View Full Version : '88 - '91 Civic / CRX
  1. Coilovers & Shocks/Struts
  2. Jdm 4G cluster
  3. b16a1 idle and fuel problem New Swap
  4. Ok Here Is More (pics) Of My Civic. Tell Me What You Think.
  5. full carbon hood question
  6. 91 CRX low idle
  7. track length on eg/ef?
  8. Straight-thru perforated Resonator or one with baffles?
  9. Clutch letting out 2 high
  10. 14" Black Enkei's on CRX?
  11. Pictures with my messed up timing.
  12. Where's the ECU?
  13. what kind of tape or adhesive?
  14. gearbox/clutch troubles?
  15. Need your opinion...
  16. gofastperformance.com?
  17. code 6 on pwo b16a1
  18. question about vtec...
  19. need info got new motor but now the same i dont think whats a d15b
  20. is this good for anything
  21. it cant possibly be good on your engine to do a burnout this big (vid)
  22. B & D series Compression Calculator
  23. rough startup and oil
  24. arg..WTF!!! I need help....N O W
  25. hatch or sedan...?
  26. Little Gray Box
  27. Crx Temp Control Can It Be Replaced By Civic ?
  28. Does the PM5 have a rev limiter?
  29. Ef,eg,ek
  30. Prepping fenders and bumper for paint a few ???s
  31. Jdm D15
  32. ebay crx perfomance chips??
  33. Zc Header
  34. im just wondering
  35. Video of the new car for 2005.
  36. d17 2001-04 civic motor
  37. Time line of my car(Lots of pics)
  38. Spring Cleaning (Pics)
  39. hi
  40. what Color To Paint My Civic?
  41. Inside top cover of DPFI?
  42. i need specs
  43. ok here is my civic well kinda
  44. Nooblet ?
  45. Squeeking from drivers side suspension HELP!!
  46. CF Clutch
  47. si tranny swap help
  48. msd 5
  49. AEM cold air intake
  50. please SHUT UP!
  51. PLEASE HELP honda civic hatchback info
  52. RPM dies, engine light on
  53. B20 swap into civic
  54. HELP, does anybody know caliper bolt size?
  55. Control Arm problems
  56. HELP: What car do i chose, CRX or Civic ?
  57. Pin-out schematics
  58. Aftermarket VS JunkYard Trash
  59. Blow Off Valve...
  60. Oil around spark plug. Blown head gasket?
  61. 18 inch rims on a crx?
  62. Misfires intermittently under 2500rpm 89 LX 4Dr
  63. WOW sum1 needs to get laid
  64. Automatic filter replacement?
  65. Power folding mirrors..wiring?
  66. This is for the Turbo guys/gal whats your MPG
  67. Whats the dif in 88-89 and 90-91 crx head light's
  68. Breather filter
  69. recommened sites for how to's ect.
  70. crx short shifter..yes or no?
  71. HELP..cant afford the bodywork!!!
  72. I dont brag bragging is for bitches out to impress ppl thats not me!
  73. mpfi swap
  74. HELP!!!! Studs broke off.
  75. white tail lights
  76. 90' Civic: Wipers, windows and wiper fluid motor went dead HELP!!!
  77. Bulb help
  78. 1988 Civic LX with automatic - questions
  79. jdm power window kit?
  80. 26mpg...New D15B2
  81. CRXSi stock eng...biggest hp gains 4 price
  82. 17" Enkei's on CRXSi? yes or no
  83. tips needed to mod 1st car(CRX)
  84. i got to put a new motor in but can it be dun check this one
  85. MPFI swap on 4-Spd STD Hatch
  86. ok guyz im stump an lost on my swap
  87. How safe are CAI's ur opinion.
  88. Any nice spoilers out there?
  89. rev limit
  90. Does anyone know?
  91. Brake light keep's coming on during.....
  92. b16 swap vtec question
  93. b16 swap vtec question
  94. people with zc's look or if you know alot
  95. too frustrated to go on..
  96. Waxoyl
  97. Honda Civic Si Engine Number
  98. Is an LX wire harness the same as a DX
  99. dual-point guys = 91 4dr lx b16a swap
  100. Clicking into gear
  101. Rear wheel noise problem?
  102. Couple of Questions
  103. Interior Lights Don't Work
  104. Intrested in learning about bodywork
  105. do you know where to find this?
