View Full Version : '88 - '91 Civic / CRX
  1. $650 for engine swap!
  2. ZC distributor
  3. b16 check engine codes help
  4. mabey its my 02 sensor?
  5. Stumble on accleration - 95 civic vtec
  6. b16a2 into 89 crx
  7. Wiring in LED lights, etc (need help)
  8. One of my "crazy" projects...
  9. dumb question but need to know obd question
  10. East Coast Meet Ny, Nj, Conn, Penn,
  11. ck out this site, i know this guy from st.pete fl. he realy know what he is doing.
  12. Port and polish a1 head or b1 head?
  13. I'm such a good friend! lol
  14. Tail light...look at pic really cool
  15. some pictas of the CRX.
  16. ecu pr4
  17. brand new 89 crx
  18. Tranny Problems
  19. damn std ball joint!
  20. a/c problem
  21. To die or not to die, I'm clueless?
  22. Replacing headlamps
  23. Re-occuring Problem got worse!!
  24. does hf crx's have MPFI?
  25. havent been here for a while... new pics of the ol' civic
  26. 88 civic dx suspension ?s
  27. Best D-Series Engine For Me?
  28. anyone have this die
  29. Dx to Si
  30. 91 CRX HF Brake pad problem... Help!
  31. Wont pass!!
  32. just wounderin'
  33. my luck sucks...
  34. LS tranny mileage
  35. HELP!! Idle is too high!!
  36. rear disc convertion help
  37. dx vs. si
  38. anybody have any engine pics?
  39. ammeter gauge help
  40. The old days.
  41. overhaul
  42. K20A swap?
  43. What front bumper is this???
  44. dx with mpfi vs. sohc zc
  45. Rear Bumper removel
  46. oil is everywhere =/
  47. Need help Engine swap 91 HF
  48. Rear Speakers?
  49. gutting a hatch out
  50. ecu question
  51. Transmission fitment Q's?
  52. 2005 (west coast) civic meets <your input here>
  53. HELP! Spark Plug wire not fitting in!?
  54. My New Wheels
  55. Will any 88-91 crx door fit....?
  56. O2 sensor problem?
  57. simple question!
  58. Kickdown cable adjustment (automatic)
  59. 87 Auto tranny in 4th gen???
  60. Bumper Progress(56k go make some food)
  61. What year is my car?
  62. Struts for 88 CRX SI
  63. Automatic B16
  64. Custom made CF Intake
  65. Drag Generation III
  66. Wind making my lights brighter?! I'm very confused...
  67. Bumper Fitment
  68. The First Snowfall for this Canadian **PICS**
  69. Where to install a block heater
  70. Interchangeable parts
  71. engine life?
  72. heater not heating
  73. 89 crx si fender question
  74. Which header would you choose?
  75. Need Info On Thermostat Lots Of Probs
  76. Need help on rear speaker installation
  77. Whose impressed with thier DPFI 4spd?
  78. 1989 Civic STD Seat Issues?
  79. Can an auto ecu be used in a manual?
  80. Battery draining
  81. b18 swap
  82. D16zc
  83. CRX Roll Cage
  84. elctrical is utter crap right now
  85. Pics of my 2 CRX's
  86. how much gas mileage?
  87. Posting pics
  88. Radio Question
  89. old 4thGen-er
  90. Getting a Honda CRX, needing some info...
  91. engine swap
  92. fitting my midwing
  93. FORUM RULES AND GUIDELINES - MUST READ!!!
  94. turbo b16?
  95. A question for automatic owners......
  96. Swap Shops?
  97. zc engine
  98. time belt Question
  99. Need advice on buying projector headlamps
  100. Cursed Junkyard Parts?
  101. sun visor
  102. mini me compression
  103. help with my car
  104. 5 speed transplant into BASE civic?
  105. about a fuil pump i have
  106. gas tank
  107. CRX gone weak, very weak
  108. Which color?
  109. crx si tranny in civic ex
  110. which clutch for zc bolted to dx tranny?
  111. sticky throttle
  112. 89 civic
  113. mpfi manifold question
  114. damn car
  115. I need a what?
  116. Rebuilt B16a overheating, any ideas?
  117. JDM Site
  118. Check out these beauties!
  119. 91 CRX B15 to B18 swap.
  120. Deal I Found
  121. Need some help on tires!!
  122. First g-Tech Run!!!
  123. help
  124. lost 1 civic
  125. The ol' seat question again!!
  126. what about a roll cage
  127. What fuel pressure should I run?
  128. Curb Check @ 30mph
  129. K20 on a crx??????
  130. Would I need to do a MPFI conversion?
  131. Integra front end conversion?????
  132. Crank angle sensor?
  133. engine problems need advice.
