View Full Version : '88 - '91 Civic / CRX
  1. HELP!! Gas smell in exaust
  2. My 91 Si, theft pics, 56k alert!!!!
  3. bored so i took some pics
  4. Made to order body kits, Anyone interested?
  5. Picture of my broken spark plug things and valve cover (7 pics)
  6. Ignition switch broken wiring help?? Thoughts?
  7. More Motor Pics *Bottom End Done* ***56k Beware****
  8. ZC DOHC Valve Cover removal
  9. Engine Trouble
  10. Doing a brake up grade...
  11. New pics of my car ..tell me what you think
  12. You Son Of A......
  13. New BMW M3 vs. CTK
  14. TURBO PIC (more to come its late long weekend) Thanks GTA FOR THE HELP
  15. Look how I saved a Civic this summer! Lots of Photos
  16. Just got a B18C1 for cheap - need help!!!
  17. One wheel in the air...
  18. camber kit question
  19. Tranny Identification?
  20. B-series flywheel cover?
  21. APC reputation??
  22. b16A engine swap...whats needed?
  23. 2 1/4 or 2 1/2?
  24. help no one knows in my town
  25. Australian 4Dr 1990 Civic
  26. removal of the headlight or bracket..help
  27. Is This...?
  28. Skunk2 springs
  29. JDM automatic Climate Controls?
  30. CRX - funny idle - weird starter
  31. Boring out a dohc zc.....
  32. 5Zigen R-Rate springs in my civic
  33. new car...what to do?
  34. Confused?!
  35. 88 Idle Air Control Valve Troubleshooting
  36. Alright, one more shot
  37. Brake master cylinder?
  38. Battery light
  39. Colorado CRX
  40. Setup sound good?
  41. Injector Resistor Box
  42. exaust...
  43. The big B18A turbo let down
  44. cv-joints
  45. Turbo
  46. Resonater?
  47. where can I get some tips on cleaning an engine bay??
  48. email address
  49. oversized fuel injectors
  50. whats wrong!?!
  51. gearbox ID and mainshaft repair
  52. Kick panels are same for Civic and CRX correct?
  53. woo hoo Finianlly she runs!
  54. D15B1 is a POS............
  55. Stock CRX si 's sure are hard to find
  56. e bay rotors is it posible
  57. Idle Control?
  58. how do i remove the steering arms?
  59. turbo or supercharge
  60. Turbo or N/A?
  61. si cam w/ dpfi?
  62. ZC motor, B16 head swap?
  63. ZC final drive in SI tranny?
  64. anymore 4g people from the bay area?
  65. coilovers for my Sedan?
  66. 1990 sedan exhaust options
  67. fuse #35??
  68. Polyurethane set
  69. i need a fuse box diagram
  70. my guage light and tail lights dont work
  71. high compression
  72. Good Turbo Setup?
  73. Correct Parts needed?
  74. sputter/bog
  75. Center Console attaching points
  76. problem with '89 windows
  77. Selling SI
  78. weird idle new o2 sensor and crazy noises
  79. How do you do a crx auto to manual conversion wit a ls motor
  80. What Pin 2 Use ??
  81. Decisions Decisions
  82. Help - Break lights stay on
  83. Compression Ratio Question
  84. 1-4,000 rpm's not running smoothly??
  85. Smoother Ride
  86. What size tire you think would work?
  87. tempature guage
  88. performance headers
  89. pic of my car
  90. fiberglass racing parts
  91. frustrating noise
  92. Help!!!/Opinions!!!
  93. 3rd gear grindage
  94. my hatch wont start!!
  95. what size exhaust?
  96. Blew My Motor (pics)
  97. How hard is it to change.. valve seal cover gaskets, and the seals on the spark plugs
  98. Anyone in Southern California that can help?
  99. Climate Controls - Changing Bulbs
  100. CRX Water Leak!!!
  101. RSR drift festival kicked ass...anyone else go?
  102. Toggle VTEC
  103. Si in progess
  104. Electrical probs
  105. need urgent help
  106. HELP! trying so sell my rex what should i do?PICS
  107. LS/Vtec Swap
  108. where to buy an engine online?
  109. Two engine questions
  110. need help crx...
  111. Difference between the PM6 and PG7 ECU?
  112. ECU Code # 20..??
  113. junkyard parts
  114. Well if PhatCX is gonna show his... I'll show mine... 56k No No
  115. Making a stronger rear bumper, need advice...
  116. d15b1 vs d15b8 w/mods?
  117. Went to the track with the ZC again...
  118. Need help fast!!!
  119. All honda brochure pics
  120. buying a new car!
