Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '88 - '91 Civic / CRX |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
i have my spark now but.....
good bye 89 Si, hello new ride (pics)
Which bolts do i tighten to get rid of that niose in my valves?
ecu's
600-700 rpms
Got no spark
Code 43 Please Help!
Anyone Remove Crx Si Headrest ?
Back from the dead...
Vids from autocross this past weekend @ Englishtown, NJ
Code 12 Please help!!!!!!
JDM front bumper....
Lips
91 CRX egine problems
bigger is better
HF to Si..1991
Engine Arrived today, Pics! 56k no no
hOW TO PUT ON SIDE SKIRTS?
91 civic with D14A Swap with ?
Help w/ odb jumper harness wireing. just 2 wires left
New Pictures of my vehicle
where can you find piston rings?
Is this safe to do?
In need of Timing belt
rubbing fender well?
weak acceleration
If i wasnt moving out
Swap pics so far
Redline.... and shift point
Vistited the upick today, have a couple questions
O2 Sensor wiring help please
how hard is this to do for honda people?
UK civic meet
Lowering Questions.
ZC swap gone wrong
water filling up tail lights
How do you take off the fender?
Help!! b16a axles people telling me different things!!
1990 Honda Civic Si Multi Port Fuel Injected Intake Manifold.
DOHC ZC Rods
Can it fit?
just snapped some pics of my rex
Failed
head gasket
Emissions legal engine swaps?
engine shutting off
Tire size converter
What engine is the logical build up?
installing a high flow cat
new crx im a nissan guy so I need some help
wheel hop
wiring in jdm headlights????
Step by Step Instructions
94 b18 LS into 89 CIVIC DX????
Pics of the crx with the swap done.
Calipers...
crx thread
CRX HF Swap
Wow this -was- a nice car....
RSR catback
glowing red hot catalyic converter
whats the difference
worn out muffler - replace with ...?
Some new things on CTK
Wrap it up in Foil!
sold my crx-pixs
RSX Conversion on CRX
it died.....anyone know if its fixable
roadrace question
engine ID?
wierd problem with 89 h/b
89 Civic Manual Tran Question
pic of my car
rims
Wrecked car issues.
Metal to Metal sound when turning?
Engine Heat Shields?
injectors not opening
port matching a6 intake manifold (?)
front alignment
Problem
88 civic lx - does it have fitv?
Rear suspension help
This damn crank pulley
Battery drains overnight
halfshaft trouble
Camber Kits
Cai
Stupid freaking battery
HELP!! SWAPING A B18 LS into Civic DX
91 civic wont start....PLEASE HELP!!!
GSR in a Civic?
tokico hp vs. kyb gr2
hello my buddy got a civic with a b21a1 he wants to know some things
anyone ever changed a timing belt?
I Have An Invader Front Bumper
Two questions:
89 Civic stopped starting
dohc d16zc
CRX REAR Lights leaking
My own E mission Statement
200hp zc?
I can't decide what I want...
catalyst efficiency low
Paint Job
Gear Fluid Pours Out!!!!!
intercooler mounting question...
Purchasing a b16a w/o paperwork. Dangerous???
Civic 1.6-16i engine kick trouble
transmissions
Brake Fluid.... How much do I need?
V-tec question
civic hatch or crx rain guards
p28 ecu an obd0 obd1 isn't worth the money got smoke by someone check this out
look at the new crx's i think there ugly what do u all think?
Air fuel help, install
Is this CRX worth the current price.
12 sec civic from hawaii
Re: 91 Honda Civic Starting/Stalling problem
drivers side connector b16 swap
Help Noise From Front End
Major HP Loss... what in the &^&#*
D15B1 to d16z6 swap ?'s about mpfi
swap in process
crx seatbelts
just got a crx
swapping doors?
Installation of Energy Suspension on a 91 HB
swap prices
Need Help Sourcing Rims for Widebody CRX
leaking oil
will CRX taillights fit on a CIVIC HB?
can't find any thing help
Rim ?
gsr bottom build
need o2 wiring help
Feedback on your Tokico Illumina shocks?
RPM Question
will dx harness plugs go into pm6 ecu
mfi questions im stumped!
Need Some Help
been think of a b series swap
Act Flywheel
d15b all motor setup.
SWAP Complete
Wires Wires everywhere
turbo question?....
Air is not blowing
Oil - What do you use?
Woo new toys on the way!
1991 Crx No Tittel
stupid clutch?
engine graggleing
what is the best front end conversion for a 91 si?
clock, dome light problems
wont start
warm starting problems
What do i need 2 buy so a b18b will fit in my 91hb
curious for best prices on the net
help me out im new (b16)
hey found some old pics of car
Problem with guage cluster...need help
not firing on one cylinder
rain shots of the ef [pics]
Bad Ass Crx (pics)
broken exhaust manifold stud from d16a6
Car does not start!!!!!!!!
oil in spark plugs, o-ring ?- need some help on my 91 civix dx
My new 88 CRX SI
Tein Coilover Install Pics - Small pics
Need some wiring help on d15 vtec
Brakes broke...
Quiet Exhaust Please!!!!!!!!!!!!!!!!!!!!!
No Heat No AC and No Radio?
Good deal or not on whole interior?
Tein Coilovers
88-91 dual-point Conversion BREAKTHROUGH
what brands
Energy Suspension bushing installation
Turbo JDM B18C?
Climate Control
Question about zc swap ecu
primary ignition
Funky Brakes
Shopping spreeee!
Cams thats it.
o2 sensor question
Is there a way to find the answer?
Ball joint procedure Civic 91 4Dr
USDM Right Hand Drive Conversion ????
B16 intermediate shaft?
how do i wire in 2 more speakers to make it 6
XTD flywheels... good/bad?
fuel pressure tester adapter for civic
updated pics of my 91 hatch 56K warning!!
Pics of the new ride - large pics warning
90 Civic Starts fine, Stalls in under 5 Seconds
1988 Ball joint replacement covers?
Reverse switch, tranny oil
tranny problem
Help Please!!
good mfi swap site for retards?
which should i hook vtec up 2?
Civtegra Front end conversion... phase 2 pics!
n00b to hondas, have questions
Crx progress pictures
front rotor size question
Help with smoke!!!!! Did compression test.
How much weight can I load in my CRX
89 Civic SI new paint (56k beware)
Vtec-e...
Pics of the engine pull
I'm a n00b, and am in need of some help!
What you think of my new rims
fuel injector question cont'
i need help
Removing Engine Without Tranny?
speaker fitting question
just finished doing a headgasket... now code9
Flywheel bolts?
i was wanting info on my motor can every tell me sites
help need more fuel?
Cleaning
body kits
Nitrous Question....
can i toggle switch vtec to see if it works?
axle splines?
sunroof drain holes?
88 honda civic
My buddys car painted mines this weekend pics of his (56k warning)
Sold my Rex today, pics right before she left
what do i need for my swap
91 Civic - Distributor Rotor Meltdown?
High RPM
Anyone use AMSoil?
sleeper price?
This is where it all starts for me
4 point harness in 91 civic
What is this for?
Need zc motor info
Side Molding
got some coilovers
Best ECU Mod ever!
HELP!! Cracking noise from engine bay
hello here is a easy one how hard is msd 6a to set up
This may or may not happen.
Crank seal
fuel injector questions
Overheat
updated pics of my ride before paint
Web
AF