  134. 50/50 weight distribution.
  135. help with radiatior fan
  136. Car won't start. Code 10
  137. Oil on the spark plugs
  138. Seat brackets for 88 CRX
  139. totally DEAD
  140. Pics of my friends h22 crx and a few other local cars
  141. my swapped hatch
  142. yeah I'm still alive..and I have a question!
  143. 88 4d just died no spark
  144. How long will you love your 4th gen?
  145. Cool Triangular B-Pillar Set up.
  146. MPFI conversion W/auto trans
  147. annoying intake
  148. engine swap d15 to b18
  149. High Heat Headlamps
  150. Interior painting question?
  151. honda convertion problems
  152. where to buy tranny?
  153. Lets talk about Wagons.......
  154. Found a genius way on hooking up fog lights!!!
  155. No Spark (HELP ME)!!!!!!!!!!!!!
  156. websites?
  157. Carbon Fiber Cargo Cover Pics
  158. Woot!
  159. Automatic civic tranny
  160. Need a new motor
  161. I need PICS...
  162. Rofl look at this...
  163. Timing belt flopped, new engine?
  164. Am i seeing things or is this a projector?
  165. Rev Limiter Problems!! Please Help!!!!!!
  166. New car...need opinions
  167. d16a6 pg7
  168. Steering wheel Ques-t-ions?
  169. Pictures of my 91 cx finally
  170. Need help dealing with interior condensation!! ASAP!!
  171. Pillars
  172. Resistor BOX HELP
  173. D16 Or B16
  174. Cool Suspension website for CRX
  175. found a good place
  176. ???
  177. Integra Front Hubs on CRX?
  178. can't find the site.........
  179. wont pass smog knox is to high
  180. Wrecked 4G
  181. vss location
  182. Rep. Check: 4G 4D Store
  183. d16a1 valves in zc head
  184. I've Fallen and I Cant get up!!!!!!!
  185. hatchback users. underglow questions
  186. Rear and Side skirts
  187. when they say HONDA D16 VALVE SPRING
  188. Ugh, that doesn't sound right
  189. Performance Cams...
  190. 88 CRX Seat Bracket
  191. Dies at a stop.....
  192. Hi
  193. Is this a good deal and/or worth it?
  194. Hf-->Dx...probs
  195. 91 civic not starting - need suggestions for next steps t-shooting
  196. Headlamp/bolt sizes
  197. thermostat
  198. Tell me this?
  199. New Wheels: Question
  200. how much nitrous will a mini me handle
  201. Crx VS. Lancer OZ
  202. Merry Christmas to ME!!!
  203. Hmm....Decisions, Decisions, Decisions.
  204. set adapter
  205. will these rims fit on a 90 crx
  206. My car and the title for it...
  207. Power steering squeeling
  208. gsr swap
  209. b16 head question
  210. Ground Wire Kit Question
  211. clutch went out?
  212. Would a 92-95 hatchback cargo cover work?
  213. leaking coolant out my header
  214. need help making up my mind
  215. Lost my coolant twice in a week
  216. Your opinions please
  217. nitrous jets
  218. need to know what plug this is
  219. Engine Swap - Keeping it CA Smog Legal
  220. crx si b16a swap
  221. zc piston question
  222. Blown front right strut or something else?
  223. d15b dual vtec?
  224. plan b
  225. I wonder what else can go wrong
  226. 88 CRX sunroof question
  227. RSX Guage Cluster?
  228. how much nitrous can I put on muy stock d16 sohc
  229. b16 boggs when floored
  230. the wire broke off! My life sucks!
  231. Help need parts info for ZC
  232. Friend Chipping a PR4 for me... questions
  233. got into an (not too bad)...need some advice...
  234. i have go need whoa
  235. 4G4D Auto-tranny, weird problem, please read!
  236. about mini me
  237. Will an '88 CRX Si Engine fit in my '88 DX?
  238. b18c(r) swap
  239. LS ecu
  240. apexi..
  241. HMOTORSONLINE.com SWAP B16A 56K maybe ok!
  242. couple questions
  243. D15B1 to A1
  244. smoked tail lights
  245. Hey everyone wanted to say thankyou for all your help
  246. Accord MPFI fit 4th gen?
  247. what the heck is this
  248. Differential swap?
  249. manual to power windows
  250. Ls axle Question
