23 Vtec
Stock Axle wrong size 91 civic
System short
Starting problems?
oil cooled vs oil and water cooled turbo
D15 help
rear suspension combo questions
please help me get my b16 90si running
turbo oil return line ect.
H22A to Civic coil connection question
White Faced Gauges (Km/H)
Is it possible to swap a 20 spline 4 speed m/t input shaft into a 21 splined si trans
Ammeter, oil pressure, water temp
Random plug and integra console swap
da vs ef rear lca
Honda Swap Meet **pics**
switched 12V problem
I have 1 pm9 m/t ecu and 2 pm5 a/t ecu's and a d15b2 w/ a m/t.
A question
88-91 D15
HELP! Car alarm removal gone wrong....
Will 88 crx parts fit a 91 Crx
reverse lights?????
question
Need a helping hand North Chicago
b20a5
89Civic1.5DX Hatch - Replace hood
89Civic1.5DX Hatch - Engine coolant Drain Plug
Steering Rack differences
A few '91 LX questions
suspension info
timing belt question
hand brake light not working
give me your opnions
car failed smog
B18B1 OBD2 to OBD1
Civic89DX-Emission Test Failure.
oil pressure problem
Engine Swap
car wont start
Horrible gas mileage... Any ideas...
Fuel Problems??
Fuel Problems??
1990 SI Electrical Problems
sway bar upgrades
Rear Mud Flaps
traction bars
My car wont stay on :(
lsd tansmission?
injector Q's
air/fuel
b16a1 swap question
GT Live '08 @ VIR
clutch problem
Temp gauge problem
MPFI Conversion for Dummies
91 Civic 1.5L Stalling problem...HELP!
Where to ground on Thermostat 88 crx dx
89CivicDX1.5 - Question on fuel
How hard is it to replace crank/cam seals?
NEW FAQ: Please read before posting! That means you!
got some work done today
Removal of Control Arm/Bushing
How to install radiator? I removed it, just want to see best way...
obd0 to 0bd1?
Best Crx Dx Swap!!!!!!!!!!!!
Whistling noise in intake... WTF?!?
90-99 spark plug question
Axle question
1990 civic dx swap please read and help
B-swap confusion
Air intake for 88crx dx???
90 Civic - flooding/fuel in intake manifold
Honda Axles
88 crx dx coolant question
88 crx dx temp gauge
Weight Reduction - Ceramic Heater core.
civic ac/heater
My own MPFI swap
Water for fuel... the longest single post I've ever made.
Smoke coming from steering wheel
New toy
Body part question
2 questions...crx sunroof and motor
A few wiper questions
Serious gas smell
CRX question
hondata s300
B18 crank pully rubbing on traction bar!!
wiring problem
ODBI Distributor wiring
91 civic distributor swap
Suspension questions CRX
92-95 zc sohc swap
What's with my Honda Accord? ! HELP PLZ! !?
88 Civic DX Cluster... swapped, now runs rough!???
90 civic "zc" fuel problems
90 Accord
Anyone Instrested In A Jeep Cherokee?
Water Temperature Sender Attachments
adjustable fpr
need motor swap info on my 88 si'
no pedal when i crank the car
running rich
Don't make this mistake
headlight turn signal trouble
Automatic seat belt
89 civic
89 civic 1/2 tank stalls
would 92-95 upper ball joint fit 91?
swapping seat backs?
jdm swap + smog troubles
88 CRX Si "popping"
skipping and sputtering
1987 mugen crx stock
what would be a good motor for my ef ?
Motor Mounts??
99 civic lx green paint is fading off?
what should i do to the b18a1 motor that is in my ef?
b18c1 overheating and injectors????
P28 ecm for mpfi conversion on d15?
91 civic Timing
Axle Help - axle to intermediate shaft disconnect
94 Integra Seats in EF???
Will a 5th civic coupe center console fit??
CRX dies after starting, and it stinks like gas :-(
no power to starter
what is this and why is it like this?
any axles from other years/cars that will fit?
91 Civic LX Sedan - window/lock problems
Fuel cut
Crx Zc Injector problems
I thought about this a long time ago... but never went ahead with it.
Fouled spark plugs?
starter help.
FIRE makes it way out of my intake manifold!!!
Honda/Acura Mini Meet in PA @ Sonic
zc into 91 civic dx
Sloppy Shifters...
Anyone put a 96-00 center console in their 4th gen?
zc head for sale
Exploring subwoofer mounting locations (opinions)
Carburettor Qs
Removing rear wiper arm
Upper coolant hose adaptor question
Auto Transmission fluid Qs, please help!
car giving me problems
hesitation in first three gears
~~> my project thread <~~
88-91 or 90-91 tail lights
Well....
Pics of the new project *56K warning... go take a shower and shave or something...*
freshly rebuilt goodness
Hood Latch Came Off! Help!!!!!!!!
I said I'd do something about it...
wiring problems help
ZC Swap Questions. Help!
zc injector swap issue
B18 Swap issue - really weird
cluster with tach work in non-tach car?
I would like to lift my CRX
Need help on A/C evaporator?
What should I do?
Best lowering springs?
To the Drawing board
okay so this 91 civ is pissing me off
How much louder will this cat-back be?
New to hondas and this forum
Fast Idle Thermo Valve
My new B18A1
No Bumper Covers...Legal to put license plate in rear window?
Which seats will fit?
sorry for asking but
1.6 to 2.3 upgrade
o2 sensor
U call URSelf a CRX Enthusiast
Anybody Tried Pulstar Plugs?
painted the wheels
Alternator
23 vs. 26 spline cv axles
replacing my tranny
How i spend my day off..
My new hatch
91 honda civic won't start
91 civic swap with zc??
changed a head gasket car wont start. need your help
quick and stupid question
please help....temp. gauge
Passed Emmisions!
89 civic 1.5 threw the timing belt
dash lights/parking lights
hacked suspension question
JDM CRX Manual???
4.25.08 - 4th Gen Civic Meet
Identifying B-Series Transmission
ECU light won't stop blinking
Please help with my civic
so i just bought a 91 honda civic and...
Who says you need a truck to tow a car?
Help! Super Extreme High Idle!5000rpms!!
resonator
high beams won't work
My yearly visit :)
buy from junkyard OR buy from jdm shop?
'89 Honda CRX Exhaust Question????????
over heating, well almost
lowering the civic just a tad
sputtering question
Buying used engine from Craig's List?
any EF meets in New York area?
Moisture - front passenger area
a/c problem
Main relay issues.
pics of the new daily
price'n parts
simple question
speed sensor
fronts brakes followed by other fun issues
tranny swap help asap
Help
Code 20 Code 7 How Do I Fix It? Please
MPFI Swap...Yes I know it's been covered...
Hydro disc in cable tranny.
Driver Side Vent blowing Outside Air
91 DX to b16 88 si style seat belts
buying car choice between 2, which is more modified
1991 honda crx k swap questions
A/C blowing hot air (91,civic-LX,1.5L)
emission test result bs??
Need help or any suggest for civic 91
ebrake handle
1991 crx need opinions
distirbutor connection
Got some Money.....
tenrai exhaust and Iowa Winter
Looking for a vacuum diagram for the 97 JDM ITR motor??
Injector resistor box
91 CRX bumpy ride, need some info
Holy wheel gap Batman!
No Spark, No Start, Help Please
Finally Got My Wing On!
Automotive Network, Inc., Copyright ©2012
