Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '88 - '91 Civic / CRX |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
13' rims
cold rev limiter
no gas no spark ecu?
For All Zc Owners!
i-vtec I video. Shows how it works, pretty cool.
stomped a 240
Mpfi swap question?
Salvaged Title Inspection
Blue smoke?
Almost there...HELP!!!
f20b swap in 4th gen
anyone have the link to the tire calc?
91 CRX HF/d16a6 swap
noob seat question
What is the hottest car show on the east coast?
How do I Make a Mini-Me?
HELP!! - 18x7.5 wheels on 90 hatch - HELP!!
Check engine light and slow peddle response
Crx Cold Start? Help please...
trouble starting
now what
ECU and Engine Code LIST
Si gauge cluster swapped.
which computer for d16y8 swap?
Find that Short
Synthetic oil
piston/rod question for the B18A
Sideways: Movie Review
Oceans Twelve: Movie Review
trans issue!!!!
rattling in the dizzy?
Melting sparkplug wires
check out this website!!!
Ignition Trouble
90 Crx
tranny problem
CV axle clunking?
big brakes faqs.
Wierd Battery Problem
ZC parts and tuning
Zc in rex worth it?
blow by question
how many layers of fiberglass
Crank Pully Removal help Please
b18 Rough warm up
d16a6 high compression pistons in a zc
1st time CRX (HF) owner - check engine light question
remember the hatch that raped the skyline??
seat pan swap possible?
Rsx Engine In A Crx!!
pr4 or pm6
What do i do know?
civic 89 driveshaft
How much would a tranny go for?
Another Gasket Bites the Dust
Is This Car Worth Buying?
D16a6 n Zc
HELP!!! I need to kno wats need for a B18 engine swap
Paint Job Estimate
dpfi/mpfi d15 any !HELP! appreciated
insert pictures
What kind of plugs and wires are you all using?
Dx Axles To Si Tranny?
zc oil pan gasket
crx rear speakers size
here's a picture of my motor...nothing special
Crx SI to Civic DX
Front end conversion, Nice or Rice?
Misaligned Alternator belt shredding
body work help
88 civic hatchback
STD vs DX 4gCivic
distributor?
d16a6 or zc
ok need help
Problem with FITV?
Tokico brake line bracket
DOHC ZC Swap into 89 STD Civic idle issues
Alternator belt sqeaking wont stop!
nitrous kit install question
ZC misfire while hot help
taillight conversion
Turbo LS power?
y8 Intake Manifold on z6 Head...
Rebuilt tranny
questions on rebuild
pictures
Simple Question
Pointless update
anyone in San Diego
1.6 zc question.
fuel injectors question
Leaving the 4th gen/Honda family... for now...
X-mas Present?
Distributor purchase?
4-2-1 Headers hang way to low
Darn Seatbelt Warning Keeps Beeping!
Are there high performance axles
shredded axle
After Market Mix-up
Clunk when I shift...
Hood won't open
question about mpfi conversion from dp
Engine bogs and hesitates whn cold
E-brake light stays on
Can I use mixed brands of springs and struts?
Engine building question?
Best place for 12v+ and Switched 12v+ in the back?
Need help installing my cold air intake
Grill Mesh
A few problems/questions.
Other 4 x 100 rims
water in back of my rex
Water in air vents
I made a mistake...now help me do it right..
Looky, Looky what I found.....Concept drawings
Which adjustable cam gear for ZC
possible new car
88 CRX rear brake question/help
hey fuel injector problem
Intake issues
dc sports exhaust
HIN anyone?
check out my custom painted CR-X
Winter Car
Teg dizzy question
distibutor rotor is stuck!!!!!
Si transmission
89 CRX, Fidanza Flywheel #191161, will it work?
engine swap in cali
18 x 7.5 rims
wiring question stump?
sir gauge cluster
need help building up civic
Starter's
weird problem
starting problem, a lil help?
C-Piller Instalation. Asap Help
UGH!!! What axles with ZC tranny?
crx flare fender
crx quarter panel
UnderDrive Pullys
Oh, it's in and it feels good!
New To Hondas, Help me out with a Head question...
Motor Swap Question?
heater
Good Place for Shocks, and Coilovers
oh boy!!
High Idle
Woo Hoo
My Wish List
to vtec or not to vtec
octane rating.
cv-joins going out :'(
sohc pistons in a dohc
racing harness
Code 7
Projector Headlight Type
Headlights Dim
dumb question
touched the speedometer needle
SI brake upgrade
hatch leaks when it rains
Rear bumpers
Rear disc without control arms?
91crxsi need part number for skunk2 camber kit
91 civic hb pics
cel code 8, tdc sensor
heater control help needed!
crx vs alero
Awd Crx?
Exhaust Pipe
Legit Motor or Not?
did I go to cheap?
What Engines Will Fit
dpfi to mpfi
What wires go where?
Tokico Strut/Spring set
dx running like poop need help!!!
Restoring body
Tail Lights
Suspension recommendations
Air ride susp?
Ansa Axle Back Exhaust System - Group Buy
d16a1 and zc
coilovers
ok final thing need help with my swap
Vti
ECU code 23
i need some timing or distributor help
will it fit?
Another odd Swap question
ecu fuse blows
Check engine light...
Loud 1st gear
PG7 or pm6
zc in a 95 civic
96 rhd integra
Best Zc Ecu
Tranny noise
clutch or gearbox problem?
Vaccum lines....
Ecu Reset Question
fixed some stuff...
soild red light
Spot the EF!!
Cheap Swap :( - need of some info
GSR Motor
water gauge
ZC Idle speed (HELP)
H22 in a CRX
zc headaces !!!!!! ecu problems
Omni suspension?
dpfi to mpfi
Auto to manual tranny swap
tein suspensions
Axle back exhaust question
No power to 3K then fine????
valve durations?
88dx to 89 teg"zc"
EACV gone bad?
marble sound + speed sensor?
Stock Parts!!
Distributor Help
distributor
Sir Cluster
hey all i know this is off but i can't make up my mind please help
ZC Tranny
front mugen kit bumper lights
big tach wiring problems
oil dipstick and battery hold down
d16y8 or d16y7 in civic hatcback 89??
some one help ME!!!!!!!!!!!!!!!!!!!!!!! mini-me swap issue!! engine not firing
CRX seats, all the same bolt pattern?
k20 hatch vs. 22psi evo8
88 Civic LX Sedan 1.5 no spark
b16 tach installation prob
b16 Throttle body and alternator questions
any of you guys see this yet..mugen kit...
b16a idle fluxuation
door locks
need help with turn signals and wipers
fuel pressure regulator
Front and rear mud guards.
directions not included lol
Axles colors, is it yellow, red, blue, etc?
zc blue smoke
zc oil pan
ecu throwing a code
need help with mfi swap
Web
AF