  121. check this out (56k warning)
  122. Si Tranny
  123. ZC acting up????
  124. Will an LS header fit a DOHC ZC engine?
  125. 88-89 4dr front bumper on a 91?
  126. ZC Ideling High....and more
  127. first side banner now ads in the threads themselves?
  128. Bumper Grille...any good?
  129. Centerpiece Problem (pics, 56k beware)
  130. Is there anyway to tell if timing belt is going?
  131. what fits my engine?
  132. Visit to the junkyard
  133. Crankshaft gear????
  134. Differential Bearings...
  135. Evry Cloud has a silver lining
  136. CF Lip
  137. gonna start fiberglassing
  138. Hybrid 91 civic B18 swap no start, no injector pulse, please help
  139. An other overheating post...90 civic
  140. The Dark Side
  141. i need to know what every one thinks about this car?
  142. Chrome Trim
  143. 4g4d Center Piece Needs Fixing
  144. 90 integra console
  145. Radiator
  146. Engine Swap B16a or D16Z6, 4G4D, Oppinions, Technical Advice...
  147. bumper help
  148. B18 REX Vs. Mini-Me REX
  149. My new rex
  150. d16y8 swap, pics
  151. Anyone Clear This Up?
  152. Wrong forum but I need help fast
  153. swapping motors
  154. Rev with gsr cams?
  155. Throttle body questions
  156. where can I get some Eye brows
  157. Help removing this
  158. how do you get this off...
  159. CV joint help
  160. Info on VX Rims
  161. Integrated Boost Guage
  162. d16a6 swap help
  163. crx questions
  164. Some Pix Of My Car
  165. Can't Get ZC Swap To Start
  166. 89 CRX Si
  167. Anyone know how to...
  168. Rubbing/Bump strip Q
  169. does anyone know any bay area dealers of JDM ENGines?
  170. which Acura axles for my 91 Zc to fit my 75 Civ?
  171. B-series axle question
  172. hatch won't latch shut??
  173. My 1989 DX/ZC Turbo
  174. Power Door Locks
  175. need o2 help!
  176. bubble backfire sound,out of muffler
  177. ZC problems
  178. d16y7 head
  179. what kind of time?
  180. Sunroof Q
  181. Putting together my crx today!
  182. My boys dyno! (197 whp all motor )
  183. How to>>subwoofer
  184. Mini-me You complete me!
  185. question about painting
  186. Alternative valve bolts for Y8?
  187. Picture Request
  188. ~ My 1988 CRX Si ~
  189. how do i know if my timing is right
  190. Swiss cheese airbox
  191. wtb: 88-91 civic hb parts
  192. 1989 Civic Timing Belt
  193. check engine light problem
  194. My crx progress thus far, 56k maybe
  195. Polished my rota's and some new fresh pics...
  196. Intermittent Starting Problem
  197. Resident Evil: Apocalyse: Movie Review
  198. Check Engine Light
  199. Pics of my rex (work in progress)
  200. Seat bolt patterns?
  201. Tell me what you think about this SI
  202. A6 powered Del Sol?
  203. lsvtec
  204. A working electric CRX!?
  205. I brought home the replacement today
  206. pics of my 4 door
  207. Selling price?
  208. update on my set up...
  209. redid my taillights
  210. Engine #7...welcome to the darkside pt2 (pics)
  211. Autolite bad? NGK good?
  212. D15A2 Timing question
  213. CRX gauge cluster PROBLEM
  214. tradin in the hatch for a rex, part2
  215. Polished HX rims! (pics)
  216. Thinking thinking, need some advice.
  217. CR-Vtec Swap
  218. camber kit installation
  219. b16a1 swap question
  220. o2 sensor
  221. 275mm tires on a CRX (no, i'm not retarded!)
  222. Engine bogging on down slopes
  223. ZC Distributor problems...Need Help NOW!
  224. How can I calm down my new exuast
  225. What throttle body goes on a skunk2 intakemanifold for my 91 honda civic si
  226. aftermarket tach
  227. How do i intall a short shift?
  228. goodies in the junkyard.
  229. Pre-88 Civics
  230. C Pillar Install Help
  231. Tranny help
  232. I'm at work till 8, ask me anything (Parts dept @ Honda dealer)
  233. does this fit????????/
  234. I think god hates me
  235. woke up this morning,my car wont start!
  236. Repla CV Half-Shaft Assy, left, right, what?
  237. b18 injectors
  238. turbo question
  239. Been a long time
  240. ZC problem possibly sticky
  241. just wondering..
  242. swapping b18a1
  243. Public Service Announcement
  244. My day at the track...
  245. No More Car Fax
  246. All Wheel Drive CRX
  247. High Mileage
  248. charging problem
  249. Need some help w/ VAFC install on CRX
  250. Swapping heads
