Our Community is 705,000 Strong. Join Us.
View Full Version : '88 - '91 Civic | CRX | Wagon | Shuttlee
  1. It Starts!
  2. B18 Swap with no spark COULD IT BE THE DIST?
  3. wheel wells and side moldings
  4. Civic wont start
  5. Hooking Up Vafc For Vtec....
  6. Swap pics, 56k... it may take a while
  7. When To Shift??
  8. hard time finding GOOD b16 cable tranny?
  9. throttle cable
  10. Tail lights
  11. 5 lug conversion in 91 crx
  12. Shift points.
  13. 94'-01' B18b LS
  14. b18 Swap HELP NO SPARK!
  15. MY SWAP IS ALMOST DONE need help with THERMOSTAT
  16. Easiest way to remove headgasket from block and head?
  17. why does everyone hate the JRSC
  18. quick question
  19. 12 sec. Civic
  20. Help!!! head replacement, broke? not right???
  21. b16- 2 vaccum lines running into intake, have aem intake where do they go?
  22. b16a1 questions? clutch speedo cable rear mount
  23. jspec 1.5vtec????!!!
  24. blinking lights
  25. 91 1.5 Idle Surging.code 10
  26. odyssey vs. dx hatch
  27. exhaust question... who likes arospeed
  28. Adding factory tachometer to Civic DX Hatch... Possible?
  29. yeah TPS for b16 broke, dealership, junkyard or ebay?
  30. b16 map sensor broke, probably during shipping. Where can i purchase one?
  31. Where do you all buy ur oem parts?
  32. need some opinions
  33. Civic project troubles
  34. Need Help With B18 Swap Map Sensor??
  35. Skunk2 springs
  36. clicking sound whenever the wheels are rolling..
  37. removal of heat shields...
  38. street import mounts
  39. 90 civic
  40. CRX's all gone?!?!?
  41. Honda/Acura Meet Lancaster PA May 14th
  42. Should I do both at once or wait due to money
  43. What are the major seals that need to be replaced?
  44. Clutch work with different trannys
  45. unstable idel problem
  46. Need Some Help
  47. just want to know what you think or would do
  48. any one from the toronto, ontario area?
  49. Is this a good deal
  50. tires
  51. sold my crx
  52. crx b16 owners
  53. where can you get
  54. b16a1 tranny mount?, bracket missing..help plz
  55. just letting you know
  56. I need a WIRING DIAGRAM!! PLEASE!!
  57. wall of woofers concept
  58. Will 4 door civic seats fit my HB?
  59. suspension swap
  60. Thinking of getting CRX
  61. If there can go anything wrong....
  62. Damn Cooling Fan!!!
  63. New Cat
  64. p28
  65. Gor ZC Runnin (56k beware!!)
  66. k20 turbo crx with rsx-s dash
  67. there goes my syncros...
  68. 91 Civic Hatch Atlanta Newbie Questions
  69. 4th Gen Civic Representin'
  70. progress on taillight conversion
  71. electrical system gone...
  72. 'unlawful display of blue lights on vehicle'
  73. Mount issues
  74. Hasport's new k20/24 mounts...Uh ohhh
  75. my civic just wont start
  76. wiring diagram!!!
  77. Need Help With B18 Swap!
  78. 88 DX - Clunk
  79. eacv bad?
  80. I'm looking to buy a 4th gen. Civic and I have a few questions
  81. umm help.
  82. Does old ignition need removed if I have the MSD SCI ignition?
  83. rsx tails on a hatch!
  84. quick question about a block change!
  85. Help! my third brake light wont come out
  86. Engine Swap Sites??
  87. Rotational Creaking Sound
  88. num.9 trouble code
  89. Is it worth it for me?
  90. Couple of questions
  91. Kinda funny story...
  92. SCAMMER ALERT! DO NOT Buy from doug294!!!
  93. Tach install
  94. Oops, Spark plug mix up
  95. K24 TSX engine
  96. clutch muffler pricing 89 crx si
  97. b16 questions
  98. Door Lock Replacement
  99. OBD1 MPFI Questions
  100. gm tranny fluid
  101. houstin..theres a problem...come on guys!!
  102. Twin Carburettor - Please help to put back it.
  103. question about D15b vtec swap
  104. new exhaust.. modification/rattling issues
  105. Bent Valves, timing off?
  106. B18B/A Install Questions
  107. Rebuild a B18A/B
  108. installing a shift light
  109. How Many of us burn OIL?
  110. turbo manifold
  111. Center Consoles And Disc Conversion
  112. putting stock neon rims on crx
  113. front end conversion...u'guys should no this one
  114. D15B2 engine mods
  115. swap help
  116. welding on exhaust
  117. Think this is legit?
  118. Anyone in the NY area want a civic Si seats ?
  119. SI cam in D15B2
  120. main relay problem??
  121. need help on b16a J-Spec ideling
  122. b16 w/ ac in my 88 si
  123. speaker size question
  124. Distributor Rotor Replacement
  125. HF to SI swap. What's needed
  126. throttle cable for b16a1? can i use my dx throttle cable??
