Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '88 - '91 Civic / CRX |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
b18 help
Motor Mount Inserts
R34 bodykit
crash test rating
modest bodykit
Close Call
oxygen sensor
suspension help
B16a1 difficulty
fuel pump
Battery Placement mod..
Vibration during acceleration
Sound Systems
got a great idea....
Check Engine Light?????
Almost Lost Me Tonight
NEED HELP getting off Transmission Oil Fill Plug!
throttle angle sensor
91 Civic Si Price Help
88 hatch swap Q's
dpfi running rough
Check Out My Ef
Insite= the new crx with conversion!
I was wondering if............
pcv valve/hose clogged
CRX Heater Control Removal?
5th gear problem
good deal?
Aluminum Flywheel Questions
Test Drive
wiring harness for d15
stock hydro clutch
electric load detection relay
Apexi exhaust systems
battery dischrage
88-91 OEM spring rates?
Anyone got an H22a rex???
rotor size
quick question
Should I adjust valves cold or hot?
are you satisfied with your d15b vtec?
whinning noise, honda civic 91
tire sizes
ZC Oil Pan drain bolt
Civic 1991 starting problem, please look
16 volt chargeing
low compression
installing new fuel pump??
civic keeps blowing main fuse on fuse box under the hood when connecting to the batte
wheres my oil going???
b18a vs zc
NO power at all 91 Honda Civic, please any help appreciated
89 integra intake fit a d15 with mods
Hood release cable shot?
questions about crx
Tranny Slips Sometimes!!!
NW civic forums
Speedo? Engine Light?
Car keeps dying on me..help!!
o2 sensor ?
turbo VS supercharger
Spring Knowledge Needed...PLEASE!
my rims
Any Pictures Of 89-91 Civic 4 Doors?
CRX Engine
black smoke
new digi cam = new pics! (56k is okay!)
b16 smog
i'm drunk...sorry to bother
type r steering wheel in 4g4d
more problems
wrecked my car today so no more fourth gen
WTF??? someone explain this to me!
Stating issues
Comp testing
Question about 88-91 crx's and civic hatches
valve cover vent tube Blowing?!? and a code 20
Integra Harness VS civic harness?
aftermarket muffler hanging too low
People Who Have Custom "racing" Seat Brackets!! Help
Anybody have experience with Mitsubishi Starion turbos?
fiberglass work
whinning noise drivers side of engine?
need help with the codes
FREE - Civic for parts
Test ECU,good/bad
alternator help
If I wanted to install my - B18 from my teg, into my civic....
if money weren't an issue which engine..
$250 idk what to do
ZC tranny VS. SI tranny
headers
my car just won't start...
help with my 84 crx looked else where
if money wasnt an option
how can i make a car faster but without any engine mods?????
Will 90-91 front bumper fit on 88 rex?
b18b
infineon raceway
street racing movies
I am back!!!! with questions...
photoshop ques.
Swapped out cluster Now getting Code 17 VSS?
long, but I need help
d16z6 or d16y8?
1/4 times
zc vs. D 15 All Help Needed
car wont start possible wiring problem
Custom License Plate Holder's
b16 crx map question
integra conversion question
Now I'm amazed how well she went through the snow!
pick one
88-89 hatch front bumper fit on a 90-91?
a few q's on custom exhaust set up (not the usual exhaust thread)
heater problem
redline on a zc?
d15 turbo 1
Need Help Asap
cool crx wallpaper
Help me build my suspension.
how do you install hood pins?
little carbon fiber mirrors on 4g civics
zc head bolt torque specs
Diagnosis help
1994 Prelude looking for an h22a
B16a Swap into a DX civic hatch
Anyone thought about doing an Odyssey Engine swap?
Idle issue.
Saw a CRX HF last night!
what would you do
H22 motor mounts
speedometer cable
spark plug heat wrap
websites on the links page not working??
d15b1 question
d15 b2
Photos : New Wheels
Alternator help please
what rear sway bar on dx
Losing breath in upper rpms
i have a dream
say good-bye
Might be leaving honda land folks
Question for the honda gods
To body kit or not to body kit that is the question?
D16z6 4 wire O2 sensor
88 Civic DX won't start
help! no heat,
Do i need a new battery with a swap
ECU codes??? 1 flash??
Retard timing for NO2?
valves???
zc cams in d16a1 head
88-89 Dual Halo Projectors on a 91?
headlights??
Suidice doors?
AEM fuelrails??
engine reving up by it's self
cold startup
d16z6 idles at 2k rpms
#*(Post Your Videos/Pictures)*#
No Spark
weather strip
d seris ?
**(Post Pictures Of Ur Ride)**
heater blower and power
connecting rod caps
Custom tail lights and a idling issue. Thanks!
Over Heatting
Will CRX Side Skirts Fit A 89 Civic Hatch??
Mmm Just Got Wheels :) :)
How do I install a new fuel filter??
pvc valve
tweed or painted interior
Where is the IAT sensor located?
instrument cluster
NEED HELP ASAP Car stalling
ECU & Wiring question
how do i check the codes
SiR Glass Roof
post pics of ur crx's
New rims and tires PICS
90-93 integra front suspension on 4th gen hatch
exhaust question
hood and radiator
d15b? ecu
dropping axle and repalcing alternator. HELP!!
CRX Carbon Fiber Body Kit
need a little help with lights
what does ex, dx, etc. mean?
crx gauges
in dash dvd
NEW here
Passive rear steering
Has anyone tried putting crv seats in a hatch?
check engine light??
Difference between B18B and B18C1 Heads & Intake Man
alternator overcharging the system
teh new guy
4G4D Carbon Fiber Trunk Lid
si guages
What do u guys think??
Gauge Cluster Bulb Size(s)???
onething after another..am i screwed or what
Horrible Gas Mileage
hf/dx/si interior all same?
most fuel effiecent crx
What motors came in Civic Type R's
speedometer pick up
opinions
this ecu work for what i'm doing?
ecu question
Need some help on a roll cage.
Engine Swap Question.
my rev limit is 3500
Yes/no?
Motor Reving Problems
New pics of the gay carrr
help me please
How Do I Adjust My Air-fuel Ratio??
THERMOSTAT question
What could cause this
hatch rear seat removal.
buying motor parts
Help, idle adjusting screw
Bodywork
CRX Frame for sale
Quarter Mile vs Wheel Size
motor mounts
Reasonable Terms (long...)
anyone in london? just wondering
distributor
when my foot is to the floor problems
Center console
Thinking About Purchasing a CRX
loud screeching noise like belt, dont know though
What cam would you choose?
Hopefully trading my hatch for a crx!!!
What happened to IheartMyHonda's thread?
sparking order
Dizzy Q?
Passing Emissions with a 2nd gen b16
Oil leak help
Tachometer, Fuel gauge, clock out
Help!...Overheating!?!
alternator can cause.....?
I think I blew a cylinder...
exhaust help
Damn People - Gotta replace window now!!
Web
AF
