View Full Version : '88 - '91 Civic / CRX
  1. Rebuilding Bumper AGAIN!!
  2. What are my other options? (Throttle Body)
  3. Reading the Ecu
  4. Teg Parts on 89 Hatch Questions.
  5. Gauge cluster pictures!
  6. how moch does it cost
  7. Bracing/ changing the rear seat on my '89 CRX
  8. Shortie radiator question..
  9. Hatchback ALT.
  10. how do i??
  11. swapping trunk and tail lights?
  12. Speedometer cable f.y.i.
  13. '88 CRX needs new clutch
  14. Anybody ever get one of these tickets??
  15. teg rear bumper
  16. lsd
  17. redline
  18. Teg Lip
  19. if you could have......
  20. air intake for hseries swaps
  21. 91 civic ex engine idle thrusting
  22. Question about rpms
  23. will somebody finish this once and for all, WHAT HONDA is my engine from???
  24. engine oil for honda civic 1991
  25. DPFI/MPFI difference overated?
  26. tranny question
  27. 89" Honda Civic Hatchback...what all can i do with it?
  28. help with V.I.N. locations
  29. 91 civic ex overheating
  30. JDM ZC engine parts
  31. New to the CRX
  32. converting to ob1
  33. Help!!! CRX Head swap didn't go right!!
  34. Poll: Do you like the stock look or body kit crazy look?
  35. Owners manual info- oilchange
  36. What should I do???
  37. right side clunking
  38. What is wrong WIth my Civic need help
  39. relay/ no start
  40. Factory Shift Light? Or what else could this see?
  41. my mod shelf
  42. Will 4dr dash fit Hatch ?
  43. LOW or BAD Spark
  44. w0w
  45. Will thest fit?
  46. nedd help finding this
  47. Doors on my 89 CRX Si
  48. Engine Swap Question
  49. gauge cluster swap...
  50. glow guages
  51. Temp Guage
  52. B16 Engine swap Cost? please help
  53. B16 Engine swap
  54. I bought a new car, 90 4d ex
  55. Help Quick!
  56. 14x6 wheels??
  57. can someone w/ a WW RS kit measure
  58. Auto Wiring Harness Q's
  59. problem finding part
  60. tell me please
  61. New to me car
  62. will these fit my crx???
  63. no heat
  64. burning
  65. Difference Between HX and VX rims?
  66. Axle Question
  67. Before & After Pics
  68. removing rear wiper motor
  69. Just aquired my winter beater...
  70. damn emissions!!
  71. d16y7...
  72. codes 4 and 8
  73. bolt pattern
  74. Educate Me
  75. Engine Swap (heelpp!!)
  76. 4th gen Hatch with LS Swap $800-1000 Good Deal?
  77. Needinf Apexi S-AFC II wiring diagram for 89 CRX HF
  78. help
  79. a request for advice!
  80. civic engines!!
  81. they took it
  82. Trading a Black 1990 CRX SI......Fast!.....
  83. https://www.rockauto.com/
  84. teg alt
  85. Can I upgrade to a higher AMP Alternator?
  86. CrX'S for sale on thsi other site
  87. Euro conversion
  88. trany ?
  89. PGM-FI confusion
  90. Want to add some gauges and need help.
  91. ZC Spark Plug gap..?
  92. anyone used an e-manage?
  93. $50 if you help me sell my civic!!
  94. exhaust question
  95. Trading My 1990 CRX SiR....Fast!...anyone interested?
  96. bent frame
  97. curb weight of civic hatchback
  98. Question for people w/camber kits
  99. Hybrid springs
  100. Teg hood on hatch...
  101. 2nd Gen CRX with B16 $2000 good deal?
  102. Where can i get Nylon plastic welding rod?
  103. Location of PCV valve?
  104. new car i found for 650 obo
  105. Sold my civic....onto my next car
  106. anyone ever mounted 6x9's in crx rear?
  107. seat conversion
  108. CRX meet pics(100) 56k no-no
  109. dizzy question
  110. D15B2 DPFI to JDM D15B2 VTEC MPFI on an 88 crx...i need some help!
  111. the most BASIC question you've ever read!!!
  112. What would be a worthy successer to our 4g's?
  113. Are outside door handles the same on CRX and Civics?
  114. Can hit 5,000k or above
  115. In california need to buy a car for 1500.00 or less and in pay ments plsese
  116. crx 91 dpfi to mpfi won't start PLEASE HELP!!
  117. car won't start Help!!!!
  118. vacuum lines
  119. 90-91 & 88-89 clear bumper lenses same?