  106. Brakepad Compatibility?
  107. Civic type r pistons
  108. Working on car right now, quick question
  109. funny crx clip
  110. zc engine swap trouble
  111. ECU Chips
  112. swap question
  113. Horsepower/ torque help
  114. whats your take
  115. fianlly got pics up and need help
  116. CRX Tragedy This sucks!!
  117. '90 Civic stalling when stopping
  118. b16a or ls vtec
  119. seat compatibility
  120. BODY work started and a Poll
  121. help !!1 91 crx vtec wont start
  122. Gimme your thoguths on this please
  123. head games
  124. How to tighten Automatic Seat Belts
  125. K20 rex with a ... check it
  126. need help with dumb question
  127. 1990 Civic Hatch (Should I Buy?)
  128. Vafc question
  129. Aftermarket Air Intake
  130. exhaust fitment on a b18c
  131. CV Joints
  132. Motor Swap or keep the same
  133. code after mpfi convetion....
  134. 88 Honda Civic - Alternator OK?
  135. On a 88 crx si, pass.side spindle bearing instal ?s!!!
  136. Which fuel pump to use?
  137. 60 a fuse bust...I dont understand?
  138. New crossmember?
  139. ZC Dizzy
  140. would you buy
  141. is this a waste of time
  142. Some of my new toys and my old clutch Pics Inside
  143. New GTECH results
  144. gas Meter not working properly
  145. My speedometer wont work ?
  146. Std Mpfi
  147. question about ls/vtec
  148. D15b sohc vtec jdm swap
  149. just noticed a driving nois
  150. JDM d15B vtec in Cali?
  151. radiator
  152. Hey, Can I Use This? Please Hlep!
  153. i need wiring help 4 gauge cluster...
  154. changing SOHC ZC into DOHC
  155. cold start problems
  156. might be scrapping my ride
  157. crx 90 radio wiring diagram
  158. another engine poll
  159. weird
  160. 88 Si head bolts
  161. Alternator keeps going out
  162. Integra for 750$.
  163. need a wiring diagram
  164. crx tail lights
  165. help with changing an 89 civic over
  166. Wireing help
  167. check this 12sec a6 Rex on ebay
  168. new to this part of the forums
  169. hard starts
  170. Updated pics of my ride
  171. Finally!!!!
  172. CARB legal swaps?
  173. Odd squeek
  174. wiring question vtec in my 91 hatch
  175. all 4dr 4th gen swaps help?
  176. Individual Throttle bodies
  177. Latest mod pics :)
  178. crx KIA
  179. Dohc Zc
  180. slicks
  181. b18 swap question???
  182. battery light blinking
  183. b18c1 swap
  184. wont go into gear while running but...
  185. Yep...overheating again!
  186. zc torque specifacations
  187. Stalling - Help Please
  188. Rear seat question (Si owners LOOK!)
  189. Will A Civic Hb Front Bumper Work On A Crx
  190. Lowering an 89 Civic.
  191. '90 CRX Si-any good?
  192. motor swap
  193. what do i need
  194. how quick would this setup be or quess
  195. most complicated problem ever
  196. Alternator dying ???
  197. ecu code 4
  198. B18 Valve Cover Question
  199. map sensor
  200. Tranny disasembly and bearing replacement - pics inside of the progress
  201. pg7 question
  202. Dose any one know where i can buy a CARBON FIBER FRONT BUMPER
  203. Dying battery/alternator/both ????
  204. D16z6 fly wheel question?
  205. distributor??????
  206. rotors and pads
  207. Transmission List???
  208. "WHERE" can I find a replacement motor
  209. zc engine swap
  210. Popping locks
  211. First Post! And Im drunk fantasizing about hondas!
  212. websites
  213. ECU Code?
  214. Smell that exaust?
  215. E-Brake Wont Hold HELP!
  216. really need help????
  217. Seats
  218. zcswap
  219. Tsudo header and muffler. are they any good?
  220. ecu wiring
  221. Battery Terminal
  222. zc engine swap wiring
  223. zc engine swap wiring
  224. 91 honda civic starting stalling problem
  225. EG LCA on EF need help!!
  226. d15 questions...
  227. Unique setups
  228. will this fit?
  229. Sway bar mounting
  230. almost here!!!
  231. Starter Questions
  232. specs for sohc zc
  233. Timming Belt
  234. Exaust questions
  235. Help with changing ignitor
  236. 91 Civic Wiring question
  237. fenders not lining up
  238. Front lower Xmembers
  239. Crx throws code 9
  240. help with mini me
  241. Big Brake Kit?
  242. Question/discussion/NOT A ARGUMENT!!
  243. 89 dx seat mount
  244. will this bolt up
  245. Havent done my swap yet one more wireing question
  246. 91 si gauges dash
  247. will ZC tranny bolt on D16A6 with no modifications?
  248. motor poll
  249. rear defrost switch, 89 in a 91?
  250. insight