  127. suspension problems...
  128. running reallly rich.
  129. Im Doing My Swap Today!! Have A Few ?'s
  130. re: 91 Honda Civic Alternator Problems
  131. bulbs: what do you use?
  132. FINALLY Painting my car is done (56k beware hell cable/dsl beware)
  133. sum of u ppl might of seen this b4 chk it!
  134. Might Loose my car...
  135. Strange noises from engine and chassis. Any ideas?
  136. lower + upper radiator hoses for b16a1?
  137. i wanna get me 91 civic lowered
  138. GRM $2006 Challenge
  139. wont go past 80, please help
  140. brembo blanks
  141. dsm?
  142. need to know if possible
  143. New Photo Shoot Pics **56k beware**
  144. ZC Installed but.....
  145. Spongy brake pedal
  146. Pics of New Accord (56k beware!)
  147. brake lights not working ?
  148. Painted my Crx today, Pics Inside
  149. Help! Headlight/Turn Signal/Wiper Switch Interchange
  150. my new 89 hatch
  151. MSD SCI Ignition went bad, 1 week old
  152. best motor swap shop in arizona
  153. seats
  154. Anyone going to NOPI in VA?
  155. 4dr vs hatch
  156. Found a good deal on ebay and though I would share it with you
  157. rear windshield wiper problem, doesn't work
  158. 88 Dx with Ls swap?
  159. Rear disc conversion
  160. Im sick of F N around
  161. dc sports 94-97 dohc header on b16a1
  162. Trunk release
  163. Timing Belt on 89 Hatch
  164. Install Airconditioner
  165. was thinkin of doing a 4wheel drive civic
  166. Noise When Revs get to about 3k
  167. Pics of my new ride
  168. JDM parts
  169. 2 10" Subs and a big AMP... but where to put it.?
  170. Fenders don't fit
  171. loud road noise
  172. goddamnit
  173. she wont start
  174. a/c compressor bracket
  175. Is it the CV joints?
  176. obd0 obd1 wiring question im stumped!!!!
  177. a shop to do my swap
  178. engine codes
  179. Fender/sidemarker question
  180. A Simple Question??
  181. holy speeding tickets, batman!
  182. coil in the distributor keeps buring out!
  183. Which clutch to buy
  184. took some new pics of Rhonda!
  185. 91 Civic Hatch
  186. 1990 Si
  187. question about DIFFERENTIALS !!!
  188. H22 or no?
  189. d15 HF Swap Questions
  190. radio/heater control switch
  191. New PICS of my hatch SI and my BMW
  192. Hey to all you obd-0 B18a swaps...need help
  193. HELP!!! I think i ruined my new paint job!!
  194. whistiling/whining in 4th gear hatch..
  195. Dizzy Question and model N#???
  196. tach reccomendations.
  197. Car Wont Start
  198. Do Turbos Get Worse Gas Milage??
  199. HELP? Strange noise, could it be the CV joint?
  200. Spark plug wire removal socket size
  201. Axle/Tranny leak?
  202. brake q
  203. fmu install
  204. who is the fastest?
  205. What do you think might have been damaged?
  206. Ok heres one for ya,boyz---vtec issue
  207. new here, code 7 question
  208. 90 DX Engine Swap
  209. D16Y5 Question
  210. got a problem
  211. only for smart honda fans
  212. My New Project
  213. vted heah
  214. Making 90-91 CRX SiR leather seats fit a 91 Civic HB
  215. 2nd thoughts about buying Eagle Rods
  216. gettin low....
  217. What turbos can go on a b16a1? GReddy...
  218. Will the B18 BLOW?
  219. porshce turbo
  220. D*** so many possibilities
  221. howling sound
  222. Tough Decision - Civic Or Accord?
  223. whats the dif between d15b2 and a d15b7 buttom end?
  224. havin problems with my Z6
  225. Need help finding custom colored oem dashboard
  226. Anyone painted their Wiper arms?
  227. difference between b16a1 & b16a2
  228. jdm parts b16a1 OEM, aftermarket hellppp
  229. sohc ZC swap and info plz!
  230. Say It Aint So...
  231. Interesting project CRX
  232. Fuse Problem...
  233. would my car run like crap without a cat?
  234. 1988 1.5FI Idle Issues!!!
  235. Very Important Hood Question!?!?!?!?
  236. Rubbing exhaust.
  237. Just added a "new" Honda to the family.
  238. wiring question
  239. Is this a good exhaust set up?
  240. B16a1 Wiring Question??
  241. Cant find anwsers anywhere else.
  242. b16 swappage
  243. Where to get new parts to rebuild a DOHC ZC ?
  244. junk yard bumper quest
  245. what is the best ECU to use for a DOHC ZC?
  246. CRX Steering Rack Removal?
  247. h22a conversion
  248. stock b16a1 header or keep dc sports
  249. sound deadening
  250. Honest Opinion