  120. H22 into a 89 hatchback civic
  121. Peformance and Mileage 90 CRX dx
  122. quick
  123. Fan Problem causing smoking?
  124. timing belt covers/valve covers
  125. What color should I do???
  126. New seat material?
  127. quick question. help!!
  128. new exhaust! what size?
  129. 2nd B16 O2 sensor
  130. having problems with my 88 rex
  131. Integra Console into 91 Civic LX
  132. Aiintake System
  133. What is this green one?
  134. New
  135. Burnouts!!
  136. 200,000 miles! (and counting!)
  137. Storing REX for winter...any tips?
  138. Got hit from behind...few ??'s
  139. Pig Rich
  140. trans
  141. DOHC ZC Valve specs
  142. D16A1 block w/ a Y8 head?
  143. B18A1 in '89 Civic
  144. hf manifold good enough for turbo??
  145. Sad day in Hondaland... got pics...
  146. Anyone got carfax?
  147. Best Engine Importer????
  148. I need an amp QUICK?????
  149. Eratic Idle
  150. Here's An Update on our last Civic
  151. std to zc swap, making sure
  152. Second Thoughts..
  153. b16 crx
  154. Electrical problem
  155. HELP Exhaust System fell out
  156. Underdash Fuse Panel Cover Clips?
  157. msd ignition
  158. will this engine and this tranny work?
  159. Will a baby seat fit on the rear JDM seat in a CRX?
  160. k24 in a crx
  161. dyno-run
  162. I found a ZC block 15 minutes from where I live
  163. fair trade for my hatch?
  164. Bad news about my ZC
  165. 02 Sensor???
  166. bodykit...
  167. $300 for an LS with tranny
  168. is it too big?
  169. Appreciative noob here
  170. Cruise Control........
  171. Dim tail lamps
  172. wow.. i've never seen this steering wheel before..
  173. ecu question
  174. Read This
  175. Fact/myth? injector
  176. pictures
  177. RE: Possible CV Joints AGAIN???
  178. Compatible Prelude parts for 3g accord??
  179. upper u joints question
  180. rear lights
  181. Here is the $500 teg, for my ls swap on my civic
  182. code 8
  183. chip
  184. anyway to tell if the main relay has been replaced?
  185. Turbo Intalled And Smoking Something Awful
  186. Finally a perfect exhaust for the DOHC ZC
  187. Damned Cluster
  188. Carfax Request
  189. How To remove the rear motor mount on a 91 hf?
  190. ? about the 2 in a 4-2-1 header
  191. clutch safety switch
  192. Upper Control Arm Can't Remove
  193. Which Aftermarket Igniter
  194. Back windshield..wtf
  195. Re-apolstering
  196. Sedan Euro/Clear Tails?
  197. A few questions..(1990 crx)
  198. 900 dollar rex
  199. Rear defroster help
  200. Anybody tried this?
  201. 4seed to a 5 speed
  202. SI Tran
  203. The End Is Ineviable...
  204. i want to drop my crx more.can someone help?
  205. help...
  206. dizzy problems
  207. Installing ES bushing kit
  208. H22a in 91 crx
  209. how much whould this cost
  210. o2 sensor question
  211. First eswap experiences MKII
  212. How did your first eswap go???
  213. help guys!! my car wont start!!
  214. CRX.Workshop.Manual & Vtec Supplement
  215. Difference between Release and Throwout Bearing?
  216. I hate o2 sensors!!!!!!!!
  217. Diff Exploding
  218. HeHe.. Alright!
  219. dx doors
  220. need sidemarker help
  221. How to clean and/or check o2 sensor?
  222. rebuilding the carb
  223. Steaming battery at 14 volts
  224. Turn Signals Not working :(
  225. tranny question, need answer asap
  226. my hatch, back from the dead (pics) 56k? eh..
  227. dang it!
  228. 90-91 Civic Hatch Guage cluster in CRX?
  229. Dashpot on MPFI
  230. Pics of the NEW $100 Civic..
  231. bound to happen!
  232. B16 + Turbos
  233. JDM Motors NOW legal in California
  234. Getting the damn insert in the back mount?
  235. stuck in eswap limbo
  236. New Carpet
  237. how to tell civic jdm and usdm clocks apart?
  238. Jack and Jack stand height?
  239. Just wondering
  240. civic crx ignition
  241. fun things to do with an extra d15b2
  242. Check Eng
  243. Im new To this..HELLLLP MEEEEEE
  244. new mods, PICS
  245. HELP! Distributor..
  246. hf vs dx
  247. 2 Days of bad luck, need a little help.
  248. injector question
  249. 91 civic hatchback
  250. to cold for cold air??
