Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '88 - '91 Civic / CRX |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
hood pins?
What is the easiest swap for my 91 HB SI?
What plug goes to the IAC Sensor?
Thoughts on new paint job
help me out please
struts
No power to ecu
What is the CYP sensor?
Updated pics of my car....
gas tank question....
shaved doors ect
this is unusual huh? video
Tech Problems
i know i ask alot of dumb shit but heres some more
E-Brake light staying on...
best cam for a z6?
What do you guys think of these lights
I Love my Honda
Pictures Of motor Build (56k no no)
92 b18 into 91 civic?
The tri-state area
Top Speed
pictures of car...finally got new ones on here
Zc Motor ?'s
B18b vs b16a1 or a2
backfire and sputters
Aftermarket Tach
90 Hatchback DX
idle issues
Safc Ii
taillights and running lights
I want my baby back, baby back, baby back..
Greddy Pipe
Lowerd SI
b18c in 4 gen civic
wat other clusters ARENT VSS
Free Strut Bar For 88-91 Civic Si/CRX
Quick Q - "LS" tranny
1991 SI Starting problem, ecu light flash every second
civic dx
turbo kits for ls swap
ENGINE SWAP PICS *56K I dunno*
need some help guys (parts wise)
I little help?
his will fit
g2 integra seats into my 90 DX
Electric Problem (89 Civic Si - ED7)
this is just a little thanks
Current Pictures
89 civic seat bracket help!
need help with a 4 wire o2
CRX HF Interior ?
Help! longest lasting problem ever!
major problems help!!!!
Instrument Cluster swap on '91 civic dx
b16 engine shuts off at 7100 rpms?
what springs out of the 3 should i get?
Project Taking Shape.
Gas Mileage w/B16a swap - HELP!?
Boiling battery acid...
painting interior in my civic
Need advice on swap
front disc upgrade
down pipe bolt
91' CRX hf replace clutch
who has a turbo b16 and what setup do you run?
intresting D16 info from T.O.O.
Anyone know a good source to buy an LSD tranny?
Video from Philly event at Northhampton Community College.
silver motegi mr7's on a black crx?
RPM Surging
Are all D-series Blocks the same?
PG7 troubles
b16 02 sensors not hooked up still runs the same
alternator fried after a week
Car running but not moving????
Cheap way to get 250 hp from a civic?
quick question
civic vti 3stage
b16 head???
Head Lights -> Smoking gauges
fuel delivery issue?
auto to manual - is it worth it?
ls swap help
how to convert from d15b2 to d15b7!!! HELP
vtec's FINALLY hooked up (temporarirly ghetto rigged), one last question though
get go smoke
woeua[rjfas'ldkf
Fiberglass 101 - Tutorial
What color is the RPM signal??
why do people relocate their battery?
HowdoI remove black on lower hatchback window?
No fuel or spark...
Whining from Clutch?
mpfi swap
Update 56k Beware!!!!
89 civic d16 swap
z3 metal fenders?
Updated taillights pic...
Updated interior....
Shocks/ Struts
Update: 88 and 91 crx pics, 56k NO NO!!!
b16 check eng. light comes on when warms up
EE8-EE9 VT/VTi Parts?
Custom Interior
acceleration: Tappets or Gearbox?
Knocking Noise..oh god..
sohc
bushing compatibility
My head is Back from the Machine Shop (pics inside, 56k ok)
windshield
shift linkage
What tranny fluid should i use??
whats the deal SI?
zc engines
code 8
goodbye dear Si transmission... (#5)
Fast and Furious 3
Civic Geeks speaker pods. Pics
Looking for the name of an Air Intake
? About Rear Cargo Space
help!!!
turbod d16 or all motor b16
02 simulator for b16, do you need one?
no more pullys no more lag
having trouble water temp
b18 swap shift linkage
Short update and quick Q...
chrome trim adhesive removal
Making A CRX Fast...
b16a idle help?? plug??
How easy is it to replace the lower ball joints?
Need Wiring Diagram... OBD0--> OBD1
Engine Build... Updates...
suspension questions...
my crx si swap
B16 questions
obd 0 - obd 1 conversion....
Rear Sway bar
B18C into civic or crx
About D16Z6 & D16ZC
Did PGM-FI Swap & Now I have temp gauge flux?
where are the fuel lines routed?
Ignittion lock cylinder
Engine swapped into civic/crx
1989 Honda CRX Si VS 1985 Porsche 944 non-turbo
Damm exhaust
CRX tank size?
unorthodox racing pulleys?
CRX hf mpg
Wiring questions (pics included)
Looking at replacing the hatch hydros
4-dr project idea
Help Me Please
i need to move out!!!!
crx swap to a d15b 1.5L VTEC
please help!
spongy brake pedal?
rear discs
racing chips
Anyone with an LS swap, need ECU code
Idle Problem...NEED HELP!!!!!
B18 Swap Not Running Right! Need Help!!!!
how do you remove driver side window trim? (metal black pieces outside)
door compatibility
A/C with DOHC engine?
90 dx wont start anymore
Switching to Synthetic..bad?
no more crx
90-91 civic bumper lens
Need help with alarm with starter disable
fuel pump
Part number needed!
89 Civic leaks feul
b16 check eng lite on, stumbles on acceleration
rally rex
auto no drive in D normal from 2nd
2g (90-91) Crx Common Problems and Price of Repairs
'88 Civic sometimes won't start...throws CEL...today it apparently worsened :(
rear spring swap for hatch
B16a1 Code 22
Help! '90 Civic w/ electrical starting probs!
MAP sensor problems
i messed up
rear bumper fit??
low mpg
Dpfi to Mpfi expense and difficulty
CF Hood >CTK
crx engine swap
Pretty sure I saw one of you today...
b16 help! sounds like its running on three cylinders, no power
Resistor Box Prices?
Pwo Ecu Fs:
Engine temperature gage goes up and down.
I want a new front bumper
90-93 teg or 92-95 civic radiator????
Back from paint
B16a Butcher Job
Do vavle breathers work?
Oil light
DPFi to MPFI - No Reverse Lights!
How long to break in a cluch?
Lighted door Mirrors.
all i need is a running engine!!!
Finally Got My Bumper Lights To Light!!!!
pics of my new 89 CRX Si JDM B16a
b20b problems!!
b16 swap questions
D15b8 and d16a6 heads
headgasket replacement
Loud BANG! now have low oil
How do you remove the fuel pump??
HELP..filling transmission.
suspension trouble
Link to the manual?
B16 question for Oz Civic Owners?
CAN You use an OBD0 Altenater on an OBD-1 Engine?
02 Si rear seats
hatchback seat mounts
B18 SWAP Done BUT NOT RUNNING RIGHT??
Bumper spoiler
roll pin b16, can't get out
single wiper
Harnesses
Check out this 4dr
Turbo
Please help me
4th gen lips
My lip
know any reliable engine importers?
canadian and american civic swaps
got a new beater! (its not an EF)
1.6 zc crank im 1.5
Pics of my project 4door
1988-91 Civic Si Parting-out
Over size valve for zc? form si? dx? witch can i use?
Brakes??? Fluid???
P30 pistons
lexar
Whats under your hood?!?!
Turbo Question
fuel pressure ....
How to release stock radio....
chopped top civic??
What kind of oil would you use?
what size slicks
my next car, bit exspensive but worth it!
CLUTCH Engagment Problem!! HELP!!
looking to buy crx...good deal?
oxygen senser wire
Web
AF
