Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '88 - '91 Civic / CRX |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
New pics of my car lowered and more
Stereo (deck) install question
Spun Bearing
2nd gear top speed
Tach signal wrong?
Its over: Bye Civic
Trannys and high RPM shifting
Radiator Fan Reversible?
New ZC info for everyone
i put my si-r up on classifieds
Hambugerler killed my Rex
here some pics of my boys ZC project.
does anyone have a pic of this
Side marker install (pics 56k)
Nitrous+No oil= help me!!!
zc head
wat exhaust?
Me and my bro's hatchies
should i buy?
got my new REAR END conversion done!!
NEED HELP FAST mid swap
What model Do I have
Whats better than a big red sleigh?
Intake slug
tachometer help in 89 civic std
what usdm ecu can you use for a b16?
Engine swap - now burning oil/coolant - need help
89 civic LS
New intake manifold b16a
ECU Pins
When i lowered my car the crankshaft pulley hits tie rod!!!????
B16 mounts
B16 JRSC differences?!?!?!
Fix AC or risk major trouble?
Motor Update...
Seatbelt motor...
compresion ratio limit for NA b16a
Free is for me!
free in NH area
wich injectors
buying parts for a japanese b16a
zc 5spd what goodies?
what to do about the bragger
boost gauge
Who was it that had Pop Cans Blow up in their car ?
K2 Headers, need assistance
Fiberglass rear enclosure *WIP*
tuner heads got a question?
good or bad idea
Rough Idle
nooooooooooo help
4dr keyless handles on a 2dr hatch
ignition switch
check this out!
Custom METAL Body Kit!!!
does a cai from a teg fit our civics
Should We Get Free Parts?
94 integra front brakes on a 4th gen hatch??
b16 compression
88 civic hatchback D152b engine!!! i got some stupid questions
dizzy
CRX leather seats, Will they fit a hatch
redline of d15b2
broken already? please help
New Pix Of the Pimp-Mobile
My Update thread
ignition replacement need help!!!
Skunk2 Cat-back
racing seat mount brackets ?
So confused
CRX SI Heater/Blower in a Civic HB DX with CRX Dash
Help Please asap
stereo/speaker help
B20 Question
Question about rear brakes
B18b1 swap help
great steal or bad deal?
havent posted forever, update on my cars..
engine help
resistor
brake help
What oil filter for B16A?
fuel presure regulator check??
Farewell D15B2 Block.
need help installing a tach
wanna dynamat the whole interior quick question
check out this crx, its a steal
binghamtonlife service manual site down?
master cylinder swap
Am i doing something wrong...
times and power?
how much should i ask?
Oil Control Jet on D15B2/ZC SOHC
b18b1 with which axles?
psi on cylinders
Is flushing the transmission oil harmful?
i need an idea
honda ecu
b18c1 swap into a 89 rex?
glass scratch
smoking
Tranny Question
pop out windows?
tach gone stupid
need honda help!!!!!!!!!!!!!!!!!!!!!!!!!
Will a b18c1 manifold fit my cAr?
Help!!! Can't Find A T-belt For Zc Dohc
d16a9 problems
olive drab or flat back
Serious waste of time and money, but what if???
Yesterday and today.
B16 exhaust manifold clearance
wont turn over after it stalls
Finally got pics of my 91
a comeback
injector replacements
Multi-Point Injection
Tachometer Problem
Civic won't start! is it the ignitor?
really stumped on this one
me again with my carbon fiber questions.
new halo projector lights.
whats this worth?
Traded 4dr
F**K! Forgot where the hose goes!?
ZC not sparking
Videos from Philly @ Ripken combined.
Need Help ASAP
Oil
auto paint help
b16 ecu?
door beeping help
car was stolen
obd0 to obd1 questions
resonator?
EF Civic raping a skyline
major moisture/leaking problem in hatch
idle surge
tangerine
b16 trouble code
fixing my crx
Gauges only work in reverse
windshield undone
justgot wingswest 6pc bodykit
please help me with my 91 crx
radio
b16 VTEC shuts off while racing through gears
Short video of my car
A dumb question
oxygen sensor wire
Got My LS motor
Engine Start button
converted to r134 but problems arose
new rims need help
Where can i buy new side moldings for my hatch?
painting interior
It's Alive ! (pics to follow)
5th gen front end swap on a 4th gen???
Rough starts
B16 or B18 that is the question
Rim's ?
Looking for pictures of turbo kit with a/c left on!
b16 build with itr parts....
boggin out b16
Motor Swap
N11 Pics
gauge clusters
zc problem
What are the best ways to lower your civic?
Need Some Help With Pick A Motor
idle problem
what block do u recommend..
turnsignals, clock, temp gauge, fuel gauge, and rpm guage dont work! why?
ZC with LSD?
ECU Fuse Blowing
chipped ecu
What clutch?
D16Y8 help
Speeker Box Issues
cleaned IACV and...
goes up and down at idle...
uh oh....
90-93 integra dash in a civic
Torque Settings?
Mini-me swap
New Stereo Project Started
heat vs my crx
Dizzy problems
clutch master cylinder
do you have to swap
aluminum crank pulley
water pump out?
Revving Up When Warmed Up-lifting Pedal Helps??
Headgasket Problems/Engine Problems
Hondata S200 Kit ... Anyone used it ?
spindle nut wont budge
can this pose a future problem?
a few dohc ZC questions.....
Story about timing belt today
Ebay turbo
stupid oil plug
hey code 10 on ecu???
89 Civic Hatch DX
RE: Oil covered sparks plugs????
Odd noise
pm7 vs pg7
Back on the track
I Need Help With Iac Sensor!!!!
hi, newbie ?s
stupid fuel injector
The latest ebay impulse buy
Peak power RPM for shift points
so i beat that 98 eclipse GS :)
Pinging even though it's timed right
Cat options
Drop it 2" on standard strurs?
spoiler wrapped in carbon fiber?
Got my parts...Next will I begin the motor build.
swap info?
temp gauge and gas gauge
Thermal R&D purchase?
AC help!!!
d16z6 170hp without fi?
Relay?
mini-me swap question
Way to ID limited slip trans. ??
Cant Stop - Loosing Brake Presure
Can't find them anywhere
SOHC ZC Questions
B16a bucks when i drive it
what times sould i be running?
My new custom CF fenders....
tinkering with broken transmission 90 civic 4door
dose any one know how to wire up a o2 sensor
buying 1988 Honda Civic
Wheels
how do you reset ECU?
swap
89 Civic H/B swap
The best Kill I have ever had!!!
gasket question
I Win !
High Idle
pics of my ride
does your engine perform better with, or without the O2 sensor??
HELP. Cooling Fan does not work
coilover! were do i start?
conversion
Front suspension crossmember?
what do you think of this
Web
AF
