Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '88 - '91 Civic / CRX |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
91 civic Timing
Axle Help - axle to intermediate shaft disconnect
94 Integra Seats in EF???
Will a 5th civic coupe center console fit??
CRX dies after starting, and it stinks like gas :-(
no power to starter
what is this and why is it like this?
any axles from other years/cars that will fit?
91 Civic LX Sedan - window/lock problems
Fuel cut
Crx Zc Injector problems
I thought about this a long time ago... but never went ahead with it.
Fouled spark plugs?
starter help.
FIRE makes it way out of my intake manifold!!!
Honda/Acura Mini Meet in PA @ Sonic
zc into 91 civic dx
Sloppy Shifters...
Anyone put a 96-00 center console in their 4th gen?
zc head for sale
Exploring subwoofer mounting locations (opinions)
Carburettor Qs
Removing rear wiper arm
Upper coolant hose adaptor question
Auto Transmission fluid Qs, please help!
car giving me problems
hesitation in first three gears
~~> my project thread <~~
88-91 or 90-91 tail lights
Well....
Pics of the new project *56K warning... go take a shower and shave or something...*
freshly rebuilt goodness
Hood Latch Came Off! Help!!!!!!!!
I said I'd do something about it...
wiring problems help
ZC Swap Questions. Help!
zc injector swap issue
B18 Swap issue - really weird
cluster with tach work in non-tach car?
I would like to lift my CRX
Need help on A/C evaporator?
What should I do?
Best lowering springs?
To the Drawing board
okay so this 91 civ is pissing me off
How much louder will this cat-back be?
New to hondas and this forum
Fast Idle Thermo Valve
My new B18A1
No Bumper Covers...Legal to put license plate in rear window?
Which seats will fit?
sorry for asking but
1.6 to 2.3 upgrade
o2 sensor
U call URSelf a CRX Enthusiast
Anybody Tried Pulstar Plugs?
painted the wheels
Alternator
23 vs. 26 spline cv axles
replacing my tranny
How i spend my day off..
My new hatch
91 honda civic won't start
91 civic swap with zc??
changed a head gasket car wont start. need your help
Intercooler
quick and stupid question
please help....temp. gauge
Passed Emmisions!
89 civic 1.5 threw the timing belt
dash lights/parking lights
hacked suspension question
JDM CRX Manual???
4.25.08 - 4th Gen Civic Meet
Identifying B-Series Transmission
ECU light won't stop blinking
Please help with my civic
so i just bought a 91 honda civic and...
Who says you need a truck to tow a car?
Help! Super Extreme High Idle!5000rpms!!
resonator
high beams won't work
My yearly visit :)
buy from junkyard OR buy from jdm shop?
'89 Honda CRX Exhaust Question????????
over heating, well almost
lowering the civic just a tad
sputtering question
Buying used engine from Craig's List?
any EF meets in New York area?
Moisture - front passenger area
a/c problem
Main relay issues.
pics of the new daily
price'n parts
simple question
speed sensor
fronts brakes followed by other fun issues
tranny swap help asap
Help
Code 20 Code 7 How Do I Fix It? Please
MPFI Swap...Yes I know it's been covered...
Hydro disc in cable tranny.
Driver Side Vent blowing Outside Air
91 DX to b16 88 si style seat belts
buying car choice between 2, which is more modified
1991 honda crx k swap questions
A/C blowing hot air (91,civic-LX,1.5L)
emission test result bs??
Need help or any suggest for civic 91
ebrake handle
1991 crx need opinions
distirbutor connection
Got some Money.....
tenrai exhaust and Iowa Winter
Looking for a vacuum diagram for the 97 JDM ITR motor??
Injector resistor box
91 CRX bumpy ride, need some info
Holy wheel gap Batman!
No Spark, No Start, Help Please
Finally Got My Wing On!
Cabed civic mods
lower control arms crx
How To Bolt On Chargespeed Wing?
Fuel line repair
Steering is tight
Which intake manifold fits?
Peanut Butter...
swaping seats
D15B1 block D16Y7 head swap ?
I'm Back
88 Civic stalling problem
New EF civic!!!
Best way to remove interior side panels?
New Header for swap?
B18A1 Power Steering Question
Opinions on OEM vs aftermarket timing belts
I Need Help Fast !!!!
replacing my D15-- budget swap for daily driver
Error code 20 for my 1989 honda civic
Whats it worth
Buying the MPFI kit
Crx Dx: A Couple Questions
CV Axle - Replace or Re-Boot
To swap or not (Tranny that is)
Service manuals, Parts lists, Carfax
mpg help
89 Prelude seats in 89 Civic HB?
f20c1 swap
16" steelies for s 89 hatch?
Got my new DX..Im in FE mode!!
obd0 to obd1 swap trouble
Lightest Gutted Hondas.
Civic Cold Start issue
Whats Wrong?????
need help with crx
D15B7 head on a D15B2 will it work?
anyone in the New Jersey area
fuel rail and injectors
CRX Carpet
Seatbelt Squeal
Goodbye to the Honda world!
Seat question quick?
head ?????
Which distributor and where to get it
Hello Again
tps sensor question
tires
Ignition Key - Won't Come out - More info- Help needed.
Engine Swap
Identify a Rim model
DAYUM there are so many deals here..
Just purchased 91 CRX DX need some advice!!
crx si 91
91 Civic Hatchback...Distributor
Installing ignition lock cylinder
obd1 question
Emergency Lights
Fender Bender
New to Crx
Car Wont Start!!!
Civic std rear wiper.
91 Civic Hatchback...Turns over..Wont start.
Body repair
solenoid valve where?
Ignition Key won't come out sometimes
Konig wheels
specs
anyone kno how to replace a fuel pump
Rear Hard Brake Lines - Size?
Cylinder head welding
Connecting rods
HF dash
just want to say thanks
91 Civic Hatchback
jdm rear crx seats
stock intake ?
O2 sensor and ECU
broken cam
civic prop valve vs si one.
y8 throttle body
Are there any unmod'd 91 Civics left out there?
cam specs
dpfi to mpfi swap questions
need help..
running rough
91 SI won't idle when warm
heater quit working..
Coilovers
Compression
Where to buy a throttle body
surging engine
89 crx brake help.
90 Civic LX Rear Seat Bottom Removal
Switch to PR4 or stick w/ PM6?
Ok, so I decided against rear discs for now
CRX front bumper on a Civic?
problem!!!
dash question
pcv ?
rough stops
Spoilers
D16A1 Into a 91 Si Hatchback - Need Help!!
Si Tranny
No ReVerSE!~!
Civic Dieing
crx engine..help new
Fix it or not?
Help 90 Honda Civic Overheating
What would cause my car not to start when it's raining?? Is it electrical? or other?
Brake booster replacement 88 1500 DX 4 dr
RIP my 1.6i-VT
Interior questions
Tranny Leak HELP!!!!
Speedometer is boggling my mind.
Pics, as promised, and if you're on dial-up, get your coffee while this loads..
so yeah...
alternator plug conversion?
Normal Oil Pressure Levels
Would code 7 cause this?
So I guess home depot sells lips :) 56k not a chance.
cam specs
90 civic with zc HELP FAST
Upgraded myself to baller status in the shop....
two questions...need help
Confirmed New Crx
Ignition Switch? Heat?
Parts sites
D series R'active header..
Web
AF
